#51 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: 66 Build
Man, that is a sweet lookin' grill.
I like it a lot!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#52 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 66 Build
#53 |
![]() Join Date: Sep 2013
Re: 66 Build
Thanks for the compliments guys! I actually borrowed that grille idea from a post I saw by Lakeroadster? some time back. Can't remember what site I saw it on either.
#54 |
Finally got the inside of the passenger door painted. Got door mounted today. Had a little grief getting it to fit in the jamb nice. But I won.
#55 |
Re: 66 Build
Worked on fitting A/C housing and inner fender together. Had to mod the inner fender and A/C housing (Tire clearance is somewhat tight. I will try get a photo later.) . I started on this last spring and got sidetracked onto other items - now am back to the front end. For those who don't recall. I am installing a A/C from my donor truck a 1987 R20 which was converted to 134A.
#56 |
Re: 66 Build
Nice work can't wait to see more
#57 |
Re: 66 Build
I cant wait to see the AC Fit in... Thats something I seriously need to do.. You do Good work HotRod...
Find a way to download your abilities and I'll plug in. |
#58 |
#59 |
Re: 66 Build
That does look nice!!!
I am kinda wishin' that I would have done that with the underside of my truck! Mine shines too much for something that I want to drive the crap out of, and I don't know how I will keep it clean! Seriously, no kidding on this subject.
#60 |
Hauled out A/C system from storage. Started assembly.
#61 |
Re: 66 Build
Good Deal Hotrod1952
I have the same set up for my 65 Suburban, not there yet but soon .... Can you post some pictures from the inside under Dash etc? Would be highly appreciated ! Thanks Eddy |
#62 |
Post Whore
![]() Join Date: Mar 2013
Re: 66 Build
Looks nice! That orange is really gonna stand out!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#63 |
Re: 66 Build
Here's what I have Dsuper5. I will get more up later when I move to the inside of the cab!
#64 |
Re: 66 Build
A few more...
#65 |
Re: 66 Build
Nice
Thanks a lot that eased already my headache a bit ![]() |
#66 |
These shots show tire clearance to inner fender. I'm using 2.5 drop spindles and expect to install 1" lower springs yet. 3/4 ton truck with 1/2 ton springs in front now. Also need to move steering arm 1 spline over to make this side turn shorter and center the steering.
#67 |
Re: 66 Build
#68 |
More pics of the front end & A/C install.
#69 |
More... I used the condensor mounts off the 87 also.
#70 |
And a wrap up... I had to trim the battery box in 3 places.
#71 |
Re: 66 Build
I've been looking at the a/c condenser for nearly a week and I hate how the mounting turned out. So I went to the big book(Google) and researched what other cars had similar hose ends on the condenser that also was shorter by a good bit. I ended up setting my sights on a condenser from a mid 80's Corvette. I was surprised at how readily available they are used. So the Fed ex truck showed up today with one. I was also happy with how easy it was to bend the lines for hookup. I like the look a whole lot better.
#72 |
Re: 66 Build
#73 |
Re: 66 Build
Thought I should post up a couple more pics on the progress.
#74 |
Re: 66 Build
Got paint on the top and windshield installed. Started working on the hood. Lots of hail dents on the 40+ year old hood. Found a small spot of rust on the lip, working on repairing. Put bed liner on the underside of hood.
#75 |
Getting ready to start putting doors together. Ordered all the rubber - rivets etc. Should be in today. Found an article on the door locks from Custom Classsic Trucks Apr 2001 edition. I bought a copy off ebay and scanned it to a pdf. I'll try and attach it. I had to compress the PDF files to get them on the forum. I can e-mail them to any who want a higher quality document. Its about 5MB in size.
Last edited by Hotrod1952; 12-05-2014 at 10:03 AM. Reason: no attachment,pdf quality, cannot spell |
