Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
View Poll Results: Engine color question, stock colors or??
Stock Orange 3 42.86%
Satin Black to match inner fenders 1 14.29%
Body color with maybe matching finned valve covers 3 42.86%
Don't give a damn, do what you want 0 0%
Paint the aluminum intake to match? 1 14.29%
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Old 08-20-2015, 05:51 PM   #51
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: 68 Burb - Project - GoldMember
Originally Posted by GAc10boy View Post
Very nice. I really like the EFI stuff. Looks very nice and, as AD said, competitively priced. How did you find out about them?
I was doing some research online one night, and I think I stumbled on them via another web forum that had a link to them on YouTube. From there I went in search of more info and reviews. While they have not been around along time, the 19 or so engineers that developed the product must have considerable time all together. It may be a risk, who knows but I have done the FAST EZefi on my sons Blazer, and while I like it, i am drawn to the idea of less wiring, boost capable out of the box, and certainly the command center idea is nice if you don't want to run a frame mounted pump or mod an existing gas tank..
When I spoke with them, they are interested to have me document the install for their website.. that would be cool!
Originally Posted by Advanced Design View Post
Thank you!
Certainly, I was poking around for my logbook to get some more info for you, I found a Wagner number for one of the calipers is CR116349
Didn't find the part number I used for the rotors..
Once I get this installed under the Burb, I will have to make some tabs for the brake lines, of course I'll take some pics to share..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-20-2015, 07:53 PM   #52
Advanced Design
Advanced Design's Avatar
Appreciate that Twisted! I need to improve the stopping power of our 72 Burb and am looking at different options. I believe that style of caliper is on the rear of my 56. While it stops ok, the ratchet style adjustment on mine aren't precise enough. The left rear is a bit too loose and one click tighter is too tight.
Don't know if these operate the same.
Advanced Design is offline   Reply With Quote
Old 08-21-2015, 11:31 AM   #53
Twisted78SS
Wide n'Low
Hmmm,
not sure about these, they seems to rotate fairly easily, i will install the brackets and do some non-scientific tests over the weekend to see how they act / feel. Of course no real idea until they are in-service. Thanks for the heads up, will make note of it for sure.
Air Force Retired
Old 08-21-2015, 03:37 PM   #54
notchbackgta
Originally Posted by Twisted78SS View Post
Do you know the size and pitch on that nut for the E-brake lever? I bought calipers without brackets (doh) but then I found someone that sells the brackets and springs, so I have those now, but I dont know what the nut size and pitch is, though I haven't looked at it too hard to figure it out. Just wondering if you knew.
notchbackgta is offline   Reply With Quote
Old 08-21-2015, 09:49 PM   #55
71chevswb
What do you use to clean your parts to quickly and perfectly?
71chevswb is offline   Reply With Quote
Old 08-23-2015, 12:32 AM   #56
3drburb
Very nice rig. That is one of my favorite all time color, keep up the awesome work.
3drburb is offline   Reply With Quote
Old 08-24-2015, 12:39 PM   #57
Twisted78SS
Wide n'Low
I typically start with a scraper to remove the big chunky stuff.. If degreasing is needed, then it is either done with a pressure washer (never seems to be the case for me ) or more typical, is the slow and tedious manner of spray, wipe, spray, wipe with some sort of degreaser and shop towels. I came across a product called Key Super Degreaser (see description below) which really speeds up this process.
After things are clean, I usually take a grinder with a wire wheel and give it a once over, or I use a flap disk if I need to smooth or remove any rough areas. Depending on conditions, I use the wire wheel before doing any wipe down as it does take off a ton of crap/crud on its own.
For final prep I use a wax and grease remover or Eastwood ‘pre’ cleaner.
I try and do at least two coats of primer followed by 2 or 3 coats of paint. I am really liking satin black, although I do like the look of Eastwood under hood black to.
Key Super Degreaser
“cuts through heavy concentrations of grease, dirt, oil and non-water soluble
contaminants. Perfect for engine and driveline degreasing as well as heavy grease industrial applications.
Works well to remove grease from tractors, forklifts and hydraulic equipment”
Thanks 3drburb!
I was initially drawn to this because of the color, it has really grown on me to the point I am considering it for my 67 K10 SWB too.
Off the top of my head I don’t, but I am happy to take a look tonight and get that info for you.
Air Force Retired
Old 08-24-2015, 12:52 PM   #58
Twisted78SS
Wide n'Low
Well, the weekend did not unfold as I had hoped, but on the positive side, I did spend some quality time alone with the wife.. Always good to keep them happy...
I did manage to take care of a few small items though.
  • Installed the front shock mounts and shocks
  • since the frame is not dimpled for power steering, I used an adapter bracket from Captainfab
  • Removed the old exhaust
  • Cleaned the frame rails back to the trailing arm cross-member so I can run new brake,fuel, and air lines for the Accuair
  • Scuffed and painted the Hydroboost & booster adapter brackets
  • Installed new outer tie rods, inner were done previously
Short list I know, but it happens.. will keep the pressure on as best I can
Air Force Retired
Old 08-24-2015, 01:29 PM   #59
GAc10boy
GAc10boy's Avatar
Looks like great progress to me!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 08-24-2015, 05:20 PM   #60
Twisted78SS
Wide n'Low
Thanks,
It seems to be going slow, although compared to my other projects it's screaming !!
Air Force Retired
Old 08-24-2015, 05:29 PM   #61
Twisted78SS
Wide n'Low
Ok,
these might be a bit premature and out of sequence on the build, but while at lunch today I decided not to go for a bike ride and instead take a few pics UN-boxing the Fitech system.
First impression:
Really quality looking parts and packaged well. After putting an Fast EZ-EFI on my sons Blazer, this one look even "easier"..
Enjoy.
I also opted for the Command Center on this go round.. I can see multiple uses for something like this..
Air Force Retired
Old 08-24-2015, 09:31 PM   #62
Advanced Design
Thanks for sharing the parts. I agree about the command center usefullness too. Likely handy for LS swaps.
Will be interested on your take of Fitech vs FAST.
The front end looks really good too!
Old 08-24-2015, 11:16 PM   #63
GAc10boy
GAc10boy's Avatar
Parts look killer! Definitely interested to hear your feedback as you work toward installing it all.
- Robbie
Old 08-25-2015, 11:15 AM   #64
Twisted78SS
Wide n'Low
Thanks AD,
I am excited to say the least.. I was thinking last night, I could easily enough setup the engine and the system on a break in stand and pre-run everything. I think with this setup, it would actually be easy enough to create the final install hose lengths, and wiring layout on a temp stand to break in a cam and validate no leaks etc... then transfer it to its final location without to much fuss. May have to try that out
Almost have the front complete, a couple cotter pins and the sway bar.
Thanks,
plan is to setup the Go Pro and shoot some of the install.. We'll see how that turns out
Air Force Retired
Old 08-27-2015, 10:50 AM   #65
Twisted78SS
Wide n'Low
Notchbackgta,
Sorry for the delay in responding, but I'll be damned, I found my brackets, but cannot find the lock nuts anywhere.. I am sure they are in a bag inside a box on one of the shelves, but so far no joy!
Figures, as soon as you want something, it decides to hide out.
I'll keep looking as I am going to need them pretty soon!
Air Force Retired
Old 08-27-2015, 10:54 AM   #66
Twisted78SS
Wide n'Low
Continued some work on GoldMember..
Moving to the rear, I began to disassemble the rear axle in prep for the C-Notch.. Well, Guess they don't make sockets as good as the old days, with a short breaker bar I ended up with these..
So out came the sawzall and plasma.
went from this:to this:
continued on attacking the rivets.. Man I hate Rivets!!
started with the bumpstop
I ended the day after getting the passenger side mocked in. I only need to finish drilling a couple mounting holes, and painting all areas that will be inaccessible.
Forgot to get pics after I started on the rivets.. I have I mentioned how much I hate Rivets!! Especially the ones I couldn't get the grinder on..
Air Force Retired
Old 08-27-2015, 11:23 AM   #67
notchbackgta
Notchbackgta,
No worries. I am not that far along yet anyway.
I actually have so many parts around the house for 3-4 projects I lose them in the house all the time! Sometimes I look for hours to not find it and then have to go on to something else. But I usually find something I was looking for and earlier project, lol
Old 08-27-2015, 05:05 PM   #68
Twisted78SS
Wide n'Low
Now that sounds all to familiar
Even though mine are all in the same shop, it's always a gamble whether or not they hide upstairs or down. Usually I think I am being good when I dedicate a shelf for a project, bag things, walk them upstairs and drop them on the right shelf. somehow that only lasts for a week or two. then the mixing magically begins.
Air Force Retired
Old 08-28-2015, 06:25 PM   #69
Mr. D
Mr. D's Avatar
Twisted:
Are you using dropped spindles and bags, or just running with the stock spindles with your AccuAir kit?
56 Chevy step-side
68 Chevy Suburban
69 Corvette Stingray
00 BMW 325 (Daily driver)
09 BMW M3
18 GMC Acadia (Wife's daily driver)
Mr. D is offline   Reply With Quote
Old 08-30-2015, 03:44 PM   #70
Twisted78SS
Wide n'Low
Originally Posted by Mr. D View Post
Twisted:
Hey Mr. D
I'm running dropped spindles and bags. I've got upper plates and stock upper a-arms, and Ride Tech tubular lower control arms.
Air Force Retired
Old 08-30-2015, 04:38 PM   #71
goldenburb
goldenburb's Avatar
What interior are you going with? Use this. lol
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 08-31-2015, 01:42 AM   #72
Twisted78SS
Wide n'Low
I'm pretty sure my son would take over the whole build if I stole his beloved buddy bucket..
I am going with buckets and console, I'll post a pic of the houndstooth material I have, I just need to decide on the seat color. I removed the third seat to make room for hauling my road bicycle, so I'll have the buckets and second row seat upholstered to match. I have plenty of the houndstooth material so I can do some sort of accent on the door panels and or the rear side panels I have yet to make..
Air Force Retired
Old 08-31-2015, 02:10 AM   #73
Twisted78SS
Wide n'Low
Well,
Been trying to get my photos to upload tonight, but that didn't go so well, so I'll just describe my progress tonight and get the few pics up in the morning.
I finished the c-notch install, which might sound like no biggie, but after doing these in the past with the body off, I can say it goes a bit slower hanging out under the Burb..
After that was done, I pulled the fuel tank to drain it and get a look inside to see what sort of shape its in. Since this sat for about 22yrs, I was afraid it was going to be a mess, but to my surprise it has very little scale on the inside. I got some fuel tank cleaner and will run that through tomorrow after work. Man were the hoses brittle! I pulled out the bags for the rear and looked over my assortment of fittings, seems my bags have a 1/2 port, and my fittings with 1/2 inch threads are rather tall.. Might have to do something about that.. I'll also work on those tomorrow.
Then I took a break from the dusty dirty underside and started to map out where the Accuair components are going to live. I decided that they will go in the back left corner inside and behind what will be the side panel. The lines and harness wiring will exit via a hole in the fuel filler housing cover. I also have a pair of 3 gallon tanks I'm going to run to give me a little extra air so if needed I can fill some bike tires while out on the road. That means I need to decide where to plumb a port for that.. I think the tanks and compressor will have plenty of room aft of the gas tank on either side, which should work out nice..
Well, not as much as I had hoped to do, but the notches took more time than I anticipated, and I spent all of today running around town with the wife and son.
Pics coming in the morning (I hope)
I almost forgot, finished sanding the the heater motor mounting area after the last round of filler.
Drew
Air Force Retired
Old 08-31-2015, 02:11 AM   #74
Mr. D
Mr. D's Avatar
Thanks Twisted.
I've got dropped spindles along with the disc brake kit for my 68 but I've haven't decided if I want to go with air ride or just go for more of a stock lowered stance.
How do you like the ride of air suspension vs stock?
Nice seats BTW Golden!
Old 08-31-2015, 02:16 AM   #75
Mr. D
Mr. D's Avatar
Thanks Twisted.
Wow! Great progress Drew! Can't wait to see the pics. That c-notch sounds like a pain without raising the body off the frame. A bit like performing surgery right?
