Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-04-2015, 09:49 PM   #51
First c10
First c10's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
Another
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-05-2015, 01:35 AM   #52
First c10
First c10's Avatar
Originally Posted by msgross View Post
Nice tires..
Thanks. They look better than I expected!!!
GO GO!!!
Old 03-12-2015, 10:10 PM   #53
MyDad'sTruck
Great thread! Jealous!!!
MyDad'sTruck is offline   Reply With Quote
Old 03-13-2015, 12:25 AM   #54
First c10
First c10's Avatar
Thanks MDT
Well its been a slow process as I have had to work some overtime and my sons sports have kept me busy.
I worked on wiring harness a little and got the LS6 Valve springs so just waiting on the gaskets and seal so i can start the cam swap. thought i would updated you all
GO GO!!!
Old 03-26-2015, 07:04 PM   #55
First c10
First c10's Avatar
I got about a hour of free time so I decided to start the can swap. I got the timing cover off and what do you know a 1 bolt cam....and I have a 3 bolt cam so I had to order a new sprocket and bolts. Not bad as they cost me 20.20 for a pocket delivered and 9.38 for arp bolts. But I would have ordered them a while back of I had known. I thought it was 3 bolt until 2010 but it's 2008 and up gen IV.
I got a couple questions.
Any problems with the timing chain adjuster from 1 bolt sprocket to 3 bolt?
Is there a way to upgrade the oil pump since I got the cover off?? I mean with out having to replace the whole oil pump and dropping the pan as the motor is sitting on the pan on a pallet. Or is the new oil pump the best way? Or just leave it?
GO GO!!!
Old 03-26-2015, 10:28 PM   #56
DWilbur
My 2004 LS 5.3 engine was a 3 bolt cam. when I rebuilt the motor I replaced the cam and installed double roller chain and gears. I'm just asking a question is your motor flex fuel engine with variable timing. If it is the lifters are different than what you would typically see.
DWilbur is offline   Reply With Quote
Old 03-26-2015, 11:49 PM   #57
First c10
First c10's Avatar
It's a 4.8 from a 2008 1500. No VVT no DOD. I picked my son up from track practice and we went to the shop and got the cam swapped out with the new one. Here is a picture of him taking it out.
GO GO!!!
Old 03-26-2015, 11:56 PM   #58
First c10
First c10's Avatar
This is the cam card for the cam we swapped in. Should help out with the 4.8 in a 4x4.
GO GO!!!
Old 03-27-2015, 12:04 AM   #59
First c10
First c10's Avatar
The finished product. Now just waiting for the 3 bolt sprocket.
GO GO!!!
Old 03-28-2015, 02:08 AM   #60
First c10
First c10's Avatar
An anyone tell me the difference between the stock spring and the new blue LS spring?
GO GO!!!
Old 03-28-2015, 04:48 AM   #61
DWilbur
The blue springs looks thicker, stiffer for the higher lift cam you are installing.
Old 03-28-2015, 12:20 PM   #62
First c10
First c10's Avatar
I agree in the picture it does. Looking at it up close it looks to be the blue coating that makes it thinker only. I am sure it is beefer just thought I would share as the difference is not much.
DW do you know if there is anything I should do to the oil pump since I am in there? Dissemble and clean maybe? I don't want to remove the pan as it would be pretty difficult for me to do unless it is best to do so. I guess I can block up the motor some way so that I can get to the bolts. Right now it is sitting on the pan.
GO GO!!!
Old 03-28-2015, 07:59 PM   #63
First c10
First c10's Avatar
Look what I got. Complete 1991 suburban frame. It's the suburban I got the transfer case out of. Steering and both axles. Not sure what I will use but of I do I have it. 200$ I didn't think that was bad. I am annum on trying to use the front cross member for the la swap plus away bar etc.
Anyone want a 10bolt front or rear????? Cheap Lol.
GO GO!!!
Old 03-28-2015, 08:01 PM   #64
Nitis
Nitis's Avatar
might be able to use the gas tank too!
If it s a 40 it might be a little big but the 31s should fit good
Anxiously awaiting the crossmember swap
Nitis is offline   Reply With Quote
Old 03-28-2015, 08:25 PM   #65
First c10
First c10's Avatar
Probably could have used the tank but it would take some work and I already have a 31 gallon tank and straps
The main reason I got it was for the steering box and crossmember. I bought a steering box and had to pay the core charge as I didn't have a core but I do now so that $50 back already.
GO GO!!!
Old 03-28-2015, 08:32 PM   #66
Nitis
Nitis's Avatar
Sweet! using the squarebody 31 I assume you are going to check off so many things on my list for me!
Old 03-28-2015, 08:47 PM   #67
First c10
First c10's Avatar
Yes I bought off eBay 96$ shipped and bought the in pump sender and straps from classic parts for 48$ and 22$ Ordered a walbro in tank pump with assessories off eBay again for I think 70$
GO GO!!!
Old 03-29-2015, 12:06 PM   #68
msgross
msgross's Avatar
probably make your money back selling the axles, if it has low gears and a locker of some sort then it should sell quickly.
Did it have a sway bar? I'd swap that over.
I've seen a few guys put in an LS with just engine mounts, sure you need the entire crossmember?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-29-2015, 12:23 PM   #69
First c10
First c10's Avatar
Well the rear is open diff. Not to sure of the ratio. But when I get the axles removed from the frame I will check. Yes I got the sway bar off of it before I bought the whole frame. This is the vehicle I got the TC frome and the swap bar and mounts.
Question regarding the comment you made about the crossmember. So you know of someone that swapped in a LS motor with no front crossmember just mounts?
This is the passenger side motor mount
GO GO!!!
Old 03-29-2015, 01:20 PM   #70
Nitis
Nitis's Avatar
Was it a pre 73 4x4?
Old 03-29-2015, 01:55 PM   #71
First c10
First c10's Avatar
Can anyone tell me if these will work? I know everyone says dirty dingo I just have a problem paying for the name. Just there plates are 120 bucks.
GO GO!!!
Old 03-29-2015, 02:07 PM   #72
Nitis
Nitis's Avatar
It's all coming back to me now. Remember the motor won't fit in the stock crossmember so unless those mounts raid the engine significantly it won't work. Square peg round hole theory. The LS is a fatty
Old 03-29-2015, 02:10 PM   #73
First c10
First c10's Avatar
Ok I am a little confused. Are you talking about the 91 crossmember or the plates and mounts I posted a picture of from eBay?
GO GO!!!
Old 03-29-2015, 02:17 PM   #74
Nitis
Nitis's Avatar
I went back to the comment the guy made about just using later mounts in the 68
There is no avoiding the crossmember swap be it the square body or dirty dingo
Those mounts will most likely work. I'd dig some more before ordering maybe something more common to square body guys
Old 03-29-2015, 02:20 PM   #75
First c10
First c10's Avatar
Oh I got you. And I agree I will Not order till I am a little I more confident they will work.
GO GO!!!
