Old 09-26-2003, 08:33 AM   #51
tom hand
CCRider
tom hand's Avatar
I suggested the pilot bushing in my first post...If the pilot bushing is worn to allow the input shaft to move enough to cause problems, the bearing on the input shaft is toast. Replaceing the bushing may solve the problem for a while, but it will come back to haunt you.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-26-2003, 09:02 AM   #52
biglou55
Jewels I would check the linkage for full throw put tranny in third gear get under the truck unhook that linkage rod and see if the tranny lever can be moved farther into third gear. If it can adjust it accordingly make sure second gear still catches too. If all is fine it couldbe the input bearing which stabilizes your cluster gears. a bent or worn out shifting fork. worn syncro.s. you could have lost a balance pad on your drive shaft. that is causing the vibes at a higher speed. these trannies are not hard to rebuild if you pay strict attention to the way you take them apart. good luck. I have seen all these problems cause the tranny to disengage.< kick out of gear.>
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 09-26-2003, 10:30 AM   #53
ts71281
Jewels this is the easiest way to put all your questions to rest. Simply crawl under your truck, shove your trans into 3rd gear and remove the linkage. If the linkage is hard to remove once your trans is in 3rd I would assume it's out of adjustment. Otherwise leave your trans in 3rd gear and REMOVE the linkage from the trans. Get back in your truck and go take it for a spin. If it drives fine with NO LINKAGE ATTACHED then it's the adjustment of the linkage rod. I'm going to bet you anything that driving your truck now at HWY speeds with no linkage attached is the smoothest your truck has been in a long time. Don't worry, your 350 should pull from a dead stop in direct drive just fine. I know my 454 does That 3spd Saginaw isn't an easy transmission to hurt. I am the only person on the board who has a 500 HP 454 sitting in front of a 3spd saginaw in my 70 shortbed. If you lived near or in MN I'd let you take it for a spin and then you'd know how a 3spd is supposed to shift. And those myth's about not being able to speed shift a 3spd? Keeping everything greased well and adjusted properly will have you shifting as fast as 99% of most other people on the road. Ever race someone on the street with a stick and hear that 2 second delay between gears as they're trying to "speed shift"? Anyways back to my reply. Yes Jewels, remove your linkage to your trans that goes to the 2/3 arm and manually put it in 3rd by hand and if you want find a big hill to assist you in getting your vehicle up to speed before you let the clutch out but go for a drive and see how it runs. Like I said, I'm willing to bet you it performs flawlessly. No sense in yanking the whole trans out to find there's no problem with it. Those Saginaw's aren't the lightest trans around. Try taking one out with no trans jack and using your chest as the trans jack . Good luck and let me know what you find out.
Joe Hirdler
Maple Grove, MN
ts71281 is offline   Reply With Quote
Old 09-26-2003, 10:52 AM   #54
jewels.
jewels.'s Avatar
Originally posted by ts71281
Jewels this is the easiest way to put all your questions to rest. Simply crawl under your truck, shove your trans into 3rd gear and remove the linkage. ...... Otherwise leave your trans in 3rd gear and REMOVE the linkage from the trans. Get back in your truck and go take it for a spin. If it drives fine with NO LINKAGE ATTACHED then it's the adjustment of the linkage rod. I'm going to bet you anything that driving your truck now at HWY speeds with no linkage attached is the smoothest your truck has been in a long time. Don't worry, your 350 should pull from a dead stop in direct drive just fine.
hmm - this is an easy thing to do, and i will probably take a few minutes and try this.... interesting point....
i am having thoughts of taking up fine69 on his offer of a free tranny in the coming weekends (a free tranny is cool) - but thats only if i discover that the problem truely IS the tranny... first, i would like to eliminate the linkage problem...
don't worry - i am taking all of you suggestions to heart - there are all kinds of ideas here, and i will make sure to start with the easiest fixes and cheapest fixes first, and move on to the harder ones if the problem isnt remedied....
i think i'll try that linkage removed thing this afternoon if i get the chance... i'll let you know the results...
thanks!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 09-27-2003, 12:14 AM   #55
ts71281
Well I have to know. How did it go
Old 10-04-2003, 01:41 PM   #56
ddsmith
Glowing since 1978
ddsmith's Avatar
Any updates on the popping out thing. I figured this was getting buried so I brought it back TTT.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 10-04-2003, 08:59 PM   #57
jewels.
jewels.'s Avatar
ok, well, i havent yet taken the time to pull the transmission apart and look inside.... but i am in the process of graduating, submitting a thesis, defending my thesis and packing and moving to kansas city....
i DID happen to drive it another 250 miles last weekend, but i drove it at 65 and under (thru lots of rain and wind), and there were no problems....
if i actually had the chance to drive 70-75, i'm sure it would have repeated itself.... but the weather would not allow that....
because of the moving and stuff, i wont get a chance to look at it in the next week.... perhaps i will have a chance to look at it once i arrive in kansas city.... i am almost certain that it is a transmission problem, and NOT the shifting linkage....
i have been focusing on getting prepared to tow my pretty truck behind the moving van.... so i have been preoccupied with other things... (towbar, lighting harness, etc)...
so, i suppose i will have to leave you hangin for another week or two until i am settled in my new place in KC....
sry!
jewels.
Old 10-04-2003, 09:06 PM   #58
gr8scott51
gr8scott51's Avatar
make a call
Get al of those KC bowtie boys to help you move and provide the beer (and opinions) while you work on your truck.
Good luck in everything,
Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
