Old 01-15-2014, 09:38 PM   #51
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: The "Wrecker"
What will be going on soon.
Alan's Classic is offline   Reply With Quote
Old 01-16-2014, 12:10 AM   #52
mrolds88
Re: The "Wrecker"
Alan, if you convert to the disc's (which I would too) you should need to replace the front wheels too. Up through 71 ( I think might have been 72) they used 1/2" studs, after that they went to 9/16".
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-16-2014, 12:25 AM   #53
mcbassin
Still Learning
mcbassin's Avatar
Re: The "Wrecker"
That's some super nice parts!
mcbassin is offline   Reply With Quote
Old 01-16-2014, 06:41 AM   #54
eldogg
eldogg's Avatar
Re: The "Wrecker"
Thanks a lot! Now I want a wrecker again. Looking good.
eldogg is offline   Reply With Quote
Old 01-16-2014, 11:52 AM   #55
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: The "Wrecker"
That will be nice!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-18-2014, 11:49 PM   #56
Alan's Classic
Re: The "Wrecker"
The donor is a 83 P30, Thank you for the info.
Glad I could help.
Originally Posted by aggie91 View Post
That will be nice!
Thank you Sir.
I researched the engine and it's a GM Goodwrench crate
350 Cubic inches 4.00" Bore, 3.47" stroke
8.5:1 compression ratio.
250 HP @4300 rpm
350 ft. lbs of torque @ 3600 rpm
( These Numbers obtained with a Quadrajet Carb,1 5/8" headers , and an Edelbrock Performer intake part # 2101)
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036
2 piece rear main seal 4 bolt main
Crankshaft- # 3932444
Nodular Iron 1985 and older flywheel bolt pattern.
Powdered Metal Connecting rods- # 10108688
Cast Aluminum Pistons-#12514101
G.M. High Volume Pump Oil Pump- part # 12555284
Hydraulic Flat tappet Camshaft- #14088839
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194 Exhaust Duration @.050"- 202
Lobe Seperation-112
This cam Has a mechanical Fuel Pump Lobe.
This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808, casting #33417369, 1.94" Intake valve, 1.50" Exhaust Valve, 76cc Combustion Chamber, 7 Bolt style Exhaust Flange Standard, 85' and prior intake manifold bolt pattern. Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
Also got the wrecker in the shop for a little while.
Old 01-19-2014, 10:19 PM   #57
Alan's Classic
Re: The "Wrecker"
Picked up some west coast mirrors today and hung one temporarily to see how it looks.
Old 01-19-2014, 11:43 PM   #58
Bomp
Bomp's Avatar
Re: The "Wrecker"
Aaargh, can't stand drillin dem der holes.
Take it you've sat and scoped'em out to see how much you can see. If they work then they're a keeper.
Bomp is offline   Reply With Quote
Old 01-19-2014, 11:43 PM   #59
Bomp
Bomp's Avatar
Re: The "Wrecker"
Looks good Alan.
Old 01-20-2014, 09:42 PM   #60
ChickenCityHotRods
ChickenCityHotRods's Avatar
Re: The "Wrecker"
Man I love wreckers! My uncle has been in the business for over 40yrs so I have it in my blood a little. Can't wait to see you make some progress on this thing.
Twin Turbo and Dropmember equipped http://67-72chevytrucks.com/vboard/s...d.php?t=586662
Follow us on Instagram @CHICKENCITYHOTRODS
ChickenCityHotRods is offline   Reply With Quote
Old 01-20-2014, 09:46 PM   #61
ChickenCityHotRods
Re: The "Wrecker"
If you ever have a little free time you should ride up to Chattanooga and check out the International Towing and Recovery museum. There are some nice restored wreckers of all sizes there.
Old 01-25-2014, 04:22 PM   #62
flashed
Re: The "Wrecker"
Alan,the bodyshop sent the doors home with me today if you still want to look at them for your truck.
flashed is offline   Reply With Quote
Old 01-25-2014, 10:04 PM   #63
Alan's Classic
Re: The "Wrecker"
Briefly, they should work if I decide to install on the new stuff I got today.
Looks good Alan.
Thank you sir.
Thank you for the heads up on the museum. I never knew it was there
Thank you but I got some doors, cab and front clip today.
Shannon and I went and picked some parts off a 1969 GMC up today. The cab, inner fenders, rad support and sheet metal has surface rust and minimal rot. The outer rocker is the only parts that have any holes to mention. The cab has a new windshield and gasket.
I also picked a C30 roof skin with cab lights that I might put on this cab. The only problem is the cab has perfect patina and if I did the roof it would mess up the patina.
Old 01-25-2014, 11:29 PM   #64
Ta2Don
Ta2Don's Avatar
Re: The "Wrecker"
It is about to get Real!!!
Still Spying...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 01-26-2014, 07:32 PM   #65
Alan's Classic
Re: The "Wrecker"
Still Spying...
I hope so.
I washed everything with a red pad and Ajax.
Old 01-26-2014, 08:46 PM   #66
flashed
Re: The "Wrecker"
Thats some good looking sheetmetal you found .
Old 01-26-2014, 10:06 PM   #67
jkeating1
jkeating1's Avatar
Re: The "Wrecker"
dayum! That's a whole 'nother truck. I see a frame-off restoration coming!
BTW---You are bringing a tear to my eye! I spent most of 1971 and 1972 driving a dark green '68 C30/Holmes 440 around southeast Texas. Some of the best times of my life. It was a 307 2bbl, of course no overdrive, and prob a 4.10---it was literally foot-to-the-floor most of the time (typical kid driving a company truck). That little engine never skipped a beat!
JK
jkeating1 is offline   Reply With Quote
Old 01-28-2014, 12:02 AM   #68
Bomp
Bomp's Avatar
Re: The "Wrecker"
Does the Ajax leave any type of film after rinsing?
Old 02-02-2014, 05:23 PM   #69
ljackson
ljackson's Avatar
Re: The "Wrecker"
Cool truck. I saw one in a Scrap yard last week. It has had a much harder life that yours.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 02-02-2014, 08:22 PM   #70
Alan's Classic
Re: The "Wrecker"
I agree it is pretty solid for this area.
This one won't be a frame off. Although all systems will be gone thru the bed isn't coming off.
on bringing a tear to your eye.
No film is left just a little dust if not rinsed well.
I've seen a decent holmes hed for sale for $900
I cut the donor roof off today. The front corners are paper thin. Still deciding if I will use it or not. There was a NOS cab light kit on ebay for $240. While it was a little pricey I debated too long. I went to get it and it sold.
Old 02-02-2014, 11:19 PM   #71
Alan's Classic
Re: The "Wrecker"
Here's the light kit I missed out on.
Old 02-03-2014, 01:29 AM   #72
65 wonton
Re: The "Wrecker"
Seems it would be alot easier to use the light kit from the donor rather than the whole roof panel. Just drill 5 holes (OK and the mounting holes) and swap the wiring over.
Dave.
65 wonton is offline   Reply With Quote
Old 02-03-2014, 08:31 AM   #73
Alan's Classic
Re: The "Wrecker"
Dave.
The donor roof has raised pad where the lights sit. I was wanting to make it look correct, but you might have a good idea. I might try it the way you mentioned and see what it looks like. That way it won't disturb the paint. Thank you.
Old 02-03-2014, 11:16 PM   #74
65 wonton
Re: The "Wrecker"
Now see, there in lies presumptuousness.
I've never seen a top with molded bases for the running lights. From my '66 to my modern '06 they were all just smooth lids. Now, I can understand why one would want to preserve the original molded roof lights. I've read a lot of your posts and I was wondering why you did not take the easy route. Now I know you were aspiring to loftier aspirations.
Any way you could post a pic of the molded base? I'd like to see it, others too I presume.
Love to read your posts.
Dave.
Old 02-03-2014, 11:28 PM   #75
Alan's Classic
Re: The "Wrecker"
Here ya go Dave
