02-09-2014, 01:28 AM | #51 |
Re: MORE lsx wiring questions
Internal or external pump?
I have seen this before....ther is a positive and negative on the pump. I have seen people wire them backwards and it will buzz like it should but it wont pump. Something to check |
02-09-2014, 08:31 AM | #52 |
Internal..I will check that out..thanks
02-09-2014, 09:16 AM | #53 |
If possible, disconnect everything on that box. Grab (1) relay and wire it for the fuel pump relay. In this order, Id test the fuel pump signal first. If that works, connect and wire the fuel relay by itself.
30-Fused Battery Power 87-Power to (+) on Fuel Pump Note: Fuel Pump must have Ground(-) also 85-Fuel Pump Signal Note: PCM Sends (+) Fuel Pump Signal 86-Ground(-) Note: #85 & #86 can change polarity, which means that the signals are interchangeable, but you must have both the (-) & (+) to power the relay/accessory properly. These are relays instructions I die by. If someone wires a relay in this fashion and it doesn't work, I'll shoot myself in the foot. |
02-09-2014, 09:49 AM | #54 | |
02-12-2014, 10:50 AM | #55 | |
02-12-2014, 11:07 AM | #56 |
Double check to make sure your coils and injectors are getting power. Also make sure the crank and cam sensors are plugged in.
How long has the engine been sitting? Could have stuck injectors.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-12-2014, 11:38 AM | #57 |
Make sure the injectors and fuel pump are receiving a constant 12V while you are engaging the starter.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-12-2014, 11:44 AM | #58 | |
I will check that..Thanks |
02-12-2014, 11:53 AM | #59 |
smartass12, no need to buy new fuel injectors, there is a product called Sea Foam. Submerge the fuel injectors for 24 hours and reinstall them. that's how I cleaned my injectors.
02-12-2014, 11:57 AM | #60 |
this stuff is sold at the auto parts store. Also is your PCM sending a fuel pump Signal?
02-13-2014, 10:56 AM | #61 |
ill try that first then.. Also is it safe to assume the PCM is sending signal if the pump kicks on for the two seconds when the key is switched on or is it better to check for signal as engine is being cranked over?
02-13-2014, 09:18 PM | #62 |
when you turn the key, and the fuel pump turns on for two seconds, then turns off your, then you are on the road to LSX freedom. Also, when you turn on the key power, (+12v Switch), things such as coil packs, MAF sensor, injectors, O2 sensors, Tranny, and Tac Module/foot pedal should have power. the above listed items are waiting for the PCM to send ground to operate them in proper PCM Fashion.
02-18-2014, 10:53 AM | #63 | |
02-18-2014, 11:09 AM | #64 |
Yes.
02-18-2014, 03:32 PM | #65 |
meowMEOWmeowMEOW
If you are still planning on doing or re-doing the battery in back, you can take a look at what we did on my 66 in our video.
02-20-2014, 10:56 AM | #66 | |
02-20-2014, 11:43 AM | #67 |
lol, welding cat
