02-20-2015, 04:30 PM | #51 |
Re: First LSx swap in progress
02-22-2015, 07:12 AM | #52 | |
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
02-22-2015, 11:27 AM | #53 | |
The Older Generation
I always shim mine out. There are some naysayers out there and I respect their opinions, but I have never had a problem doing this. I use solid spacers and not washers and move it out just so I can see a sliver of light between the box and frame, with washers & lock washers inside the frame. Make sure the spacers are the same diameter as the threaded bosses on the steering box. (I think 1 1/4 or 1 1/2 inch) If you have to get longer bolts make sure they are grade 8 bolts. I am not saying this is what you should do as that would be your call. If I was going to modify the frame I would cut the area out and weld in a curved piece of the same thickness, cut from a piece of pipe, or hand formed. The contour of the piece should match the shape of the steering box. Just my 2¢ worth. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-22-2015 at 11:42 AM. |
02-22-2015, 12:48 PM | #54 |
He means taking the fitting out of the back of your old pump and putting it in the new pump. However, this can only be done on a truck style pump, and not an F body type. You will need the F body hose to clear the pulley since it's in the way of where most hoses would want to come out of the pump. An easy way would be to get a newer power steering box that uses O ring fittings instead of double flare, I think around '81-'87 trucks. This is what I usually do, and it has the extra added benefit of being fewer turns lock to lock, which makes the truck drive (feel) a little more like a modern truck.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-22-2015, 05:54 PM | #55 | |
Thanks, I will check into that. LockDoc
02-23-2015, 10:06 AM | #56 |
Sorry to jam you up, Leon! Eric as usual did a much better job of saying what I meant. Just trying to help you dodge a bump in the road.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-23-2015, 12:14 PM | #57 | |
No problem Chip. The LS is giving me some unique challenges that I haven't had with the carb'ed engines. So far I'm enjoying the ride. It keeps my brain working... LockDoc
08-02-2015, 12:50 AM | #58 |
Been working on the panel off and on but I had to take a little break from it to put a new crate engine and NV4500 trans in a '72 C-30 I picked up.... http://67-72chevytrucks.com/vboard/s...52#post7206852 So I'm back on it again and I had a couple of wiring questions that the guys on here answered for me to get me back on track. I fired the engine up today. I had a small glitch that took me some time to figure out but it was really simple, I missed hooking up one ground wire. The only problem was it was the most important one. It was for the ECM, so everything was dead until I figured it out. It needs tuned and the VATS removed but the guy I bought the engine and trans off of agreed to come over and do that for me as part of the purchase deal. I called him this afternoon and told him I was ready for him to give me a hand on it whenever he had the time. He is going to let me know after he checks his schedule.... A couple of friends of mine are going to come over tomorrow and help me set the front clip back on it, then I can finish hooking everything back up. I can't wait to drive it. Thanks to everyone on here for the help. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-02-2015 at 01:00 AM. |
08-05-2015, 10:31 PM | #59 |
I went to the salvage yard yesterday and picked up a couple of things. Electric fan assembly, OBD2 port, misc bolts, clips, and assorted hardware. The electric fans are off of a 2002 Toyota Camry and they fit the '67-'72 radiator to a "T". We will see how they do on the cooling chores. They do seem to move a lot of air.... I also blasted and painted the auxiliary battery box and installed it. Tied up a bunch of loose ends and made a couple of brackets. Tomorrow I will get the fans wired, throttle cable hooked up, radiator hoses installed, and go over all of my work again to make sure I haven't forgotten anything. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-12-2017 at 11:32 PM. Reason: Changed electric fan donor vehicle. |
08-15-2015, 11:49 AM | #60 |
Awesome, Leon! Are you bringing it in September? Hope so!
08-15-2015, 11:55 PM | #61 |
I'm sure going to try to Chip. I'm having trouble getting the tune done. The guy that was going to do it must have fallen off the face of the earth. I talked to him on the 8th and haven't heard a word since. I need to get the tune done so I can take it to the muffler shop and take it to get the front end aligned.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-16-2015 at 10:23 AM. |
08-18-2015, 11:16 AM | #62 |
I am interested in those fans but have looked online and all I can find on 2002 jeep liberty fans is that they use only a single fan not duals? are you certain on the their origin?
08-18-2015, 02:52 PM | #63 |
digging this build!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
08-18-2015, 08:46 PM | #64 | |
I can't be 100% certain since they were in the back seat but I will be back at the salvage yard in a couple of days and I will double check on it. LockDoc
08-18-2015, 08:54 PM | #65 |
Thanks Justin. I have been wanting to do a build like this for a long time.
I have built quite a few trucks but I am more excited about this one than any of the others..... LockDoc
08-19-2015, 12:03 PM | #66 |
08-23-2015, 10:25 PM | #67 |
OK, I finally made it over to the salvage yard again. It looks like the fans are from a '02 Toyota Camry not a Jeep. I will edit my previous post.
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-12-2017 at 11:33 PM. |
08-23-2015, 10:51 PM | #68 |
More stuff done on the Panel. I take it Tuesday to get the exhaust installed, then on to the alignment shop. Won't be long now.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-04-2015 at 02:13 PM. |
08-24-2015, 12:25 AM | #69 | |
Btw your build is progressing nicely. |
08-24-2015, 04:59 PM | #70 | |
Naturally I installed it upside down from how it was in the original vehicle. Using my mirror I get: DENSO AA422750-1521 LockDoc
08-25-2015, 10:47 AM | #71 |
08-25-2015, 10:28 PM | #72 | |
Wow! It might be a while before I get back over there but when I do I will see if I can find a Camry and check it out..... I wouldn't mind picking up another set of them anyway. Thanks for the info. LockDoc
08-26-2015, 01:12 PM | #73 |
Congrats on the first drive! Are you gonna hook the AC up? Momma won't know how to act!
08-26-2015, 06:47 PM | #74 | |
I may not have time to hook up the A/C Chip, I need to make a bracket for the Sanden compressor. LockDoc
