11-19-2014, 10:41 AM | #51 |
Boosted Member
Re: Improved Door Seals
I snagged some dakota door seals from the junkyard, and cut them down to work on my blazer. they're pretty decent.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-26-2015, 11:33 AM | #52 |
Has anyone here ever use the LMC brand door seals? if so how do they work compared to the other brands.
01-26-2015, 12:37 PM | #53 |
Im sure they was aftermarket junk seals.. they was sitting in the cab when I got the truck and I put them on... Me no like... I will try the Dakota ones when its gets that time.
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
01-26-2015, 03:07 PM | #54 |
I'm real happy with my Sofseals - but the whole sealant install is messy and a pain....
Weren't really that much. Bought from a vendor here if I recall
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-26-2015, 03:32 PM | #55 |
Great thread and very useful. It's interesting that Jeep CJs have similar problems and I always wondered what the corner vents on the hardtop with the TJs was for! Makes sense about pressure though. I always tell folks not to slam the doors as folks here are correct, puts a lot of stress on things-CJs are notorious for cracking inside right below the lower back corner of the wing windows.
01-26-2015, 04:13 PM | #56 |
Not sure if it's been mentioned at all, but has anyone tried rubbing in some armor all or some kind of oil into the precision seals to loosen them up a little? I'm sure someone out there has and I'm curious if that would help
Current project: 1972 Chevy c-10 350 (700r4 hopefully) - "Lola" 68 Oldsmobile Delta Custom 455 78 Z/28 Camaro - "Rocky" 89 Camaro RS 305 TBI DD - "Betsy" |
01-26-2015, 04:16 PM | #57 |
Moderator
Give it a try and see if it works
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-29-2015, 07:31 PM | #58 |
So what's the verdict on the seals? I'm gonna replace mine soon. Is it 50/50 on Dodge or factory Chev seals? Or is it just personal preference? Is one better than the other?
Thanks!!!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
01-29-2015, 08:03 PM | #59 |
So what I got from this what that the Dakota seals have metal in them and do not require the glue?
01-29-2015, 08:30 PM | #60 |
01-29-2015, 10:39 PM | #61 |
Ill give a set a try when its time.. thanks
01-30-2015, 05:14 PM | #62 |
I'm in. Dodge for me too.
01-30-2015, 05:33 PM | #63 |
Six in a row makes it go...
I bought the push-on ones. Original doors on original cab. They're tight. One door will close with a good amount of force, one won't.
Tried lubing them with glass cleaner, but it didn't do it. Lower front corner is the tight spot.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
01-30-2015, 05:42 PM | #64 |
I did read that you may need to "adjust" the lip it mounts to with a hammer. Adjusting inward to the inside of the cab because it is wider than OEM rubber... It takes a little work to get a good seal all the way around and still be able to close the doors nicely but they are better seals.
01-30-2015, 05:50 PM | #65 | |
01-30-2015, 07:42 PM | #66 | |
I had your issue. Painted, driver door would not shut. Lower bottom front was too tight after MANY adjustments. A rag and a crescent wrench was used to "tweak" the lip to widen the gap. Touched up and under the seal, no harm, no foul. Next time i know this, i will mock up my doors with seals installed before paint.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
01-30-2015, 09:17 PM | #67 |
Well even if the doors dont close it looks like a real nice paint job... Since its just the lip that needs adjusted any touch up or damage would be hidden under the seal when its re-installed... It would be worth doing.You could use a chunk of 2x4 and hit that with the hammer and it shouldnt chip the paint...
01-30-2015, 11:55 PM | #68 |
With the door on, it may be tough to get the right angle hitting it without slipping. I slipped the wrench over the lip with the door on and could get it precisely where I wanted.
01-31-2015, 12:52 AM | #69 |
Moderator
Wrench and a rag would be the way to go for bending the lip on a freshly pained truck. I used Dakota seals from a junkyard on my 68 and they work great. Nice and snug, but do not need to slam the doors. Can still close them with a firm push.
01-31-2015, 04:49 PM | #70 |
I called my wrecking yard and he said the'86 -'96 are different. Do you happen to know what year you bought? The year that worked for you.he said $20 each, sound right?
01-31-2015, 08:16 PM | #71 |
Roto Reuter thats the name...
Are these used Dakota seals hard to get off once the teeth grab in? I just wondered if I found a used set how easy they come off?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-31-2015, 08:25 PM | #72 |
Ditto... What year?
01-31-2015, 10:38 PM | #73 |
Moderator
86-96, easy to remove. I paid less than $10 for the pair.
02-01-2015, 01:06 PM | #74 |
02-01-2015, 10:34 PM | #75 |
