09-29-2018, 08:00 AM | #51 |
Re: 81 K30 Flat Bed
The GMT400 series C&C 14bolt will have the rear sway bar which should be easy to find.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
09-29-2018, 09:00 PM | #52 |
Re: 81 K30 Flat Bed
I bought this sway bar last summer.
It is 1.75 dia. and will require longer U bolts and a custom mount for the front because 2WD front spring hanger mounts are shorter than 4WD. I got the air bags as well. They are store bought Firestones with mounts modified to work on the C&C axle. Pretty big to compared to my Firestone 2071s. I just need to figure out some kind of rubber mount to slide around the bar with a bracket/mount to attach a vertical front sway bar mount like the 3/4-1tons have. See pics.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
07-18-2019, 11:00 PM | #53 |
Re: 81 K30 Flat Bed
Working on the donor truck.
07-19-2019, 01:17 AM | #54 |
Re: 81 K30 Flat Bed
Cool what’s it donating?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
07-21-2019, 01:34 AM | #55 |
Re: 81 K30 Flat Bed
87 Silverado cab and clip. AC, PW, tilt, solid, straight, no rust. I want to paint it
with new front and rear glass and gaskets. I have new door glass rubber to install as well after the paint. At this rate it could be 2022.
