Old 07-28-2014, 08:13 PM   #51
Lalla666
Re: How much would you spend
Originally Posted by oldno7 View Post
That bumper threw me off I thought you only had 1 front turn signal light lol then I realized it was just a bumper sticker that's actually on the bumper hmmm
It's not 4x4 I'm 24 yrs old and work full time I plan on keep her original has much has I can today I change the fuel pump but the carb is definitely goin to need a rebuild I also found in the glove box the receipt from 1970 along with the warenty card lol
Lalla666 is offline   Reply With Quote
Old 07-28-2014, 08:14 PM   #52
Lalla666
Also the dash pad has no cracks and the blower motor works and all the lights work besides right blinker also the truck was last register 2007
Old 07-28-2014, 08:22 PM   #53
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Wow, good buy! Do you have any more pics of the truck?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-28-2014, 08:31 PM   #54
Lalla666
I have just this one from the other night
Also that fuel pump was a pita for me, I'm a ford guy so you just drop the fuel pump in and it aligns itself not chevy I found there's a rod you have to hold up and put the pump in the same time, it took me 45 mins before I had to have my buddy help.also has for the fuel filter is the one in the carb good or should I add one in the line too
Old 07-29-2014, 02:50 PM   #55
Lalla666
Should I keep my original carb or go with a Holley my buddy seems to think Holley is the better route
Old 07-29-2014, 03:42 PM   #56
GuyO
GuyO's Avatar
That is a question we regularly ask ourselves. For me - if I buy an original truck like yours (which is awesome BTW!) it stays original. If I buy someone else's project and it already has been altered, then its ripe for all kinds of mods. The classic question isn't Ginger vs Mary Anne, its restore vs. modify. And for the record, its Mary Anne
GuyO is offline   Reply With Quote
Old 07-29-2014, 03:49 PM   #57
Lalla666
Yeah I want to keep it original but my buddy's seems to think that the Quadrajet carbs always have issues and leak which mine does but what do you expect lol
Old 07-29-2014, 05:23 PM   #58
mechanicalman
Wow that's a steal. I'd be afraid to try to get the price lower, wouldn't want to insult him. I'd try to pay him and get the title ASAP. I believe it's worth maybe triple, quadruple to the right buyer, some people are longhorn crazy. Rare truck.
mechanicalman is offline   Reply With Quote
Old 07-29-2014, 05:26 PM   #59
mechanicalman
So is that rear coil springs with the leaf helper springs mounted off the side of the frame behind the rear wheels?
Old 07-29-2014, 05:49 PM   #60
Lalla666
It's leaf sprung but he don't have title but in ct I don't need one for that old
Old 07-29-2014, 05:54 PM   #61
Lalla666
It may be coil I have to check my buddy's dad things the truck is worth 3500 has its sits
Old 07-29-2014, 06:01 PM   #62
mechanicalman
Get a syringe or turkey baster and suck that fluid out of the master cyl. Get some dot 4 and fill it back up, crack all the bleeders at the wheels and see if you can get it to run out all 4 wheels, don't let the reservoir run too low.
Then, bleed it out starting with the lines on the master cyl then all 4 wheels and see if you get the pedal back or not.
Be careful even if you do, a master cyl can be spooky working seemingly perfect then it can by-pass without warning.
Old 07-29-2014, 06:06 PM   #63
mechanicalman
Well looking at the option list the auxiliary leaf springs brings to mind some I've seen on trailing arm/coil spring trucks that mount on the outer side of the frame behind the rear wheels, and they are "half leaf".
Old 07-29-2014, 06:08 PM   #64
mechanicalman
Biggest, most common mistake made with the Q-jet is to over-tighten the bolts that hold it to them manifold; this warps the top cover and leaks can ensue.
You can actually straighten the top cover with a soft mallet, wooden blocks, a nice touch and some courage. Maybe you could take it to somebody that has done it before.
Old 07-29-2014, 06:10 PM   #65
mechanicalman
I used to be a "Mary Ann" buy, but now it's "Ginger" LOL
Old 07-29-2014, 08:13 PM   #66
Lalla666
Old 07-30-2014, 09:09 AM   #67
volksworld
damn a waterford speedbowl bumper sticker...went there once in the 80's...does that track still exist?...and my tow vehicle at the time was an orange 72 longhorn c20 ...your truck is amazingly solid for a ct. work vehicle....hope they spilled enough tar in the bed to preserve it...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-30-2014, 09:24 AM   #68
Lalla666
Waterford is still there and the bed still has wood I gotta clean it out though to inspect it it looks solid on the underside tho
Old 07-30-2014, 12:20 PM   #69
AirSpeed
AirSpeed's Avatar
Nice truck! Tailgate looks great and so do the rockers. Check the drains under the rockers and make sure they're open, check the cab corners for crap, clean the drains there too. There are also drains in the doors that plug up. I took a hose to all those areas in my trucks, you will be surprised how much crap will be in those areas. All that dirt and road goo will hold moisture against the steel.
Great buy! Nice truck!
AirSpeed is offline   Reply With Quote
Old 07-30-2014, 09:18 PM   #70
Lalla666
So today I bleed the brakes in the back got one to spit fluid the right Sid it just driped out I could not get any to squirt out but the pedal did start to come back i also notice the back hose was a little dry rotted I also replaced the carb bad gasket and she idle like a champ but I couldn't rev it it would die and I notice it was leaking fuel by the filter so I tighten it up and then it wouldn't idle
So my parts list so far is
Battery
Rear brake hose
Carb rebuild ( I'm going to attempt )
Also had a scare today when I started it it was knocking so I thought the motor was bad lol but it was just the fan shoud hitting the fan lol
Old 07-30-2014, 09:35 PM   #71
stsalvage
Scrapper 1
stsalvage's Avatar
Even tho its a longhorn I be finding a 1/2 ton 1973--87 suspension and put it under that truck.Most of us will never use them trucks as trucks any longer.Making it a usable truck in getting good Gas mileage would make that truck such a wonderful truck to build
stsalvage is offline   Reply With Quote
Old 07-31-2014, 10:40 AM   #72
71veronica
71veronica's Avatar
I'd leave it all original.very nice long horn pretty rare. Just make it reliable and safe.
71veronica is offline   Reply With Quote
Old 07-31-2014, 01:44 PM   #73
Lalla666
That's the plan
Old 07-31-2014, 09:24 PM   #74
Lalla666
Got some stuff today I order the carb rebuild and getting ready for the rebuild I've been watching alot of videos on how to rebuild the carb, I've rebuilt carbs on quads,dirtbikes and other small engines but not a car
Old 07-31-2014, 09:35 PM   #75
FrankenCub
FrankenCub's Avatar
Sweet deal ! I use my trucks as trucks so a C30 would fit me well lol. I'd be feeling I stole it for that price here in upstate NY. Everything here is rotted beyond reasonable repair. I paid around $5300 for my '72 GMC 1500 and felt ok with it, even '02 Silverados here are crusher food so I jumped on my GMC without second thought. You done real good
FrankenCub is offline   Reply With Quote
