Old 04-19-2014, 10:04 PM   #51
First c10
First c10's Avatar
Re: New LS swap/install questions
Here is a picture of where the MAF is. The code is MAF and intake air. Sorry I didn't take a picture of that.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-19-2014, 10:24 PM   #52
First c10
First c10's Avatar
Ok so I reset the computer and cleaned the MAF. Ran it without the MAF connected ran smooth. So I hooked up the MAF and he didn't change. So I checked the scan tool and this is what I got.
So was it just a learn that the computer needed? Or combination of cleaning and learn?
GO GO!!!
Old 04-19-2014, 10:44 PM   #53
First c10
First c10's Avatar
Ok so I took it for a short drive and stopped at the gas station for fuel and started it up was running a little run check engine light came on and this was the code.
GO GO!!!
Old 04-19-2014, 11:02 PM   #54
First c10
First c10's Avatar
As I play with this more I start seeing things. What should the MAF read on the scan tool in (LB/S)?
GO GO!!!
Old 04-20-2014, 01:04 AM   #55
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The VSS code is gonna play into that "lock/unlock" feeling you mentioned earlier. Normally I would say to check the VSS wiring, but afaik the 6l80e doesn't use a regular external VSS...so I'm not sure what can cause that code.
Is there a gasket used where the MAF plugs in/ do you have it?
Put a zip tie on that little vacuum nipple, they can suck past. I used a random plug once that wasn't heat resistant and it melted a hole in it.
Your STFT looks alright, but the LTFT's both are high (and what about 3 and 4?). It still has a little bit of the vibe of air leaking past somewhere.
Have you tried the starting fluid/carb cleaner method of leak detection?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-20-2014, 10:33 AM   #56
First c10
First c10's Avatar
I figured that the vss code may be from the lock issue. Thanks
The MAF has a red silicone oring it looks to be ok and fits snugly.
After all the reading I had done. Doesnt the LTFT's adjust to make the STFT's 0? So maybe I haven't let it run long enough to get the LTFT to adjust?
I will be checking the carb cleaner method just have to get some when I get a new MAF.
On the scan tool the MAF always reads like .01 or .02 lbs/s shouldn't that be higher? In my mind if the MAF is reading basicly 0 than the computers would lean out right?
GO GO!!!
Old 04-20-2014, 01:20 PM   #57
First c10
First c10's Avatar
Ok so I was reading .01lbs/s which translates to 8.6 g/s. Is that what everyone else has at idle for MAF reading?
GO GO!!!
Old 04-20-2014, 02:20 PM   #58
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
How big of a change in the MAF reading at 2k rpm? Is it going up to like 11, or way more/less?
Old 04-20-2014, 04:14 PM   #59
First c10
First c10's Avatar
At 2000rpm it is at .02 lbs/s
GO GO!!!
Old 04-20-2014, 04:17 PM   #60
First c10
First c10's Avatar
I sprayed carb cleaner round the intake and didn't really see or feel a difference.I sprayed under the TB and the scan tool read StFT's dropped for a second but than I couldn't get it to do it again.
GO GO!!!
Old 04-21-2014, 12:26 PM   #61
First c10
First c10's Avatar
ok so yesterday I took the truck for a longer drive put on about 25 miles. tried it with the MAF connected and disconnected. When the MAF was connected the trans shifted funny (up shifted and down shifted) on normal acceleration and the motor didnt run very well.(stumbled coughed etc). so I disconnected the MAF and the motor idled great about 630 rpm and the trans shifted like a new car, nice and smooth....
this MAF or leak or problem whatever you call it is making me mad..... should I just remove the intake and check for leaks?
GO GO!!!
Old 04-21-2014, 01:44 PM   #62
Houston Ben
Houston Ben's Avatar
I had a leak on mine and it threw a code, is your MAF new?
Houston Ben is offline   Reply With Quote
Old 04-21-2014, 01:45 PM   #63
First c10
First c10's Avatar
Yes it's brand-new. Where was your leak at?
GO GO!!!
Old 04-21-2014, 02:05 PM   #64
Houston Ben
I used the original intake and cut it up. I tried to seal with silicon but it didn't work to well so I used fiberglass. Sorry, but that is probably not going to help you on yours but it was a small leak and threw a code. Also, leak was after MAF sensor.
Old 04-21-2014, 03:26 PM   #65
First c10
First c10's Avatar
Wow you cut it up? Ok cool I will try some staring fluid. If not I am going to remove it and check the intake.
GO GO!!!
Old 04-21-2014, 07:29 PM   #66
68c10airstream
68c10airstream's Avatar
First c10, go to "motor.com" and click on magazine articles. Find july 2006, article "successful maf diagnosis" by Sam Bell. Once you are at the actual article, warm up your printer and click on download pdf and print and save this info. Its top notch, it talks about theory of ops, fuel trim, lab scope readings etc. Motor.com articles will take you to the front seat of the bus. You will need to look at each month and click on each article highlight sometimes to get the full jist of what the article is about. I'm probably repeating myself but take an evening with your pc and print every and all articles of interest and if you need to take your vehicle to a repair place and you hand them these articles i bet it would be of help, as there is too much to remember. Some of these articles are obviously sourced from the oem's so it doesn't get any better. I have a thick book of many motor articles and that is my bible, along with my fluke meter and my autoenginuity software for diagnostics. I can labscope trace 4 channels at once live and look for glitches, etc, on my laptop going down the road. Good luck, Brian Fuller
68c10airstream is offline   Reply With Quote
Old 04-21-2014, 08:09 PM   #67
littlevictories
that vss code is a bummer.
littlevictories is offline   Reply With Quote
Old 04-21-2014, 08:16 PM   #68
First c10
First c10's Avatar
Thanks 68 I will check that out.
Litlvic I cleared that code and haven't seen that code again.
I think it was the horrible running of the motor and maybe the brake TC lock up thing.
GO GO!!!
Old 04-22-2014, 04:54 PM   #69
First c10
First c10's Avatar
Man. I took some time to get the a/c charged and installing the heater shutoff valve. So I took off the air filter. After I installed the heater control valve I started the motor without an air filter and the MAF connected.if sounded like it was running pretty good not like before. So I hooked up the scan tool and the stft's were like 6 and the LTFT's were like -4-8. So I let it run for a little bit. Then stuck the air filter back on. And as soon as I did te motor almost died. Stumbled and then went way rich. Running like crap. Stfts 29.7 and LTFT's 69. Took off air cleaner and went back to normal. Has anyone experienced that? Could it be the angle of the air filter to MAF?
GO GO!!!
Old 04-22-2014, 06:00 PM   #70
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Question; did the o.e. intake have a special tube section that mated to the MAF, that the aftermarket intake didn't keep? The reason I ask, is a friend and I sat down and noticed the aftermarket parts from JET etc for the 9,10,11 trucks have a small metering tube that mounts under the MAF, getting it an air channel to sample. Without this, I imagine its reading un-metered turbulent air, which would cause erratic problems.
or
Move the MAF further up the intake path, instead of directly behind the filter. Sounds like the filter is scrambling air flow and confusing the hell out of the MAF. Some can get away with that (screen style), but its technically not ideal, as the MAF doesn't have room to read straight air.
Old 04-22-2014, 06:22 PM   #71
siggyfreud
siggyfreud's Avatar
Can you access a second MAF to try? My experience was from the TPI era, but we faced similar issues on a 85 Vette and it was simply a bunk MAF (that was new).
siggyfreud is offline   Reply With Quote
Old 04-22-2014, 06:28 PM   #72
First c10
First c10's Avatar
Well that makes sense if there is a channel or groove that forces air to pass the MAF. I have a 2013 at work with the same motor I will take a look at the air cleaner into and see what it has. I wonder if all the blade drop in type MAFs have this tube or channel.
GO GO!!!
Old 04-22-2014, 10:26 PM   #73
First c10
First c10's Avatar
Does this look right? Can anyone look at there MAF installed in the tube?
GO GO!!!
Old 04-23-2014, 12:15 AM   #74
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This might make things more confusing but:
I started seeing things like this listed for 2011
Then after that, I saw an image of a similar style sensor, but they added the screen? (google said 2011, i don't know for a fact if it is)
I'm not sure how exactly the 2011's MAF was configured, but the thing that I see in common, is that one way or the other, something is straightening out the air to give it a smooth sample, instead of turbulent air.
Old 04-23-2014, 12:51 AM   #75
First c10
First c10's Avatar
Well looking at the last picture you posted my maf may not be low enough especially since the aluminum tube is 4" and not 3"like the stock one. I may just cut the tube and tig weld it lower in the tube.
GO GO!!!
