Old 02-19-2017, 01:15 AM   #51
CABLESCUM
CABLESCUM's Avatar
Re: '72 GMC Shortbed Stepside...last truck
B4/After Drop...1/4 Round Drip Rail
I need a new goat, mine is worn the hell out!
MY TRUCK: https://67-72chevytrucks.com/vboard/...d.php?t=698511
MY SONS TRUCK: https://67-72chevytrucks.com/vboard/...d.php?t=812054
CABLESCUM is offline   Reply With Quote
Old 02-19-2017, 12:49 PM   #52
rustytruck50
rustytruck50's Avatar
Man, talk about being in the right place at the right time...massive score!! Like the direction you're going on the build!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 09-11-2020, 05:18 PM   #53
CABLESCUM
CABLESCUM's Avatar
Well, I’m off FB and back on the forum(where there is more sanity&#128514🤘🏼
Since I was on here last, I did:
Quicky paint job til I take it off the frame.
Tubular upper/lower control arms.
Tubular trans and trailing arm crossmembers.
Tubular trailing arms(heims in front), I built them.
Buckets/console out of a 2019 Toyota Sienna(leather).
67 Cowl hood.
3.5/5 drop.
Tilt column/Forever Sharp steering wheel.
Then I decided to bag it, so I’m halfway through that lol
I’ll post some random pics of that stuff as soon as I remember how😂
Old 09-11-2020, 05:28 PM   #54
CABLESCUM
CABLESCUM's Avatar
After the satin black and static drop...
Old 09-11-2020, 05:33 PM   #55
CABLESCUM
CABLESCUM's Avatar
Tubular control arms and crossmembers, Hooker 2455 Chevelle headers...
Old 09-11-2020, 05:37 PM   #56
CABLESCUM
CABLESCUM's Avatar
Trailing arms I made, angled for the drop(for good pinion angle)...
Old 09-11-2020, 05:40 PM   #57
CABLESCUM
CABLESCUM's Avatar
Whoops, forgot to hit “upload”...
Old 09-11-2020, 06:20 PM   #58
CABLESCUM
CABLESCUM's Avatar
The seats required some bracket gabbing...
Old 09-11-2020, 07:03 PM   #59
CABLESCUM
CABLESCUM's Avatar
How it looked and sat before I started bagging it...
Old 09-11-2020, 07:04 PM   #60
CABLESCUM
CABLESCUM's Avatar
Plate on an actuator for those pesky photo intersections...
Video wouldn’t load lol
Old 09-11-2020, 07:15 PM   #61
CABLESCUM
CABLESCUM's Avatar
Bagging it because I got tired of trying to calculate tire height and all that, I’ll just put it where I want it. Not trying to lay frame, but it’ll go low. Frame rests on the trailing arms, so I’m going to notch/box the frame(just a little notch to clear the arms). Slam Specialties SS7 bags all around, 2 Viair 480C pumps.
Step notch and such...
Old 09-11-2020, 10:03 PM   #62
CABLESCUM
CABLESCUM's Avatar
Here are a couple pics of the headers. I know there are threads on here about the Hooker 2455s. They do bolt up, but it’s not as simple as that. They dump right into the trans crossmember, so you have to go tubular or chop up the originals. Also, they go directly where the antique shift linkages(on an automatic), so I did a Lokar cable conversion...
Old 09-12-2020, 12:22 AM   #63
cornerstone
cornerstone's Avatar
Very cool man... I saw a thread a good while back about making trailing arms and considered it for the same purpose as you. Do you remember what angle you used to correct for the new lowered ride with bags? Any info would be great. I'm gonna have to do something since my pinion angle is way off now.
Looking good brother
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 09-12-2020, 02:28 PM   #64
CABLESCUM
CABLESCUM's Avatar
Thanks man. When I did the 5” drop I got the vibration from the bad pinion angle, so I put in a tubular crossmember with different mount holes for the drop. That almost had it right. Then I got some of the angled shims because I figured I’d go another inch lower, and it would put everything about right.
You could flip the brackets on your crossmember to get real close for free, and an afternoon.
When I made the arms, I did it the redneck way lol. Traced it on the welding table, then put the shim on it and drew a new line. Sorry I don’t remember the exact angle. I threw those notes out when I sold that house.
It’s not really too hard to make the arms. I’d definitely recommend the heim joints so you can go back and forth an inch. I got those and the bungs off Barnes 4WD. Really quality American made stuff. The ones I got are rated at 38K lbs or something like that lol
Old 09-13-2020, 10:32 AM   #65
Stickman
Stickman's Avatar
Cool truck and a Chandler fella on top of that.
Stickman is offline   Reply With Quote
Old 09-13-2020, 03:30 PM   #66
CABLESCUM
CABLESCUM's Avatar
Yessir, I’m at AZ Ave/Queen Creek Rd
If you ever hit any of the Arizona C10 Club(Facebook) meets I’m always there. We’ll be at the next one in my kids square. If you see it, come holler at me🤘🏼
Kinda easy to spot, it’s a roundeye with the elusive square headlight option...
Old 04-05-2024, 09:43 PM   #67
CABLESCUM
CABLESCUM's Avatar
I fell down The Rabbit hole and just clawed my way out😅
Built my own 4 Link, Watts Link, exhaust, put in a 4” shaft, countless other things. Only projects I can do in a weekend from here on out lol. Back on the road
