11-02-2018, 07:16 PM | #51 |
Re: 68 Anniversary Gold LWB C-20 to SWB C-10
Back up and running.
Eric 68 Anniversary Gold C-20 LWB to C-10 SWB build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=637492 It's hard to explain puns to kleptomaniacs because they always take things literally. |
02-08-2019, 05:35 PM | #52 |
Gave her a bath and polish for the first time in a few years.
02-24-2019, 11:03 AM | #53 |
Now that you don’t have to deal with CA DMV are you gonna do a frame swap? What ever happened to that short 2wd frame at the wrecking yard?
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
02-24-2019, 11:19 AM | #54 |
Hey there Andrew. I’m not sure if I will frame swap or cut it. I might do a rear clip like your Dad did on the green truck. I don’t plan on bagging it but would like a fairly low static drop that doesn’t hit the frame when you hit bumps in the road. For now I’m just going to try to preserve it a little. The seam sealer on the cab is gone so water and leaves got in and s tarted to get the toe kick area and the interior roof skin above the windshield. I’m so glad to have it home and out of the weather. If I hadn’t done that, I would have a MUCH bigger project.
02-08-2022, 08:13 PM | #55 |
Picked up a 72 C-10 frame for the front suspension and disc brakes from another board member. Thanks Uncle. Can’t wait to convert to 1/2 ton and disc brakes.
02-09-2022, 10:32 AM | #56 |
I am putting a 72 frame/chassis under my 67. I won't have problems some do in other states with registration. In Fact I already have it registered........
02-11-2022, 05:37 PM | #57 | |
Then, when the time comes, swap the 67 body over to the refurbished chassis. Sheet metal can be swapped over in hours if you have a good crew for the help (or days if it's just one or two). Allows you to get things completely done chassis wise vs. having to take the assembled truck apart for the work.
02-11-2022, 05:51 PM | #58 | |
02-11-2022, 07:18 PM | #59 | |
