Old 01-24-2016, 01:58 PM   #51
flashed
Re: A boy and his 1972 fleetside restoration
Wow ,its looking great ,look forward to more .
flashed is offline   Reply With Quote
Old 01-25-2016, 01:04 AM   #52
Ol red 71
Originally Posted by Hayseed4 View Post
So I have a little bit of a dilemma I would like some opinions on regarding my side mirrors. The truck was originally equipped with below the eyeliner mirrors that mounted on the top by the vent window. These are long gone, and the PO replaced them with the mirrors seen on the right. I picked up a nice set that is on the left, but they must have been from a different year or are also aftermarket. So the question is should I fill in all the mounting holes with weld before the paint job and add them when I can find a nice set of below the eye mirrors? should I leave the original holes only, and wait for the day I find the right set? should I go with the really wide camper mirrors? I only intend on hauling my 22ft trailer with 2 cylinder John Deere's occasionally. Thoughts?
I've enjoyed following your adventure and I'm eager to see the finished project. Something mentioned in your first post was the bedside toolbox. I love the toolbox and hope you incorporate it with the rebuild/remodel! I've recently changed mirrors on my 71 fleet side LWB c20 from similar mirrors that yours has to the jr west coast mirrors. I love the classic look and get tons of compliments. They're great for towing but do have a blind spot which doesn't affect me. I'll have the holes welded over and repainted eventually. they were around $50 or less brand new off eBay I believe.
1971 c20 LWB Fleet 2wd
'working' Add-on AC & Working heat/defrost
manual transmission w/ Power steering & power brakes
Family owned since 1971
____________________________________
“Life is rough so you gotta be tough” - Johnny Cash
Ol red 71 is offline   Reply With Quote
Old 01-25-2016, 02:01 PM   #53
steelhorse
steelhorse's Avatar
Truck is looking great. Keep up the hard work and keep us posted.
steelhorse is offline   Reply With Quote
Old 01-25-2016, 03:06 PM   #54
73737373
Well, I was going to recommend that you keep the patina........ never mind!!
73737373 is offline   Reply With Quote
Old 02-11-2016, 08:10 PM   #55
Hayseed4
I am definitely keeping the tool box section of the truck. I found a pretty good door on the parts board, and am working on repairing the bottom of the with a quarter section from a catalog. I thought the door was pretty cool as well as very useful to keep my tools, straps and other stuff out of the bed.
This has definitely been a fun and challenging project, but I am looking forward to being done so I can drive it around and show it off.
Hayseed4 is offline   Reply With Quote
Old 02-11-2016, 09:26 PM   #56
Hayseed4
So I managed to get the passenger side door and fender on with minimal trouble. The paint lines lined up exactly even though we did not paint them at the same time. I also installed a cargo light I pulled a few years ago from the junk yard. I taped the area and marked it to ensure that I didn't scratch the paint as well to get it leveled and centered.
Old 02-11-2016, 10:32 PM   #57
flashed
Looks great and I like the cargo light .
Old 04-03-2016, 10:00 PM   #58
Hayseed4
So I reupholstered the seat and added heating elements for those cold winter mornings. I was able to save the foam core, but needed new padding. I purchased cotton batting at a fabric store and sprayed the whole thing with fire retardant. Once I finished the seat I scotch guarded the fabric.
Old 04-03-2016, 10:04 PM   #59
Hayseed4
And the finished seat
Old 05-05-2016, 10:07 PM   #60
Hayseed4
Just finished the new brakes. After seeing the grooves in the front discs I decided they needed to be replaced. Judging by the cracks in the rear brake liner and how stiff they were, I am not sure the rear brakes even worked so I rebuilt them and got new drums.
Old 05-05-2016, 10:20 PM   #61
Hayseed4
So as I was doing the brakes I decided to replace the wheel bearings with new Timken ones and that was quite an adventure. The first set they sold me turned out to be for a half ton because they were way too small for the 3/4ton. The shop ended up figuring out that the Dana 60 full floating rear end was the heavier one and ordered the ones for a 1 ton. While they were a bit more expensive, I shouldn't have to do them for quite a long time.
Old 05-05-2016, 10:22 PM   #62
In The Ten Ring
Wow, that is really coming along well!
I want to see you fix up the tool box door.
I love the idea of extra tool space. In fact, I am such a tool nut, I probably need a utility bed!
In The Ten Ring is offline   Reply With Quote
Old 05-06-2016, 08:35 AM   #63
Aus69c20
Aus69c20's Avatar
Love your work and great to see you've kept it a 3/4 ton.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 05-06-2016, 10:08 PM   #64
72 tigger
72 tigger's Avatar
Great progress!
72 tigger is offline   Reply With Quote
Old 05-07-2016, 12:53 AM   #65
toolboxchev
Awesome! Wish I was as far along as you!
toolboxchev is offline   Reply With Quote
Old 05-13-2016, 10:59 PM   #66
Hayseed4
As part of the wiring of the truck I wanted to make a 7pin trailer harness. I used a camper wiring harness that came with the truck as an example. I cut the ends off of the old intermediate and tail light harness since I had new ones. I used a semi trailer wire and soldered it to the pig tails. I think this is definitely better than cutting up my new harnesses. I also am going to add my period correct variable resistor and the brake controller that came with the truck.
Old 07-23-2016, 11:10 PM   #67
Hayseed4
Long over due update to bed blasting and prepwork
Old 07-23-2016, 11:19 PM   #68
Hayseed4
I ended up taking a lower bed corner and modifying it for repairing the toolbox lower section. I then used a spot welder to weld the panel in place using the box insert for alignment.
Old 07-23-2016, 11:36 PM   #69
Hayseed4
The paint is done on the bed and all of the lines match with the cab even though we painted everything at different times.
Old 07-24-2016, 12:22 AM   #70
In The Ten Ring
It looks great!
Further, is that a lwb? If so, you have my increased compliments.
Old 07-24-2016, 09:30 AM   #71
Tdrcreyn4
Tdrcreyn4's Avatar
Very impressive progress. Nice truck.
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 07-24-2016, 10:41 AM   #72
57taskforce
All about them K’s
57taskforce's Avatar
Any more details on what you did to repair the tool box opening? I was gonna modify a rocker panel to repair the bottom of the opening.
Progress looks great!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
1972 c20, restoration
