Old 12-02-2014, 07:43 PM   #51
ol_skool_chevy
ol_skool_chevy's Avatar
Re: 65 SWB Porterbuilt Extreme Drop project
This might be a really stupid question but here goes. Is there a benefit to running the porterbuilt cross member with stock control arms?...will it set lower?
also do you Have to run rack pinion with these cross members?
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-10-2014, 02:36 PM   #52
creep
Registered Loser
creep's Avatar
With the stock arms you can still lay it out. I don't know if you need to cup the lowers to do it or if you can get away with plated arms. It may depend on tire diameter. I think the PB arms are for a narrower track in front and maybe better camber control, not to mention better looks.
Any reason you wouldn't want to run a rack and pinion?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 10-23-2016, 07:05 PM   #53
idreama300
What size tires are you running with those smoothies?
idreama300 is offline   Reply With Quote
