Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 07-04-2015, 07:45 AM   #51
engairuph
Re: 6 Lug Rear Disc with 15" Wheels and an E-Brake
I'll take a set and just found you do brackets for the six lug disc brakes for the rear using 15" tires and would like a set also.
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 07-04-2015, 10:59 PM   #52
Captainfab
60-66 Nut
Do you want 2 sets of rear disc brackets, or just one?
Old 07-05-2015, 07:12 AM   #53
engairuph
Just one set.
Ralph L. Jasper
13 GMC Ext cab
MAI
Interior shop
Old 07-08-2015, 09:01 AM   #54
Dale_Brown
CapitanFab -- Installing in the next few weeks Are these the calipers you recommended in your previous post?
http://www.ebay.com/itm/GM-Metric-Re...#ht_4099wt_859
Dale_Brown is offline   Reply With Quote
Old 07-08-2015, 10:47 AM   #55
TypeSL2
Those look identical to the ones I put on my truck using this kit. I don't know that company, so it may be a cheap chinese knockoff. They may be great quality. The ones I ordered were actually not assembled properly, so I kept blowing out the seal in the right rear. It was missing a copper washer inside the caliper.
James
TypeSL2 is offline   Reply With Quote
Old 07-09-2015, 12:02 AM   #56
Captainfab
60-66 Nut
Those appear to be the correct calipers. You might contact them prior to purchasing and inquire about the country of origin and or warranties.
Old 09-01-2015, 02:58 AM   #57
jonesky2
jonesky2's Avatar
wanting a set of brackets powder coated. Has anyone actually finished the conversion? any input/response? I would prefer disc/disc valve so I dont have to worry about adjusting the pressure and having my rear tires stop sooner or slower than the front... does anyone have a disc/disc valve that was basically plug and play for our trucks?
jonesky2 is offline   Reply With Quote
Old 09-01-2015, 11:51 PM   #58
Captainfab
60-66 Nut
I'll send you a PM with ordering info.
If you don't get a response here regarding the proportioning valve, you might try the for sale threads for the other 4 rear disc brackets that I make.
EDIT: I tried to send you a PM but your inbox is full.
Old 08-08-2016, 01:01 AM   #59
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
Old 08-09-2016, 12:30 PM   #60
bigbuc
Certified Pud Puller
bigbuc's Avatar
I would like a set
1997 Silverado extended cab- mpfi conversion, 22" kmc's
1983 C10- some assembly required
99.5 F250 Super Duty 7.3 5" straight pipe, wicked wheel, ts tuner, ccv mod, 4" lift 315/75/16s
bigbuc is offline   Reply With Quote
Old 08-27-2017, 02:30 PM   #61
shume
This is the setup I am looking for.
Send payment amount to shume@gotgear.com for PayPal
Would like setup powered coated
shume is offline   Reply With Quote
Old 08-27-2017, 11:26 PM   #62
Captainfab
60-66 Nut
I replied to your PM from earlier today.
Old 01-10-2018, 01:11 AM   #63
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
Old 01-16-2018, 09:47 AM   #64
Lennart
In your first post you mention that 3rd gen F-body calipers will also work. Which ones are those? The 1985 -1992 ones like ACDELCO 18FR972 ?
Lennart is offline   Reply With Quote
Old 01-17-2018, 12:12 AM   #65
Captainfab
60-66 Nut
The 1985-92 F-Bodies are the third Gen, and the 18FR972 is what comes up when searching for those rear calipers, but the picture is not correct. The picture looks like the '93-'97 F-body rear calipers. I will have to do some more searching and get back to you.
Old 01-17-2018, 05:06 AM   #66
Lennart
OK, in that case it is probably the caliper ACDELCO 18FR790 used from 1982-88.
Old 01-18-2018, 12:13 AM   #67
Captainfab
60-66 Nut
Yes that is the correct caliper.
Old 03-21-2018, 10:09 PM   #68
TheBrewery
TheBrewery's Avatar
Would these work on a 1960? or could they be modified to work? I think I need to get rid of my rear drums...
Mike
1960 C10 Short Step 235 w/ 3 on the tree
1999 Mazda Miata <- Track Car
2016 Chevrolet Colorado z71
2016 Chevrolet Traverse - Wifes Car
2014 Honda CBR500R <- Also A Dust Collector
2009 Suzuki GSXR600 <- Stolen
TheBrewery is offline   Reply With Quote
Old 03-21-2018, 10:55 PM   #69
Captainfab
60-66 Nut
None of my rear disc brackets are a direct bolt on to the Eaton HO32/33 differential. I imagine they could be made to work if you want to spend the time and money to do so. Personally if you want rear disc brakes I would replace the Eaton with a '64-'82 truck 12 bolt with a better gear ratio and then add your rear disc brakes.
Old 03-21-2018, 11:08 PM   #70
TheBrewery
TheBrewery's Avatar
I guess I don't understand how they attach, Is it just modifying the mounting or is the axle whats going to cause the issue?
Mike
Old 03-22-2018, 10:59 PM   #71
Captainfab
60-66 Nut
All of my rear disc conversion brackets attach using the original backing plate flange. The Eaton HO32/33 has a different flange that the truck 12 bolt. Plus I do not know of the brake offset is the same. If they are not the same offset, the caliper will not line up with the rotor.
Old 04-11-2018, 02:51 PM   #72
TheBrewery
TheBrewery's Avatar
I picked up a 12 bolt out of a 70 Chevelle, would this kit fit? I am special ordering the axles and will have the flange cut down.
Mike
Old 04-11-2018, 03:58 PM   #73
Killer Bee
Killer Bee's Avatar
I'm not even going to pretend that I can answer your question..
however I was just reading this recently and it may be useful to you..
good luck!
12 bolt truck rear end vs 12 bolt car
Old 04-11-2018, 11:57 PM   #74
Captainfab
60-66 Nut
The car 12 bolt has a different backing plate flange shape size and hole pattern than the truck/Impala backing plate flange. I do happen to have a couple car 12 bolt base plates that I could substitute. So you are having axles made for a car 12 bolt with the 6 x 5.5" wheel stud pattern? I would think that a '70 Chevelle 12 bolt would bring a premium price.
Are you going to need a set of trailing arm mounts also?
Old 04-12-2018, 10:14 AM   #75
TheBrewery
TheBrewery's Avatar
Yes, I am having Moser make a pair of somewhat custom axles for it.
I am halfway thru removing the Chevelle mounts and will absolutely need a trailing arm mounts.
I picked it up a Super Chevy for $600, it's open with 2.73? gears. I think it's a good deal.
Mike
