01-18-2016, 10:08 AM | #51 |
Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
I don't use it to scare people. Being from 57 they didn't care about decibels and its a lot louder than most on the tracks today. To many sue happy people out there. But yes it will get anyone's attention with a quickness
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
01-18-2016, 10:19 AM | #52 |
dazed and confused
Nice
members met: redbaron69, billsbowtie,nc67 |
01-18-2016, 12:03 PM | #53 |
Thats one nice truck, love that red/orange paint and trick horn setup.
I have the same FiTech kit and I'm still debating on using the timing feature. I see you plan on using a MSD 85551 distributor. I guess that means you don't plan on using vacuum advance? I have been meaning to call and see if FiTech recommends using vacuuming advance when using the system for timing control. It's hard to tell from your pictures but did youinstall that O2 sensor 10* above level as per the instructions? Not trying to pick on your work you have done an excellent job on that truck.
Made in America by Americans |
01-18-2016, 12:16 PM | #54 |
I do not plan on using vacuum advance. I believe the fitech goes up pretty high in its advance set up. I did not install it 10 deg above center. I have done several several O2 sensors on my rides and several others and never had any trouble at the 90 angle. This one may be the one that proves me wrong but only time will tell. If you look close I have other O2 bungs there already. They were just to long to use
01-18-2016, 12:16 PM | #55 |
But Found Her 25yrs Later!
The computer takes care of mechanical and vacuum advance.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-18-2016, 12:23 PM | #56 |
Edit.
It's my understanding that the computer handles both mechanical and vacuum advance.
01-18-2016, 12:28 PM | #57 | |
It can be straight up and from the top of the tube and it'll still work as well as 10° |
01-18-2016, 12:33 PM | #58 |
You will be the first to know when it goes bad. I understand your concern. But I have sold cars before they have went bad on me. I will be screaming damnit swampbog told me so. Lol
01-18-2016, 12:38 PM | #59 |
Also I just want to say the FITECH customer support is top notch. I just called them to see if I could get the decel pid to act a little faster because my truck is an standard. He told me these are set up for autos but immediately knew the parameter and values to put it to and try. Also he told me another parameter to watch for the absolute best idle blade openings. I work for Johnson controls and program for a living. It's nice to talk to someone that actually knows the configuration and pids and can immediately tell you where to look. These guys are top notch and not just salesmen. They make me feel like they built all the logic and have it on their rides.
01-18-2016, 12:40 PM | #60 | |
And it won't be the first time I lied to anyone......on purpose |
01-18-2016, 12:45 PM | #61 |
I know and thank you for pointing it out but I knew it when I installed. I read the instructions 3 times lol. One thing I do not do is drive it short distances and shut it down. This may help in keeping them dry. If it does go bad I will cut the pipe and rotate it. No biggy.
01-18-2016, 03:31 PM | #62 |
Are you using the factory rod type throttle linkage?
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
01-18-2016, 03:33 PM | #63 |
I sure am with a set of steel bushings!
01-18-2016, 04:04 PM | #64 |
So you did not use the factory throttle linkage?
01-18-2016, 04:34 PM | #65 |
the rod linkage is the factory linkage to my truck. It did not have the cable which I like.
01-18-2016, 06:30 PM | #66 | |
That is the coolest/funniest thing I've seen/heard in a long time.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-18-2016, 06:32 PM | #67 |
Don't let me catch someone crossing a train track to slow cause they scared of bending their 26 inch rims. I have made a couple turn the tires to smoke that was dicking around.
01-18-2016, 06:42 PM | #68 | |
I am doing a study find the best lube. So far I have tried motor oil, WD40, "O" Ring lube, JB80, and Joe Gibbs assembly lube. Results are inconclusive.
"In an insane world a sane man must appear insane" ~Spock~ |
01-18-2016, 06:46 PM | #69 |
I would of paid good money for that the other night. Very cool design. I can favricate most tools and that may be my next addition if I ever have to do another EFI.
01-18-2016, 07:33 PM | #70 | |
01-18-2016, 07:43 PM | #71 |
I'm unfamiliar with this.
Is this setup to press the fittings into the plastic injection hose?
1971 C10 SWB 350/350 A/C PS PDB |
01-18-2016, 07:44 PM | #72 |
That's just awesome. Grew up next to the Southern Pacific. Hijacked rides when the freight slowed down for the Siskiyou's, then down to Northern California to fish on the Shasta River. Sounded just like that. Just awesome.
72 K10 |
01-18-2016, 09:14 PM | #73 |
It's not for the hard plastic OEM style fuel lines. It is for the rubber "push lock" type of hose and fittings that a lot of the aftermarket EFI systems use. They are very hard to install.
01-18-2016, 09:20 PM | #74 | |
Funny, used to hike up the tracks to fish Shasta Lake. Back when it was still a lake.
01-19-2016, 08:30 PM | #75 |
Diceman,
How about using dish soap for lube? give that a try.... Ben |
