Old 09-02-2015, 08:17 PM   #51
JPutnam
Re: Wizit's bagged 60 gmc build
Originally Posted by Wizit247 View Post
I'm fairly new to all this airbag stuff so bear with me.
The way I understand it is that the bags have a sort of internal bumps stop and that the plates of the bag need to contact each perfectly flat if they are ever bottomed out.
If they contacted each other at an angle it could cause damage to the bag.
Im entirely new at this airbag stuff. lol I never heard of that. but that doesnt mean its not true. kinda makes sense.
JPutnam is offline   Reply With Quote
Old 09-03-2015, 10:19 AM   #52
Wizit247
Wizit247's Avatar
So I talked to someone at Slam Specialties and they verified that my thinking was correct. The bag plates need to come together parallel to each other to avoid any damage.
I know i originally read about correct bag setup on this site somewhere. just not sure what thread.
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901
Wizit247 is offline   Reply With Quote
Old 09-15-2015, 12:30 PM   #53
Wizit247
Wizit247's Avatar
Not too much progress to report on. Im trying to gather parts for the watts link.
Added a crossmember and built some filler panels for it.
The sandblast guy at work let me know they were gonna have a little extra time that they could blast the frame for me so i quickly stripped it down.
Once it back from blasting I will finish weld everything and box the rest of the frame. then hopefully some paint soon!
Old 09-16-2015, 01:04 AM   #54
Captainfab
60-66 Nut
I replied to your post about a pair of caliper brackets, but have not heard from you.
Old 11-06-2015, 06:03 PM   #55
Wizit247
Wizit247's Avatar
I unfortunately have had to sideline The build for a couple months while we build my brothers new drag car.
The only real update I have is that the chassis is back from sandblasting and I picked up a low mile 5.3 for the truck!
Old 11-06-2015, 07:33 PM   #56
Coach529
Coach529's Avatar
Looks awesome.....subscribed
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 11-06-2015, 09:23 PM   #57
dwcardfan
dwcardfan's Avatar
Nice donor motor!!!!
dwcardfan is offline   Reply With Quote
Old 11-23-2015, 12:13 PM   #58
Wizit247
Wizit247's Avatar
I set the cab on and took her to her resting place for the winter.
all I have is a 2 car garage and the wife needs a spot to keep her car parked out of the snow. the other spot will be occupied by my brothers drag car that Im doing an bunch of fab work on.
I should be back to the gmc in a few months. sad day.
Old 11-26-2015, 02:14 AM   #59
Captainfab
60-66 Nut
Your GMC will be nice with the 5.3. Did you pick that up from Spauldings? What trans are you going to run?
Are you still interested in those spindles, rotors, etc?
I'm interested in some details on your brothers drag car.
Old 11-30-2015, 07:18 PM   #60
Wizit247
Wizit247's Avatar
I sure did! they actually sent me the wrong motor the first time around and I received one with over 200k on it. They quickly sent me the correct much lower mileage motor so it all worked out.
As of now im planning on a th350. Theres a guy in Spokane(cant for life of me remember his name right now) who we buy all our offroad th350s from. Hoping to go through him.
Yessir! Sorry I have been slacking on it. The truck has gotten pushed to the side as of recent and hasn't been a priority sadly.
66 nova 2. twin turbo LS build. Building to 8.50 spec. I will post up some pics and more details soon! we are hoping to have it done minus paint/body by Car d'Alene next year.
Old 03-15-2016, 10:25 AM   #61
Wizit247
Wizit247's Avatar
The truck is still in storage until the fabrication on the drag car is done. probably another month or so.
I scored some 22x9 transit wheels last night off the local craigslist for a killer price!
Old 03-21-2016, 01:29 AM   #62
ebaby35
A guy local to me had a 60 Shortbed frame that had been modified with the X cut out and a later crossmember installed and a 63+ front end with drop springs. I got it and a 12 bolt rear from him for $200. We were already planning on cutting down to a shortbox so this was perfect.
Saturday my brother and I got the frame in the garage.
First we cut the bottom of the crossmember and patched it in. I just laid a level across the frame rails and marked the crossmember.
We added some gussets and some exhaust pass throughs.
Started on the rear notch. The 60-62 frame doesnt have the jog in it like the later frames do so I just drew up a notch and cut it on one of our plasma tables at work.
Prepping for the notch. Thats my brother grinding.
Getting everything mocked up and tacked in.
Pancaked the front crossmember 2" and somehow didnt take a picture of the finished product.
We set the front end on it just to get a peek at what it was going to look like.
Not bad for a days work.
we are still about 2.5" from laying frame. Theres no drop blocks in the rear and the upper balljoints were maxed out.
Im planning on building tube trailing arms with integrated blocks similar to the PB ones. The front I think I will Pie cut the upper arms and see where that gets me. Im trying to avoid drop spindles becasue this build is on a very very slim budget.
The tires were deflated in this pic to get it to lay frame.
Hey just wondering what cutting the X member allows you to do different. I have a 62' frame and was wondering if this would help me do other things.
ebaby35 is offline   Reply With Quote
Old 03-21-2016, 08:23 AM   #63
BFoley
BFoley's Avatar
Incredible fabrication skills! In for the build!
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 03-21-2016, 09:33 AM   #64
dwcardfan
dwcardfan's Avatar
Very nice work!
Old 03-21-2016, 10:00 AM   #65
Wizit247
Wizit247's Avatar
Its commonly referred to as "pancaking"
theres lots of info in the FAQ page.
If you have a stock 62 crossmember with the torsion bars I dont think pancaking the crossmember is an option. I changed to a later style crossmember.
Originally Posted by dwcardfan View Post
Very nice work!
Thanks guys!
This thing should be coming home in the next couple months so there will be lots of progress happening soon!
Old 03-27-2016, 09:49 AM   #66
r8e1d
In for the ride.
Red
r8e1d is offline   Reply With Quote
Old 03-27-2016, 10:38 PM   #67
namloc
namloc's Avatar
Gonna be fun.Part of the fun is the build and just seeing what is to come.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 03-31-2016, 01:15 PM   #68
Wizit247
Wizit247's Avatar
Another lame update. Still collecting some parts while the truck is still in storage. I have made a bunch of progress on the drag car so it will be out of the garage soon.
Got some new tires for the 22's
265/30
Old 04-07-2016, 10:57 PM   #69
casey g
casey g's Avatar
you need to get to work! car d alene is coming fast : )
casey g is offline   Reply With Quote
Old 04-18-2016, 01:13 PM   #70
made2drag
made2drag's Avatar
nice work so far!
made2drag is offline   Reply With Quote
Old 04-22-2016, 07:17 AM   #71
clemdaddy
clemdaddy's Avatar
great progress… and a good deal on the frame.
clemdaddy is offline   Reply With Quote
Old 05-06-2016, 05:58 AM   #72
scum1
scum1's Avatar
Im following you on instagram, just found the build on here. Thinking about using your design on those trailing arms. they look so clean. Your welds are beautiful looking on all the fab work. Are those all mig welds? Great job, looking forward to the finished project.
scum1 is offline   Reply With Quote
Old 05-12-2016, 12:37 AM   #73
scum1
scum1's Avatar
oh and check out this website..i haven't used them but i had it saved if I ever needed it in the future.
http://www.dsuban.com/custom-u-bolts...und-p1033.html
Old 05-12-2016, 10:30 AM   #74
Wizit247
Wizit247's Avatar
Yep they are all mig welds. The camera makes them better than they are.
I would be happy to send you the cut file for the box part of the trailing arm!
Thanks! Im gonna get some ordered!
