12-20-2016, 10:24 AM | #51 |
Re: 1965 C10 ... Project Name: Just Learnin'
I've always made my own gasket to seal them up if needed. I used the same window tape for installing glass into you channel (holds glass tight) You can usually get this from any glass shop, and comes in a roll just cut to length and pop your holes in it and your done. I also use this for installing fenders to keep from scratching the paint. My2 cents...
Good to hear the airline monkey is off your back... FYI the tape is not sticky but when you apply pressure it will hold very well. Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-20-2016, 11:46 PM | #52 | |
12-31-2016, 11:57 AM | #53 |
So i finally got around to tackling the outer rockers (or at least started). I don't know if i got a bad set or it is pretty typical but i sure had to cut my lmc ones up quite a bit to get them to fit perfectly..... and I really shouldn't use the word perfect i guess.
My apologies as I seem to have misplaced most of the progress pictures from the drivers side but here is bare metal and paint at least, I was able to get most of the fit to line up really nice except the cab corner sits about an 1/8th lower that the rocker. I know I will come back to that but Im pushing to at least get my girl on the road this year. |
12-31-2016, 12:01 PM | #54 |
12-31-2016, 12:06 PM | #55 |
Today I am going to keep working on the fitment of the passenger outer. The front fit beautifully with just a single relief cut, the pinch weld lines up perfectly with the inner... but the back was not nearly as nice to me. I'm guessing its because some owner along the way smashed the back cab corner and simply bondo'd the entire thing. So I'm trying the get shape proper as I go as well.
12-31-2016, 10:08 PM | #56 |
01-01-2017, 10:42 AM | #57 |
Nope it's not just your Rockers....I'm Building a F$^d bronco for a customer right now and the rockers had to be modified.
If you checkout the build it shows the drivers side had to be modified alot. it's all part of it, I have not had 1 single rocker I didn't have to cut in someway Mark...
01-02-2017, 12:27 AM | #58 | |
01-02-2017, 12:32 AM | #59 |
01-04-2017, 02:38 AM | #60 |
01-04-2017, 03:02 AM | #61 |
Always a good felling when there's no more rust. Project is looking good
01-04-2017, 06:21 AM | #62 |
Nice work!
01-07-2017, 02:42 PM | #63 |
Thanks guys!! one more question, anyone have good advice for what to use as the seal underneath the tunnel? looks like the original seal was about 2 1/2" thick and the PO just used home insulation hahahha he seems like a smart guy.
01-12-2017, 12:40 AM | #64 |
01-12-2017, 12:40 AM | #65 |
01-12-2017, 12:44 AM | #66 |
01-12-2017, 12:46 AM | #67 |
01-12-2017, 10:32 AM | #68 |
One little note on POR15
Those of you who want to use the product be warned after applying it (if you have to grind off any to weld in an area) You WILL get major perosity (bubbles in your weld) The por gets into the metal and stays there and does not like to be welded on after application! I found this out the hard way on a Customers build. That being said I started to use the Eastwood rust encapsulator it can be sprayed or brushed and dries in minutes rather than 12hr like POR Just my opinion! Mark...
01-12-2017, 11:16 AM | #69 |
01-12-2017, 01:12 PM | #70 | |
Posted via Mobile Device |
01-13-2017, 10:13 AM | #71 |
You are welcome..we All have something to learn If your not learning your dying. (Or so they say )
I started to use POR several yrs ago and found this out (bad welds) and also on the POR you might want to put a plastic baggy on the top then the lid. The reason for this if you get any on the lip of the can and the lid they will "weld" themselves together. Mark...
01-13-2017, 09:22 PM | #72 | |
01-13-2017, 09:27 PM | #73 |
01-16-2017, 11:39 PM | #74 |
01-19-2017, 11:10 AM | #75 |
