Old 02-08-2015, 12:32 AM   #51
NevEno
NevEno's Avatar
Re: 64 c10 build
Drivers side rocker done!!
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 02-08-2015, 08:31 AM   #52
sambrutay
sambrutay's Avatar
Re: 64 c10 build
@NevEno Nice radiator. Looks like the company I need for my GMC Sprint. Thanks for link
Bruce
1964 C10 SWB #Junk
1979 C10 utility #cargopants (sold)
1971 GMC Sprint (sold)
1974 GMC Grande Sierra (sold)
sambrutay is offline   Reply With Quote
Old 02-08-2015, 11:56 AM   #53
Dubnova
Re: 64 c10 build
NICE WORK!
Dubnova is offline   Reply With Quote
Old 02-08-2015, 12:20 PM   #54
NevEno
NevEno's Avatar
Re: 64 c10 build
Originally Posted by Dubnova View Post
NICE WORK!
Thanks.
I worked on the passenger side last night some too. The ps new rocker is awful. I kept my old one so I guess Im going to repair it. it fits like it supposed to.
Old 02-08-2015, 03:25 PM   #55
Mjminino
Re: 64 c10 build
Did you have any trouble lining up the door gap to the rockers? I am having a tough time. Is it possible to look at my build thread and let me know what you think?
Mjminino is offline   Reply With Quote
Old 02-08-2015, 04:54 PM   #56
NevEno
NevEno's Avatar
Re: 64 c10 build
My drivers side rocker fit ok with some modifications but in my opinion turned out awesome, it had a "triplus" sticker on it but the passengers had "counter part" sticker and let me tell you if you get one of these good luck.. I wasn't sure at first if I had messed up doing the floor, lower cowling or the apillar. I put my original one back on it fit perfectly. the counter part rocker I had to gap it out at the top/back it was twisted the lip was too short on the top I would have had to slice it all over to make it fit and stitch it back together..
Mjminino, it also looked like crap lined up with the door.. I've kinda looked at ur build but I'll have to check it out again.. It's hard to tell from pic's. I can just tell you what worked for me..
Old 02-11-2015, 09:09 AM   #57
Dubnova
Re: 64 c10 build
Originally Posted by NevEno View Post
It's made by Entropy its a LSX conversion radiator.
http://www.entropyrad.com/1963-1966-...-radiator.html
I used the entropy rad as well. It's all most to nice to cover up Very nice package with the fans and controller. I can't wait to get mine running.
Old 02-11-2015, 10:19 AM   #58
NevEno
NevEno's Avatar
Re: 64 c10 build
I’m not going to cover mine, I’m going to use the original side trim pieces as the radiator brackets.. little mod... I didn’t buy the controller.. Yet. more $$$. I haven’t decided. Did you get the programmable harness? How do you like it?
Old 02-11-2015, 12:35 PM   #59
4mulaSvaliant
4mulaSvaliant's Avatar
Re: 64 c10 build
Loving this build in just the three pages you have so far. I just had to pass on a set of transport wheels. Didnt have the cash, and wasnt sure of the fit anyhow. Now seeing them, Ill have my eyes open for the next set for sure!!!!
Are you running wheel spacers at all?
Are you running stock track width?
Does the front wheel rub as of the ride height you have in the pics?
Subscribed!
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 02-11-2015, 02:15 PM   #60
4shongo
Re: 64 c10 build
I have my eye on a set of those transport wheels myself. Can you share any insight on how you installed the clips (measurements, etc)? Tire size? I have 4 wheel drum brakes on my 66 C-10 Service truck, will I have to have the center hub enlarged? Let me know. Thanks
4shongo is offline   Reply With Quote
Old 02-11-2015, 03:00 PM   #61
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: 64 c10 build
This build is making me really like these trucks..Love the radiator in there!..The transport wheels look awesome with that rubber stretched on there..thought they were Mob Steel at first glance
Justin@EntropyRad is offline   Reply With Quote
Old 02-11-2015, 04:01 PM   #62
NevEno
NevEno's Avatar
Re: 64 c10 build
Subscribed!
The bolt pattern is correct, they will not bolt on stock drums because of the center bore of the wheel is too small. I did a disc brake conversion on the front and rear. The front works perfect center bore and all. off set seem good to.. The rear will need a spacer not only because of the center bore but the offset of the wheel. I haven’t put my bed on yet but I know it will hit the inside of the fenders just off measuring I think I’m going to have to use a 1 1/4" or 1 1/2" spacer on the rear. I’ll put the bed on this weekend.. once the rain quits
Thanks 4mulaSvaliant!!! above is off another thread I’ve posted on.. Mine is still in the build stage of course but I have taken some measurements with my bed on.. the front should be fine but I will run a 1 1/4" spacer on the rear.. I put a 1 1/2 space on there and the tires are too close to the fenders. About a finger.. My rear axle is out of a 1971 c10 witch is 2" wider than the 64 axle. The front is sitting a little high right now, it should go down a little once the truck is full assembled and the new springs are broke in. clearance seems ok
not sure the measurements that why I made a tool. I wanted a 28" tall tire so I used 255/30ZR22. The center bore on these wheels are smaller than your stock hubs.. I think someone on here had the center bore opened up to make it work with the drums
Thanks Justin i love that radiator too!! Hey I need to talk to you can you PM me
Old 02-11-2015, 10:51 PM   #63
Dubnova
Re: 64 c10 build
I have not got the truck running yet but, My buddy Jim has used a couple of the harnesses and he likes them a lot. The whole entropy "package" is very nice and fits like a glove. I dig it!
Old 02-11-2015, 11:02 PM   #64
NevEno
NevEno's Avatar
Re: 64 c10 build
I guess if I get one it will be the LSX series dual speed.. It's another $150.. How are you mounting your radiator?
Old 02-11-2015, 11:05 PM   #65
Dubnova
Re: 64 c10 build
We just used the factory mounts and kinda made them fit. We build new side plates and re worked the upper mount. I try to get some pics.
Old 02-11-2015, 11:26 PM   #66
NevEno
NevEno's Avatar
Re: 64 c10 build
Awesome thanks!! I thought about building some side brackets out of aluminum that use the fan holes and the core support holes!! Instead of modifying my original ones.
Old 02-11-2015, 11:36 PM   #67
NevEno
NevEno's Avatar
Re: 64 c10 build
I scored a used painted grille today. I'm looking to buy a painted/primed back bumper. Anybody buy bumpers from top banana?? It would be like $169 to my door.
http://www.topbananaparts.com/primed-rear-bumper-2.html
Old 02-12-2015, 06:45 AM   #68
Mjminino
Re: 64 c10 build
Top banana takes forrrrrever to ship and their customer service is like non existence,at least to get ahold of them.
Old 02-12-2015, 06:47 AM   #69
Bomp
Bomp's Avatar
Re: 64 c10 build
Nice looking grille
Bomp is offline   Reply With Quote
Old 02-12-2015, 08:30 AM   #70
Dubnova
Re: 64 c10 build
I don't know about top banana but, I like the painted bumpers. I think they look really clean.
Old 02-12-2015, 07:41 PM   #71
NevEno
NevEno's Avatar
Re: 64 c10 build
Originally Posted by Bomp View Post
Nice looking grille
Thanks Bomp! You guys know of any other companies that sell a rear painted/primed bumper? LMC use too have them but it's not on the site anymore. I have a nice chrome one but removing the chrome would be a nightmare.. I read a lot about top banana being hard to get a hold of. I may try to call them tomorrow and see what happens.
Old 02-15-2015, 04:11 PM   #72
cheessee
Re: 64 c10 build
got the frame painted hotrod black. installed the gas tank and set the motor in for a test fit..
What hot rod black did you use
1963 GMC swb sbw 5.3/4l60e porterbuilt
From middle Tennessee
60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details..
cheessee is offline   Reply With Quote
Old 02-17-2015, 03:41 PM   #73
NevEno
NevEno's Avatar
Re: 64 c10 build
Medallion
http://www.medallionrefinish.com/pro...sp?prodID=2075
Old 02-17-2015, 04:00 PM   #74
timmytimm3
Re: 64 c10 build
I've never had to call Top Banana but I got all my sheet metal from them and it shipped pretty quick. All decent quality stuff (for repops).
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 02-17-2015, 04:20 PM   #75
NevEno
NevEno's Avatar
Re: 64 c10 build
Rockers DONE! I worked on the bottom of the cab Saturday removing the old paint and undercoating with a wire wheel. I still need to sand it and hit some weld spots and it should be ready for new undercoating.
