Old 06-26-2016, 10:12 PM   #51
gokellurself
gokellurself's Avatar
Re: 65 long bed step side
Very clean and simple Mehoff I like it
gokellurself is offline   Reply With Quote
Old 06-27-2016, 11:32 AM   #52
roll_the_dice
roll_the_dice's Avatar
Looks good...Don't see enough LWB stepsides around. We love ours!
roll_the_dice is offline   Reply With Quote
Old 08-06-2016, 09:29 PM   #53
mehoff400
picked myself up a set of 22" transit wheels.
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 08-06-2016, 11:52 PM   #54
62stepside longbox
62stepside longbox's Avatar
Looks awesome, Wanna sell me your baby moon caps now?
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 08-07-2016, 12:21 AM   #55
mehoff400
LOL i was going to try and using my current baby moons.
My truck
Old 08-07-2016, 07:55 PM   #56
mehoff400
looks like these caps should work just fine... sorry 62stepside
My truck
Old 08-07-2016, 08:41 PM   #57
rusty76
rusty76's Avatar
Awesome wheels. Love that look.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-07-2016, 11:34 PM   #58
62stepside longbox
Looks great!
Old 12-16-2016, 06:48 PM   #59
mehoff400
well plan origially was to wait until i can do a caliper swap before i install the wheels. i was able to find a guy that will bore out my wheels for 20 bucks a wheel so i figured why wait. i test fitted one today after finishing up the wheel bearing.
My truck
Old 12-16-2016, 11:51 PM   #60
shp4man
shp4man's Avatar
Nice truck, mine's a long stepper, too. I like what you did with the engine, looks good!
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 12-29-2016, 07:40 PM   #61
mehoff400
just got tires on my transit wheels
My truck
Old 12-30-2016, 12:25 AM   #62
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
oooooo doggy! lol!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-03-2017, 01:53 PM   #63
jcramsey
jcramsey's Avatar
Diggin this truck! What's planned for it next?
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 01-03-2017, 08:11 PM   #64
mehoff400
plan is to lower it as much as i can.... with these wheels not sure if i am able to go as low as i want. i still got intake carb and headers i need to install on the straight six,
My truck
Old 01-07-2017, 12:39 PM   #65
mehoff400
getting gas this morning going to take our engagement photos
My truck
Old 01-07-2017, 01:00 PM   #66
rusty76
rusty76's Avatar
Congrats on the engagement!
My build thread
Crossmembers CC
Old 01-26-2017, 09:19 PM   #67
wolfsden
wolfsden's Avatar
Did you have any issues with the fitment of the 22 transit wheels?
I just purchased a 63 C-10 fleet side long bed and I want to change the wheels.
I am putting air ride on it for suspension, I decided to go with EZ Ride. I have drum brakes front and back so for now no drop spindles or C notch. I will see how it looks and rides first and if its not low enough for me then maybe I will change to rotors and add the drop spindles in front and c notch in rear to get it even lower.
I was looking at the Mob Steel wheels and the rep said if i run 20x8 in front and 20x9 in back i won't have any issues with rubbing or fitment and won't need to do any mods. The transits look the same to me and are so much more affordable but I only see them in 22x9 for front and back, I really don't want to go any smaller then 20"s I'm fine going bigger with 22's but don't really want to do any mods to make them fit. I know the the center hole on the rim needs to be machined a bit larger to fit the drum but I'm ok with that just don't want to cut any wheel wells or shorten axles for now. You have a really great looking truck!
Thanks for your input,
Jerry
wolfsden is offline   Reply With Quote
Old 01-26-2017, 09:24 PM   #68
wolfsden
wolfsden's Avatar
What tires and tire size did you go with?
Old 01-26-2017, 09:38 PM   #69
mehoff400
tires are a 265/35/22
other than milling the center hole out bigger grinding down the rivet so the wheels sit flush on the drum in the front and a 1" spacer in the rear no other modifications needed. if i didnt run a spacer the tire was rubbing on the bed for me.
My truck
Old 01-26-2017, 10:51 PM   #70
wolfsden
wolfsden's Avatar
Where did you get the Chrome center caps and did they just pop on or you had to modify some clips? they really look awesome!
Old 01-26-2017, 10:59 PM   #71
mehoff400
bought the clips from
https://www.instagram.com/struggle_55/
center caps are from
http://www.wheelskin.com/cbm10.html
Thanks!
My truck
Old 02-01-2017, 09:57 AM   #72
wolfsden
wolfsden's Avatar
Thanks!
When do plan on lowering it and what kit are you going with?
Please post pics as well when you do.
Jerry
Old 02-16-2017, 10:50 PM   #73
mehoff400
starting to install the new carb
My truck
Old 02-17-2017, 11:19 AM   #74
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
That's looking better.
Old 03-04-2017, 09:14 PM   #75
mehoff400
got the new carb in place... still need to figure out linkage and run some lines
My truck
