Old 09-08-2015, 11:24 AM   #51
bgood70
bgood70's Avatar
Re: LMC digital dash cluster????
Originally Posted by DUD2STUD View Post
Has any one had any problems with this unit. I installed mine and everything worked great for about a week then the speedo stopped working. I ran all new wires for everything. Now the speedo is pegged out and so is the fuel. The clock is no longer there either. All the other gauges tach, temp, oil and voltage work fine. I tried running a direct ground to the fuel and speedometer but nothing changes.
Not sure if you got this resolved? I just got mine installed, I am running a 700R4. Mine Speedo works great as do all my gauges. My only issue it my clock keeps resetting to 12:00. Need ot investigate more as it is hooked up to constant 12v. The clock seems to only need to 1 red wire hooked up and ground.
70 C-10 SWB 350/700r4 Good 70 SWB Build
72 GMC Sprint SP Custom 350/Turbo300
bgood70 is offline   Reply With Quote
Old 09-08-2015, 07:41 PM   #52
portworks
Um. I have had no issues with mine for 3000 mi.
Maybe you meant your reply for someone else ?
portworks is offline   Reply With Quote
Old 09-08-2015, 08:44 PM   #53
EARNHARDT#3
EARNHARDT#3's Avatar
I don't understand why anyone would want these gauges. Digital stuff in cars went out back in the late 80's early 90's.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-08-2015, 09:22 PM   #54
leftybass209
leftybass209's Avatar
To each their own. Part of the contributing factor to digital gauges being phased out was unreliable digital readings coupled with technicians that were rapidly being introduced to increasing electronic components and their associated faults.
leftybass209 is offline   Reply With Quote
