Old 05-17-2014, 11:20 AM   #51
ls1nova71
ls1nova71's Avatar
Re: Checking for spark?
Originally Posted by smartass12 View Post
Cuz im in panic mode! Always empties my pockets lol
Dude, SLOW DOWN!!! I understand your impatience, but throwing money at a problem is only for people with more cash than sense. Did you try the starting fluid again? I'm guessing no? If you're going to buy stuff, I would have bought a set of noid lights and checked for injector pulse, but that's in the past now. You could still buy a spark tester or just check it the old fashion way by putting a screwdriver in the boot and holding it close to bare metal on the block. I'm not sure the old plug method you used is the best way. If you still get no spark, and your power and grounds are good, it most likely going to be a crank sensor issue, either the sensor or mosf likely the wiring from it. Know anyone with a good scanner or tuning software you can use to see if the PCM is seeing RPM during cranking? Also, are you absolutley sure you're not loosing power while cranking? Some circuits are hot in 'run' but not during 'crank'. To test this, turn the ignition on, and then jump the solenoid at the starter. MAKE SURE THE TRUCK IS IN PARK AND CANT MOVE SHOULD IT START.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-20-2014, 09:34 AM   #52
smartass12
smartass12's Avatar
so i was in the middle of emailing bill@bp to buy a harness (which still might do cuz of how clean they look) and a huge light bulb went off in my head. dont know how i over looked this as long as i did being that i have messing with the fuse block as much as i have. i remembered i used 2 of the unused powers off the block to feed my harness, ran out to the truck and sure as s#@% the two extras didnt ship with fuses in there slots....2 fuses later.....ITS ALIVE!!!!!!!!! seems to run smooth and idle well....throws no codes as of now...
yes im an idiot for not catching this earlier but want to thank everyone that stuck in there with me and helped out...im sure more help will be need soon. I did upload a startup video to my photobucket but its not there..ill post as soon as i can figure that out
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 05-20-2014, 09:50 AM   #53
smartass12
smartass12's Avatar
Old 05-20-2014, 09:52 AM   #54
smartass12
smartass12's Avatar
https://www.youtube.com/watch?v=QaXB1z3o-X4
Old 05-20-2014, 12:30 PM   #55
Custom 68
Custom 68's Avatar
I am glad you got it going.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-20-2014, 01:34 PM   #56
siggyfreud
siggyfreud's Avatar
Nice that it turned out to be something rather simple . The first time I did an injection system I had it die on the road about 5 miles after getting it going. I tore through that think looking at sensor after sensor, and it turned out that the fuel pump fuse simply had blown because I reused a small one on the fly to get it going rather than sizing appropriately.
It happens, just add it to your book of knowledge .
siggyfreud is offline   Reply With Quote
Old 05-20-2014, 07:09 PM   #57
ivorton74
ivorton74's Avatar
congrats man..ur truck looks bada** too
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 05-21-2014, 07:40 AM   #58
smartass12
smartass12's Avatar
thanks
