12-07-2014, 09:43 PM | #51 |
Re: Serp system advice
Well, after a couple times of putting things on just to take them back off, I am finally making some headway. I ended up removing the radiator, this helped enormously. I still have to reinstall the power steering pulley. The next hurdle appears to be the upper radiator hose. The current one hits the alternator. Anyone got any suggestions on fixing that problem?
12-07-2014, 10:10 PM | #52 | |
Radiator hose for a 92 C1500 maybe if the radiator nipples are the same size. Or a flex hose maybe. Yeah, they are ugly but IMO the most durable hoses out there. You might be able to wrap it and put those fancy ends on it. Amazon.com: Heatshield Products 240003... Ends example: http://www.ebay.com/itm/Chrome-Alumi...73f9f5&vxp=mtr |
12-07-2014, 11:06 PM | #53 |
Your almost there, good job. I used a swivel type thermostat housing, stock 1972 upper hose. Rotate the housing slightly clockwise, just enough so that the hose clears the belt.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-07-2014, 11:20 PM | #54 |
My power steering pump did not have a hole in the pulley for the bolts. I also cut the fan shroud down and it appears to be enough clearance. I won't know for sure until I get the pulley back on. Thanks guys
12-08-2014, 12:23 AM | #55 |
Thanks Lee. I think you had told me once before in a pm and had forgotten. I ordered a swivel housing, hopefully it will be here by the end of the week.
12-12-2014, 06:00 PM | #56 |
I ordered the alternator connector part ec80 and it doesn't fit. I thought it was the correct one from reading on another thread. Can anyone tell me the correct adapter for this plug? Thanks
12-12-2014, 06:47 PM | #57 |
I used NAPA EC82.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 12-12-2014 at 06:58 PM. |
12-12-2014, 06:48 PM | #58 | |
http://www.ebay.com/itm/88-92-TPI-TB...-/360460065008 |
12-13-2014, 12:03 AM | #59 |
I got the male part right, it is the female part that are wrong. They all look like this, but I need them to be vertical.
12-13-2014, 01:32 AM | #60 |
I thought you were trying to put a 92 alternator on a 70ish chevy pickup. I'm confused so I'll stop guessing I'm sure someone knows on this forum. Vette Vett seems like the guru here on alternator wiring.
12-13-2014, 01:43 AM | #61 |
I am trying to put the alternator from a 92 on a 70 chevy. I rewired the entire truck a few years back and that is the plug that is going into the alternator on my 70 truck. Apparently, it is a 10d plug. So, I would need a 10d plug to a cs130 adapter. Haven't found one yet
12-13-2014, 02:02 AM | #62 | |
M&H part # 37787 even comes with external regulator plug. Give them a call or shoot them an e-mail to give the particulars of you truck. Scroll down to page 3. http://www.wiringharness.com/PDFS/TR...hevy_Truck.pdf |
12-13-2014, 10:10 AM | #63 |
So you need the plug shown in post 59?
12-13-2014, 11:24 AM | #64 |
12-13-2014, 11:34 AM | #65 | |
12-13-2014, 12:08 PM | #66 |
Got it. The adaptor I mentioned is for the type of plug you pictured in post 59.
12-13-2014, 05:45 PM | #67 |
I saw on the forum, where one guy used a 330 ohm 1/2 watt resistor, so I just picked up a pack from radio shack. I am going to go home and wire it in. I have one more stupid question to ask. I have on my original alternator harness a, blue and white wire. Which one does the wire with the resistor attach to?
12-14-2014, 02:47 PM | #68 | |
Msgt USAF Ret
Here's the diagrams I promised you in the PM. This is the original factory wiring. This is the jumpered conversion at the EVR plug, it is for the SI alternator but the wiring is the same for the CS except pin 1 becomes the L pin and pin 2 becomes the S pin. This is the clean way to do it and eliminate the external voltage regulator harness. Don't forget the resistor.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-14-2014, 06:16 PM | #69 |
12-14-2014, 06:27 PM | #70 | |
I just replaced the pigtail, cut out the old harness and used bare metal butt connectors with heat shrink covering to connect the wires. Some cheap plastic "snake skin" and it looks like new and less resistance eliminating extra spade connectors. |
12-14-2014, 09:39 PM | #71 | |
Chevrolet Performance 12497697 - Chevrolet Performance Small Block Serpentine Belt Drive Systems. Available from Jegs and others. |
12-14-2014, 10:59 PM | #72 |
Msgt USAF Ret
the resistor prevents the exciter voltage from burning up the diodes and transistors in the regulator and the diode trio in the alternator. The alternator also backfeeds voltage to the ignition switch to activate the charging light if the alternator voltage output drops below battery voltage, or if the alternator voltage exceeds the battery voltage by more than 3 volts.
It also prevents this backfeed voltage from powering the ignition circuit when the key is shut off and prevents engine run on after the key is shut off.
12-16-2014, 03:10 PM | #73 |
I just bought Serp brackets off a 89-95 1500. I like my current V-belts but I HATE the squeal when I get on it, so this is my winter project.
I have 2 questions... Can someone measure their reverse flow water pump from block to fan flange? I want to compare with my current short pump in order to figure out if, or how much, I need to trim the stock fan shroud. I rewired with the Painless kit using a one wire alternator. Can I just order a one wire alternator for a 89-95 truck from Summit and avoid any rewiring? Thanks CST350 |
12-16-2014, 04:26 PM | #74 | |
12-16-2014, 04:43 PM | #75 |
I called flex-a-lite and told them my shroud opening was 19". They recomended a 17" reverse direction fan (PN 591740)
It has a 3 1/4 bolt circle so it should bolt to the clutch that came off the serp system. |
