Old 12-28-2014, 01:05 PM   #51
400/400
Re: Minnesota Daily Driver
Also got the fire walled patched.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 12-28-2014, 01:08 PM   #52
400/400
Then the new tanks hangers, tanks, and sending units.
Old 12-28-2014, 01:11 PM   #53
400/400
Removed the windshield and rear window to find some more rust in the bottom of the windshield channel.
Old 12-28-2014, 01:14 PM   #54
400/400
Windshield channel was patched.
Old 12-28-2014, 02:25 PM   #55
MTCK
MTCK's Avatar
Nice work! I'm excited because I see we have 10+ months of updates coming based on the date stamped photos. :-)
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 01-19-2015, 07:37 PM   #56
400/400
Thanks. I do have a lot more progress to post. I got a lot done on it last year. It's a continual process, I keep finding things to do on it.
A couple of weekends ago I tore down the steering column to replace the wiper and multi function switch. While I was in there I also replaced the turn signal switch as preventative maintenance.
Also installed a stereo over the last couple weeks. So I'll have some pics to post of that.
Old 01-19-2015, 09:49 PM   #57
77K10Silverado
77K10Silverado's Avatar
Looking good! Love the high boy look!
77K10Silverado is offline   Reply With Quote
Old 01-23-2015, 05:50 PM   #58
400/400
Thanks!
Old 03-02-2015, 09:27 PM   #59
400/400
The truck's been serving me well as a daily driver. It had been getting into the 20's & 30's below over the last few months and she ran well.
Also time to continue the story:
After getting the windshield channel repaired I hung the doors to see how they lined up with the repaired rockers and cab corners.
Old 03-02-2015, 09:30 PM   #60
400/400
I was happy with how they turned out and started on painting the firewall.
Old 03-02-2015, 09:33 PM   #61
400/400
Also, I had chiseled out the dry seam sealer from the cowl and re sealed it. The cowl was painted with the firewall.
Old 03-02-2015, 09:40 PM   #62
400/400
Previously I had mentioned adding a stereo around Christmas. I made a board to mount the sub and amp on and got it in behind the seat. There were also 6x9's powered off the amp installed in the original locations behind the seat.
Old 03-02-2015, 09:44 PM   #63
400/400
Also got my mud flaps installed around that time. They do a good job of keeping the winter slop off the truck.
Old 03-02-2015, 09:46 PM   #64
400/400
Then it was time to haul some lumber. The truck rides pretty well with 600 + pounds in the bed.
Old 03-03-2015, 12:00 AM   #65
y5mgisi
Second Chance Program
y5mgisi's Avatar
Thanks for the continuation!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-03-2015, 08:18 PM   #66
400/400
It's been a couple months since I posted about the build. Here's some more....
Once I got the cowl painted, it was time to set the box on the frame. It had been stored upside down so I could paint the under side so the 1st step was to get it vertical.
Old 06-03-2015, 08:24 PM   #67
400/400
Then came the fun part, getting back down without damaging the lower bed sides. With some carful use of wood blocks we were able to get it down. I was fortunate to be able to borrow a bobcat to set the bed back on the truck.
Old 06-03-2015, 08:33 PM   #68
400/400
I also found a couple more pics that show what I started with, as far as the rust went on the rockers.
Old 08-30-2015, 05:09 PM   #69
400/400
Been a few months since I posted on the build. I've been driving the truck daily for about a year with a bit over 10,000 miles on the rebuild.
I decided to go to an electric choke vs the divorced choke. So I rebuilt the carb that was original to the truck.
Old 08-30-2015, 05:12 PM   #70
400/400
I also found this pic of the 1st time the bed was put on the truck.
Old 08-30-2015, 05:47 PM   #71
Zane M
Amazing work. Thank you for sharing.
Zane M is offline   Reply With Quote
Old 08-31-2015, 03:09 AM   #72
MTCK
MTCK's Avatar
Looks awesome. Glad you have been racking up the miles.
-Marcus
Project Plow Truck
Old 09-02-2015, 06:05 PM   #73
400/400
Thanks!
Old 09-02-2015, 06:07 PM   #74
400/400
Thanks. It's been a fun vehicle. A lot of people like to stop and chat about it in parking lots.
Old 09-02-2015, 06:09 PM   #75
400/400
Made a bit more progress on the finishing touches today. Got the new AC components in and charged. Man it's nice having working AC.
