10-07-2016, 11:48 AM | #51 |
laying low
Re: crate 350 no oil pressure
Its worthwhile testing that pump. You can get a new pump that is bad. I once installed a rebuilt engine in a car for a man who owned a napa store. His own machine shop remand the engine. I just installed it for him. Guess what. No oil pressure on start up. That taught me to prime all engines regardless of who built it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-07-2016, 01:24 PM | #52 |
did you take the pump apart just for a look?
1961 chevy K10 my build is------------61K10 build |
10-07-2016, 03:56 PM | #53 |
yeah I was sitting there drinking a corona ticked off about the motor and decided to blow air through the galley's. I pulled the filter and blew air through there and behind the intake were the oil gauge goes and pulled the oil pump and blew air there to. put it all back together with oil first 10 seconds of hitting it with the drill oil shot up from the gauge hole all over my garage. I felt like of the Jed Clampet. so this morning I hit it again till oil started to come out of the lifters but my drill started to smoke so I called it quits till tomorrow.
10-07-2016, 03:57 PM | #54 |
I also need to re torque my main bearing. I did it 60 lbs. I believe its suppose to be at 70 lbs.
10-07-2016, 05:44 PM | #55 | |
*** That's interesting ***
But the good news is that you have oil pressure now! I think we asked this before, but are you sure your gauge works? Can you have someone watch the gauge while you drill it? I have an aftermarket capillary tube oil gauge that I pulled from a car in the junkyard years ago that works great. It has easily readable tick marks for PSI. If I am by myself, I can temporarily plumb in that gauge while I spin the primer. This is an option if you don't have someone to help. So summarize what you've done to solve this? Because it couldn't have been solved on its own...
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
10-07-2016, 05:55 PM | #56 |
I ran the stock one and it didn't move so I ran a electric one I had on another car and that one didn't mark either. so either I had blockage or some valve had gotten tripped. or I just didn't hit it hard enough with the drill. I am using a 1/2 drill but its a harbor freight drill to LOL
