Closed Thread
Old 10-12-2014, 06:56 PM   #51
endlessearth
endlessearth's Avatar
Re: What did you do to your truck today part III
My wife surprised me for my birthday this year and she worked with local hot rod builder and louver specialist Chip Quinn to have him put a sweet Vintage Air A/C unit into my '64. It was a six week job and it required the concoction of many, many excuses to as where my truck had gone. Chip did a great job as usual making the unit look very tight and trick attached to the 355 under the hood. Just the compressor tensioner alone is a beautiful and well thought out piece. I am very happy with the build and even more happy that I scored such an amazing and thoughtful wife. Thank you Dayna. I love you.
endlessearth is offline
Old 10-12-2014, 06:59 PM   #52
pimpston65
pimpston65's Avatar
you been overhauled!!!
pimpston65 is offline
Old 10-12-2014, 07:00 PM   #53
endlessearth
LOL! Yes, I guess I have. Feels awesome.
Old 10-13-2014, 07:43 PM   #54
LVPhotos
LVPhotos's Avatar
Overhaul installs headliners, might be a Monkey without one! Did you use a 2 or 3 rib lower pully for the Air/PS?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 10-14-2014, 03:20 PM   #55
endlessearth
Here is a response to your question direct from the builder:
Grant had said some one was asking about which crank pulley I used in this installation. That was a bit of an odyssey on this one. See, for some reason, this truck was equipped with a rudimentary batch of smog controls from the factory in '64.... I know that doesn't sound even reasonable, but every body that I have talked to about this and shown it to simply scratches their head and wonders, too. It was ALL factory, as well. But the lower pulleys that came on this truck were like no other Chevy stuff that I or any body had seen, and were slightly different off set than others that I had here. All had Chevy part numbers. So, long story short, I used the stock cast lower three grove pulley, but needed a to groove upper. I found what was supposed to match via a Chevy truck parts guy in California via E-bay, but when it arrived it matched the other "standard" Chevy short pump two groove pulleys I had around, which put it about 3/8" off from the lower.
I lucked out in finding a guy in far east Mesa that runs a small business parting these trucks, that didn't wrinkle his nose and tell me I was nuts as I told him what was up... And he just happened to have another "oddly" equipped '64 in.... with a two groove water pump pulley! All matched and was well.
I used a Vintage Air direct fit kit on this truck, and would recommend it to anybody, but I do have to mention that due to things such as the fresh air inlet hoses on Grant's truck, I did end up modifying lots of it.
About the biggest was the compressor mount. When we did the engine earlier this year, I noticed that the "Corvette" style 2 1/2" ram's horns that Speedway is reproducing had accessory mount on both sides as opposed to the standard's driver's side only. Taking advantage of this fact, instead of running the Vintage Air semi kinda ugly self supporting compressor bracket, I made up one that would utilize that Corvette ram's horn's mounts... Hard to see in photos, but it looks like it belongs there since the beginning of time.
Old 10-14-2014, 10:18 PM   #56
Turtleman
Turtleman's Avatar
A/C is on my list "To Do".. Looks like he did a great job...
Turtleman is offline
Old 10-15-2014, 01:05 AM   #57
endlessearth
[QUOTE=Turtleman;6879513]A/C is on my list "To Do".. Looks like he did a great job...[/QUOTE
Chip does quality work.
Old 10-15-2014, 08:10 PM   #58
jnovotny
Found a fuel tank at the salvage yard that was actually useable. Installed and fired up the engine. Pulled the master cylinder and am in the process of rebuilding it.
jnovotny is offline
Old 10-16-2014, 03:38 AM   #59
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 10-16-2014, 02:10 PM   #60
jnovotny
Thank you.
jnovotny is offline
Old 10-22-2014, 11:17 AM   #61
earl84
Replaced kick panel, large section of floor, and rocker panels on passenger side. Very time consuming, took better part of 2 days solid work. First time doing it, though, and I am a total noob with welding body panels. This was a great place to get experience, and I learned a lot about settings, gas flow, techniques, etc. Driver's side should go much faster. Then I can put in Peel and Seal, some closed cell foam, and my vinyl mat that Markeb01 used in his truck, and call my cab sort of done, haha. So much good information on this forum, love everything about it.
Sorry no pics, my camera lens on my phone is scratched horribly, and everyone has seen pics of this stuff before.
earl84 is offline
Old 10-26-2014, 04:53 PM   #62
schpeen
schpeen's Avatar
applied RainX to my windshield and removed the wiper arms and replaced with these bullets I found.
Also got an alignment done
schpeen is offline
Old 10-26-2014, 05:04 PM   #63
LVPhotos
LVPhotos's Avatar
So to cure detonation, I been adding 100 octane. Swapped in yellow spring for secondaries on my 670 Holley Street Avenger. The results are a nose up rear slip with wheel hunt for grip.
LVPhotos is offline
Old 10-27-2014, 09:50 AM   #64
endlessearth
Those bullets look cool!
Old 10-27-2014, 09:54 AM   #65
schpeen
schpeen's Avatar
I use RainX on the outside and RainX anti fog on the inside glass.
The old wipers barely worked anyway so I figured this was a way cooler way to go!
schpeen is offline
Old 10-27-2014, 09:57 AM   #66
schpeen
schpeen's Avatar
NAL-19301294
Crate Engine, Long Block, Assembled, 1-piece Main Seal, Aluminum Vortec Heads, Intake Manifold, Chevy, 350
(Mfr. #: 19301294)
New crate motor from Summit Racing should be here tomorrow!
schpeen is offline
Old 10-27-2014, 06:00 PM   #67
Blessed66
Blessed66's Avatar
Preparing to do some body stuff soon... hopefully.
Removed the bumper and headlamp rings/headlights. Discovered that my adjuster screw (female sides) are broken/old and appear to be having a hard time finding a good set of NOS replacement headlamp secondary mounts. Sigh. Might have to legitimately look into converting to a Chevy front end soon.
Don't mind the messy carport, please. I'm working on a lot of projects right now. Especially if my wife asks...
Oh, the next step is also taking off that beautiful white grille/headlight surround panel... As soon as I figure out how (3 bolts in the fender, yea?)
Current Projects:
1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion
1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently.
Blessed66 is offline
Old 10-27-2014, 06:39 PM   #68
SIR
SIR
SIR's Avatar
What size where those bullets?..
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline
Old 10-27-2014, 09:21 PM   #69
schpeen
schpeen's Avatar
classic industries
Product # C4041
CHROME WIPER BULLETS
MSRP $12.99 pr
Classic $10.99 pr
Add to Cart
Add to Wishlist
schpeen is offline
Old 10-27-2014, 09:36 PM   #70
schpeen
schpeen's Avatar
i took the rear fenders off and installed the felting came out great in my opinion. I hot glued it on to the fenders and then mounted them. Nice clean look.
schpeen is offline
Old 10-27-2014, 10:59 PM   #71
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Got Rocker Removed, Epoxed Sealed Body, 1 Gallon High a Build Prime, Let Dry in Sun and Block Away 2bbl Holly on Got Her Running After Sitting At Orignal Owners For like 9-10 Years. Picked up 2 new windshields
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline
Old 10-27-2014, 11:12 PM   #72
1971 GMC SHORTY
More
2002 FXDP
Old 10-30-2014, 05:11 AM   #73
schpeen
schpeen's Avatar
400hp in a box arrived!
schpeen is offline
Old 10-30-2014, 11:45 AM   #74
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
NO FAIR!!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 10-30-2014, 06:23 PM   #75
disasterbus
today I collected my first ever Chevy truck :-)
Went and collected a '64 step side I bought on ebay in the UK this week, haven't stopped grinning since!
disasterbus is offline
Closed Thread
