Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-12-2015, 10:20 AM   #51
wannabefastcrf
Re: The Blazer Train
Updates.
I really wanted 10 wide ralley wheels but just couldn't justify the cost when I already had 8s. So they were powder coated and mounted with 33x12.50 bfg all terrains. Finished with deep rings and caps.
wannabefastcrf is offline   Reply With Quote
Old 06-12-2015, 10:28 AM   #52
wannabefastcrf
Also I took a stab at recovering my front seats. It took a few extra times on and off but I managed to get through it.
The passenger cover was in really good condition. Drivers side had a large crack. But I wanted to change their color so off with the green.
And on with saddle and some extra padding.
Old 06-12-2015, 10:36 AM   #53
wannabefastcrf
Also I started putting the front end back together. Everything seems to be fighting me at this point. Had to trim the grill just a bit on the bottom to get it btw the fenders. After I got this all mounted. I only have one blinker working. Time to start checking grounds....
Old 06-12-2015, 10:38 AM   #54
wannabefastcrf
It was nice one day so I pushed it outside and got the front carpet and seats in.
Old 06-12-2015, 10:40 AM   #55
lowrodderchev
lowrodderchev's Avatar
Great pics and a awesome blazer keep up the good work
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-12-2015, 10:42 AM   #56
Chulisohombre
Chulisohombre's Avatar
Love the colors. Creamsicle almost. I bet it feels good to get it outside and in the sun again.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 06-13-2015, 12:38 AM   #57
wannabefastcrf
Yup it does.
Color is Paint code 516. Often called Tangier Orange.
Old 06-13-2015, 04:31 AM   #58
whitels1
whitels1's Avatar
Great work, looks great!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 12-13-2015, 08:40 AM   #59
wannabefastcrf
Phase two has started...swap in a 5.3 with 4l65e. My goal is it has to be done by April.
Over the past year I bought a wrecked truck and pulled the drive train out of it.
Old 12-13-2015, 08:51 AM   #60
wannabefastcrf
Step one
Sold old motor. Guy who bought it wanted it right away. So I hurried and pulled it.
Old 12-13-2015, 11:46 AM   #61
Chulisohombre
From what I've heard the 5.3 is a real Nice engine to swap in. I've only driven one once but it had good power stock. With s few small mods it can be a great power maker.
Old 02-20-2016, 10:05 PM   #62
wannabefastcrf
Can anyone help. Here is the end if my oil pressure sensor I need an adapter to 1/8 NPt. Anyone know what I need ?
Old 02-21-2016, 05:22 PM   #63
wannabefastcrf
I pretty much copied some other threads and used a 91 blazer 31 gal tank with pump inside.
I added a cross member and got the tank installed
Old 02-21-2016, 05:24 PM   #64
wannabefastcrf
I used a cut off wheel and grinder to modify the adapter for the transfer case.
Old 02-21-2016, 05:27 PM   #65
wannabefastcrf
I figured out the hard way they make two of these. And even though the directions don't mention it. This is the shorter version that you don't have to cut.
Old 02-21-2016, 05:28 PM   #66
wannabefastcrf
Old 02-21-2016, 05:30 PM   #67
wannabefastcrf
I got a great deal and a local guy installed the output shaft and a transgo hd2 Kit in my transmision for 50 bucks plus parts!
Old 02-21-2016, 05:35 PM   #68
wannabefastcrf
Ordered a pacific fab mount and got the motor bolted up. I was a bit disipointed when the mount showed up half the bolts they sent were lose in the box or missing completely. The box was also filled with packing peanuts. So I had to slowly pick through them.
But afterwards the mount worked well.
Old 02-21-2016, 05:36 PM   #69
wannabefastcrf
Old 02-21-2016, 05:38 PM   #70
wannabefastcrf
But in the process of this I ruptured a brake line. So gotta add those to the list of parts to buy.
Old 03-01-2016, 08:22 PM   #71
wannabefastcrf
Been trying to keep this project moving forward. We have had a few warm days so it has kicked me in gear. My harness and Ecu is out to kenny cash for rework. In the meantime I reworked a battery box into a drivers side configuration
Old 03-01-2016, 08:26 PM   #72
wannabefastcrf
I also bought some of the 170 dollar ebay manifolds. The look pretty nice and i have good clearance it looks like
Old 03-01-2016, 08:59 PM   #73
1mrtimk
Looks good, I really like the color choice. I am the 2nd owner of a 72 cripple black, numbers matching CST (35 years) and just can't bring myself to do the color change. Good luck on the drive train.
1mrtimk is offline   Reply With Quote
Old 03-13-2016, 08:53 PM   #74
wannabefastcrf
After much debate i decided on putting a cam kit from Texas Speed in my motor. So i spent a day this weekend getting it all swamped in.
Old 03-13-2016, 11:39 PM   #75
Chulisohombre
Man that looks clean. It was a huge change when I went from stock to a even cam on mine. Also did fuely heads and roller rockers at the same time. Woke up my crate engine like crazy.
