Old 08-11-2015, 03:44 PM   #51
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Forest's rebuild thread
Nice Re-Build!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 09-05-2015, 08:36 PM   #52
forestb
forestb's Avatar
Spent the last few Saturdays removing trailing arms and rearend. Finished stripping paint on the pumpkin and plan on painting it on Monday. I painted the trailing arms 2 weeks ago with por 15 and planning on doing the same to the pumpkin.
forestb is offline   Reply With Quote
Old 09-23-2015, 09:20 PM   #53
forestb
forestb's Avatar
Installed my freshly painted rear end and trailing arms. I would post a pic but there was no good angle. I spent a half hour sucking in exist fumes unfiltered through mufflers while trying to bleed my rear breaks only to run out of gass. It took me so long to try and bleed the breaks because for some reason the nipple is metric instead of standered.😧
Old 09-23-2015, 09:26 PM   #54
forestb
forestb's Avatar
Here is a photo of the rear end after I painted it.
Old 10-10-2015, 05:33 PM   #55
forestb
forestb's Avatar
Here's the rear end installed. I bled the breaks then my head started to feel like scrabbled eggs in the heat so I had to stop working. That's ok because that was the last thing that needs to be done before it goes off to body work and paint👍
Old 10-29-2015, 12:13 PM   #56
forestb
forestb's Avatar
Sent her off to paint and found out the colors that I was thinking of will be to expensive.
Old 10-29-2015, 12:14 PM   #57
forestb
forestb's Avatar
Old 10-29-2015, 02:08 PM   #58
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Paint!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-29-2015, 05:06 PM   #59
aggie91
I'm just glad to be here!
aggie91's Avatar
Great start. What colors did you decide on?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-29-2015, 07:56 PM   #60
forestb
forestb's Avatar
I don't know yet. I have a month before it is in primer so I think I will look through the swatches with the painter first. But I should have an idea before I do that. I am tearing my hear out about it though. I was going to go with a metallic green and white but that was going to be to expensive. It is hard when you have finally decided and then you can't do it.
Old 11-04-2015, 05:36 PM   #61
forestb
forestb's Avatar
Me thinks I found my color.
Old 11-04-2015, 05:37 PM   #62
forestb
forestb's Avatar
Maybe
Old 11-04-2015, 09:23 PM   #63
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Make a good hunting rig.
Old 11-05-2015, 12:37 PM   #64
forestb
forestb's Avatar
Something like this was my other alternative.
Old 11-05-2015, 05:56 PM   #65
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I like the blue better to be honest. But whatever color you choose will look sweet.
Old 11-05-2015, 06:41 PM   #66
66 c20
I like the blue a lot better too, but that's my opinion. Blue and white looks timeless to me.
66 c20 is offline   Reply With Quote
Old 11-06-2015, 09:56 AM   #67
White knuckle Garage
White knuckle Garage's Avatar
just read through your thread looks awsome green is always my favorite color
White knuckle Garage is offline   Reply With Quote
Old 11-09-2015, 05:57 PM   #68
step65
Nice truck looking forward to seeing after paint.
step65 is offline   Reply With Quote
Old 11-14-2015, 11:37 PM   #69
forestb
forestb's Avatar
I tried installing my steel ruber gaskets on my vent window saround on my 62 and they were a pain and did not fit varry well in the corners. I had to do a lot of training and am now worried they will leak.
I am not sure yet but I do not think they salve the gap problem between the gasket and the door. So far I am disappointed.
Old 11-15-2015, 12:02 AM   #70
forestb
forestb's Avatar
Still going through the wows of paint color decisions. The green I posted earlier is not exactly the coler that I was thinking of. The fist 2 photos are more of what I was thinking of. The rendering is to show which parts I would make white. The blue I like also. The only problem is the painter that I am using has no experience with semigloss paint and he kind of grumbled about the idea.
Old 11-15-2015, 06:02 PM   #71
62stepside longbox
62stepside longbox's Avatar
Some great colors. May I suggest something like this?
Plymouth prowler orange pearl.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 11-15-2015, 06:16 PM   #72
forestb
forestb's Avatar
I can't really afford a pearl color and I don't want to go too fancy since it will be kept outside.
Old 11-19-2015, 05:41 PM   #73
forestb
forestb's Avatar
Just got a photo of my steering wheel after being freshly polished.
Old 11-20-2015, 12:28 PM   #74
62stepside longbox
Lookin good. Have you made a decision on the color yet?
Old 11-20-2015, 01:11 PM   #75
forestb
forestb's Avatar
No it is so hard to decide
I have almost given up on the green. It is just to bright. I was wavering between a glossy version of the mat blue truck posted above and maybe a gold. I like gold because it is more hot rody but the problem is it would be a non metallic gold which I don't know about. The blue I like because it seems like a throw back to cars of the 30's and 40's but I don't know if it will have that feeling on my truck and it definitely will not have the hot rod feeling I am looking for. At the same time I can't stop going back to the turquoise color that I posted earlier. The only problem with that is it almost seems to predictable.
