01-22-2019, 06:09 PM | #51 |
Re: Who's running steelies on their K5 - post your pics
Currently running 15" x 10" alloy aluminum wheels but would strongly consider running these 20" Rally reproduction wheels from US Mags in white or grey.
http://us-mags.com/sierra-u706-6-lug-w-7843.htm
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 01-22-2019 at 06:16 PM. |
01-22-2019, 09:40 PM | #52 | |
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
01-23-2019, 03:28 PM | #53 |
Painted these traditionally. Open face steelies.
01-24-2019, 02:49 PM | #54 |
37" on 16.5 homemade to 9.75 wide - painted with Rustoleum hammered black, which comes out dark gray.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
03-05-2019, 04:49 PM | #55 |
Running 31x10.5x15" on stock 15" x 6.5" stock steel wheels on my '72 4x4 Jimmy / stock suspension.
03-05-2019, 06:15 PM | #56 |
33x12.50R15's Mickey Thompson Baja Claws mounted on 15x8 steelies.
03-07-2019, 07:35 AM | #57 |
15" X 8" Wheel Vintiques steelies with Mickey Thompson Degan 38 32" X11.50 " tires. I have hub caps but haven't yet decided if I am going to put them on.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
06-04-2019, 11:38 AM | #58 |
06-04-2019, 11:47 AM | #59 |
Carpe manana
Thank you - I miss that one. 4" lift and 33 x 10.5" old style BFGs. I went with zero lift on my current Blazer with same size tires. With the 4" lift it was tough for my wife to get inside. That said, I still added the accessory steps to my zero lift current Blazer for her.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-04-2019, 11:50 AM | #60 |
Awesome. I'm running the 12.5/33's - no lift but new leafs so it sits up decently. Thinking of going to the 10.5s for potentially better steering.
06-04-2019, 01:30 PM | #61 |
Rsavage, what is the backspacing on those wheel vintiques? And do the stock dig dish hubcaps fit onto the nubs?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
06-05-2019, 06:41 AM | #62 |
I believe they are 4.25" back space. It puts the inside edge extremely close to the tie rod ends. Thought I would have to run 1/4" spacers so put some longer studs in the hubs in preparation but ended up not needing to. The nubs accept stock type caps. One thing I found is that these wheels are not perfectly true from the manufacturer. I didn't notice that on the 15 X 6 set on bought for my Vette or the 14 X 7 set I put on the 65 GTO. Had to make sure that the two used on the front of the Blazer ran true - that's how close the inside wheel lip is to the tie rod end.
06-05-2019, 07:09 AM | #63 | |
Thanks! That is great info. I like that you can use the stock caps, but my concern also was whether or not they would clear the tie rods in front. I have an older set of 15x8 wheels that are about 3-7/8" backspace and they are fairly close as well. Maybe I should restore these instead of buying new. Hmmmm....
06-06-2019, 10:21 AM | #64 |
Here's my 71. I had a set of 16X7's made for it with maximum backspace. (If I remember correctly, 4 1/4" backspace). It has a set of 235/85/R16 Hercules mudders mounted up on them
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find) 67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find) Keith Riel |
06-10-2019, 03:54 PM | #65 | |
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
06-10-2019, 06:30 PM | #66 |
12:50 33” km2s
12-08-2019, 06:48 PM | #67 |
What size tire are you running? Do your Steelies have 4 nubs? I’m trying to find some. But only found with 3 nubs so far.
12-08-2019, 07:15 PM | #68 |
They are 12:50 x 33” on 8” 4 nub Steele’s. My buddy just found some 3 nub from firestone with the correct back spacing for the calipers. I was always told 3 nub does not clear. I just saw hillbilly wizard.com has some m1009 rims but they are pricey. Mine are m1009 rims
