09-29-2015, 07:49 PM | #51 |
Re: Hemi's 70 Blazer build
Looks great, I'm envious of your progress!
10-02-2015, 02:16 PM | #52 |
A few more updated pictures.
10-05-2015, 08:55 AM | #53 |
Very nice
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-11-2015, 09:28 PM | #54 |
Been a busy week. Got the chassis done, so I'm back to getting the body done. I fabricated the roll bar and mounted it permanently. I figured it would be easier to paint it in location than to risk getting the paint scratched afterwards. I incorporated the seat belt mounts into it also. I'm putting in 3 point harnesses because I just don't feel safe with just a lap belt. We have some nice weather coming up, so I rolled the body outside for the fun task of sandblasting it. So far I've used 52 50lb bags.
10-15-2015, 09:39 AM | #55 |
Was able to get the underside and floor epoxied and painted. Today I will be seam sealing all the joints. Someone asked for pictures of the transfer case to frame mount, so I've added those too.
Dan |
10-15-2015, 09:40 AM | #56 |
One last lic of the mount. sorry about the crappy quality.
10-15-2015, 01:37 PM | #57 |
Thanks Dan. That was me asking the question about the mount. Between yours and another post I get how it goes together now. The bushings are different thicknesses, which did you put on the bottom the thick or thin? I'm getting conflicting answers on that.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
10-15-2015, 05:32 PM | #58 |
I think the thick one, but I will double check.
10-15-2015, 08:50 PM | #59 |
You certainly have some talent and some very nice tools. Great job on your Blazer. Looks factory straight. Better than new.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-16-2015, 05:17 PM | #60 |
Dan definitely I think it was the thick bushing. I just installed my transfer case this afternoon and after I got it bolted to the tranny and sitting at the correct height I measured. Thin would have been way too low in my case.
Right now my output yoke is sitting offset between the frame rails a bit. That side mount basically dictates where it sits left to right between the frame. When I take a measurement I'm 1" closer to the Lh rail than the Rh rail so 1/2" off center. How close is yours to center between your frame rails ??
10-17-2015, 02:50 PM | #61 |
I just checked mine, and the thick bushing is on the bottom. I also checked the side to side location of the transfer case yoke and it's 1/2" offset also same as yours.
Was able to get the passenger 1/4 straightened and epoxy primed today. Nice to see panels in one color. |
10-23-2015, 06:52 AM | #62 |
great progress
10-23-2015, 08:46 AM | #63 |
10-23-2015, 12:26 PM | #64 |
Are your exhaust tips out the back or are they angled out behind the tires?
Did you put a H-pipe anywhere or are they straight from the manifold back?
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
10-23-2015, 01:11 PM | #65 | |
I had plans on an H-pipe, but once I had the exhaust fabbed up, there was no place for me to install one. Since I'm using a 5.3, the laws here in Canada dictate that I use all the emission controls from the donor engine and this includes the cats. If they weren't there I would have had room.The small gain in HP is minimal anyway, but I will miss the sound of an H-pipe though. Oh well !! |
10-23-2015, 04:46 PM | #66 |
11-04-2015, 11:24 AM | #67 |
Getting lots done, but mostly boring body work. Everything is now in epoxy primer (gray colour), and giving it 72 hours before I sand it and spray on the polyester primer (Featherfill). Parts like the underside of the hood and rad support were epoxy coated then painted wet on wet with satin black urethane.Parts like the inside of the doors that wont get blocked with Featherfill were sprayed with high build urethane primer (tan colour).
11-04-2015, 11:58 AM | #68 |
Looks good. At this rate you'll have it on the road before the snow flies.
11-04-2015, 12:27 PM | #69 |
I'm trying....
Fantastic Dan. Hood looks great. I love it when everything is the right color. Keep rocking it out.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
11-04-2015, 01:26 PM | #70 | |
I guess you wont like my final choice for the exterior then because it's not a factory colour. When I first bought my Blazer, I was going with Hugger Orange. It looks great and really suits this style of truck, the problem is that everyone else thinks so too and in IMHO it's been done too many times. What made me change my mind was the Syracuse show this year. There was an amazing looking Blazer there (1 of 2) and it was from Ontario, and you guessed it, it was orange. I don't like wrong year paint either, and some newer colours with high metallics and pearls really don't suit older vehicles. I think my choice will look good, and will be somewhat different. I'm not one to follow trends. |
11-04-2015, 01:46 PM | #71 | |
I'm trying....
BTW...have I missed it in the thread...or misread your post? What colour are you painting it?
11-04-2015, 03:08 PM | #72 |
I'm going through the colour deciding process now. I think my paint guy is getting tired of doing test panels for me. Can't decide beyond I want to be period correct. Also curious what you're going with.
11-04-2015, 03:47 PM | #73 |
I'm a real military buff and would have loved to paint it flat drab olive, but then everything on the truck would have to blacked out and needless to say any flat colours (color for my American friends) are extremely difficult to maintain. I knew I wanted a solid colour, and driving home one day I spotted a 2015 Jeep which from far away looked black. It was actually a real dark olive green, and although it was shiny, it still had that military look to it.
It's called "Tank" green, and although the paint formula says there's metal flake in it, it's in such a low amount that you can't even see it. I had a buddy photoshop a Blazer with it and it looked good especially with the black soft top. I'm a couple of weeks away from having to buy the paint, and so far I can't seem to be able to talk myself out of it. It would be different, but not so different that it would make it stand out. |
11-04-2015, 04:44 PM | #74 |
I'm trying....
That sounds cool...next question...interior colour(my spell check really doesn't like that word): green, saddle or black?
11-04-2015, 05:56 PM | #75 | |
Even though I've upgrade the drivetrain and a few other things, I still want this truck to look to be as close to original right down to the AM radio. The stereo will be in the console, and I have a WW2 era anti tank mine box that will be a permanent storage box behind the rear seat. I also have a WW2 metal gas can that will become the housing for the subwoofer and this will be clamped to the rear part of the roll bar by the tailgate. |
