Old 08-25-2015, 04:16 PM   #51
Metaldoc
Metaldoc's Avatar
Re: 67 long box
changes in progress on last cross member, added 2"x 1.75" angle and 1" square tube as the bed stop. It seems I keep adding more work, why do I do this, passion for the build.
Metaldoc is offline   Reply With Quote
Old 08-25-2015, 04:33 PM   #52
Metaldoc
Metaldoc's Avatar
Re: 67 long box
had to cut down the gate hold bars, looks easy but to get the amount out each half so it folds back up is a little tricky.
Old 08-26-2015, 11:04 PM   #53
Metaldoc
Metaldoc's Avatar
Re: 67 long box
tailgate link assy. shortened and they both work
Old 08-27-2015, 04:25 AM   #54
71Sleeper
71Sleeper's Avatar
Re: 67 long box
Nice work. I bet the build is on your mind day and night. Make sure you keep the gears oiled down because walking around with smoke coming out of your ears is never a good sight.
71Sleeper is offline   Reply With Quote
Old 08-27-2015, 07:42 AM   #55
Metaldoc
Metaldoc's Avatar
Re: 67 long box
yeah I think I have OCD, Obsessive C10 Disorder. My wife has become a garage widow.
Old 08-29-2015, 12:02 AM   #56
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Put another 250 lbs through the sand blaster and maybe another 200 tomorrow. That stuff gets into everything but does a nice job.
Old 08-29-2015, 10:09 AM   #57
Xeen
Xeen's Avatar
Re: 67 long box
A cantilevering tailgate -love- inspiring work.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-29-2015, 10:21 AM   #58
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I love the way it turned out, no step and will take an experienced eye to see the change. I want to keep the look but not look altered with the raised bed.
Thanks Derek
Old 08-29-2015, 10:24 AM   #59
Ta2Don
Ta2Don's Avatar
Re: 67 long box
Had to check out your madness after seeing your post on my thread...
Dig watching Metal Madmen at work…
Tailgate mod is
Well played...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 08-30-2015, 11:13 AM   #60
Metaldoc
Metaldoc's Avatar
Re: 67 long box
straightened the chrome and took all the dents out, looks better. Brought the frame home so I paint more parts at father in laws shop.
Old 08-30-2015, 11:40 AM   #61
Bomp
Bomp's Avatar
Re: 67 long box
Solid Build.
Sub'd
Bomp is offline   Reply With Quote
Old 08-30-2015, 10:47 PM   #62
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Bought another 250lbs of blasting media and more glass shard media for my blast cabinet. Cut 14 pieces of 2" tube and made spacers for the bed raise. Welded a washer on both sides, blasted, painted. Blasted some other parts, painted as well.
I had a good day. Time for a pop.
Old 08-31-2015, 02:19 PM   #63
Metaldoc
Metaldoc's Avatar
Re: 67 long box
made a welding turn table, also worked for the clean up on them. Done and checked off the list.
Old 09-01-2015, 03:39 PM   #64
Metaldoc
Metaldoc's Avatar
Re: 67 long box
more painting, more blasting, more painting , more blasting, there seems to be a pattern
Old 09-01-2015, 04:06 PM   #65
71Sleeper
71Sleeper's Avatar
Re: 67 long box
Looks great. You are moving along nicely.
Old 09-01-2015, 04:37 PM   #66
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks, May of next year is the plan to be driving. Almost time to start reassemble
Old 09-02-2015, 09:34 PM   #67
Metaldoc
Metaldoc's Avatar
Re: 67 long box
finally decided on the trail arm ends, threw a bit of primer on it to see my finish work. ready for blast and paint.
Old 09-03-2015, 09:28 PM   #68
Metaldoc
Metaldoc's Avatar
Re: 67 long box
steering box, flywheel covers, horn , washer bottle holder, and rad saddle parts
Old 09-06-2015, 06:33 PM   #69
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I thought that I'd blasted and painted everything and I find another pile of stuff.
Old 09-07-2015, 06:36 PM   #70
71Sleeper
71Sleeper's Avatar
Re: 67 long box
That's usually how it goes.
Old 09-10-2015, 05:09 PM   #71
Metaldoc
Metaldoc's Avatar
Re: 67 long box
another 400lbs of sand through the blaster, I guess I'm painting tomorrow. Trail arms, track bar, sway bar, control arms (all 4), gas tank straps, rad saddle and the list goes on.
Old 09-12-2015, 06:03 PM   #72
Metaldoc
Metaldoc's Avatar
Re: 67 long box
blasted and painted small stuff at home last night. this is the modified cross member for the tailgate to swing under.
Old 09-12-2015, 06:09 PM   #73
Metaldoc
Metaldoc's Avatar
Re: 67 long box
rad saddle , control arms, engine cradle, and trail arms done. It's getting closer to assembly time.
Old 09-12-2015, 06:21 PM   #74
Xeen
Xeen's Avatar
Re: 67 long box
I propose a challenge to you sir.
Fabricate your own upper tubular control arms with corrected ball joint geometry for a 2" drop spring.
Will you accept this challenge?
Old 09-12-2015, 06:57 PM   #75
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I think I could do it, but I have to finish this truck to pass an Ontario Canada safety. Once that is done then I can play with the rest of the stuff I really want to do, like my own front suspension so I can beef up the front wheel size. I will get back to this challenge after May 2016 when it's on the road and I'm enjoying it, I will have more time to play in the shop.
Thanks Derek
