02-02-2021, 08:38 AM | #51 | |
Re: NV4500 swap installed and rollin!
Are you sure the extra 1.5 of length didn't show up in the t-case swap? I've had my hands on three transmissions simultaneously; a 4wd sm465 with the factory hydraulic bell, a 1993 4wd nv4500 with the factory external slave bell, and a 1997 4wd nv4500 with the factory internal slave bell. All three measured within a half inch of length from the engine block to the transfer case mating surface. The trans mount point was the same as well.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-02-2021, 08:45 AM | #52 | |
100:1 low gear! |
02-02-2021, 12:56 PM | #53 |
I just went thru Larry's thread recently as I am planning a swap. Looks like the ticket is a late round pattern 205, with the early short 32 spline input swapped in. Then it should bolt up to a 4wd NV4500 with no mods, other than clearance for the shift rail. ORD can supply the input shaft.
ORD apparently also has a good twin stick shifter setup with brackets as well. Likely the path I will go as it's proven. |
02-09-2021, 09:39 AM | #54 | |
E.H.F.D Engine #2
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
02-09-2021, 10:17 AM | #55 |
AA sells new, rebuilt trans. You're money ahead going that route in the end...and a lot less headache.
02-09-2021, 10:58 AM | #56 |
E.H.F.D Engine #2
I know, I know. I just looked on Summit: trans, bellhousing, clutch with tax & shipping- $3261. That’s going to hurt, but will definitely ensure I won’t have to touch it for a long time.
