02-09-2019, 07:50 PM | #51 |
Re: Project "CREWMAX" Just another crewcab build....
We section cut a portion out of the sloped rail section of frame to bring it lower, then section cut the frame in the flat to shorten it.
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
02-09-2019, 08:56 PM | #52 |
I am curious why you didn’t just move the axle forward and cut off the excess frame? That’s what I’m planning to do with mine so you got me wondering.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
02-10-2019, 11:38 AM | #53 |
The C30 cab and chassis rear section raises up more than the typical c10/c20 frames. This wouldn't allow the body line to match up correctly without raising the body without raising the bed ( which I could have done). In order to fix this we lowered the rear section then shortened the frame
02-10-2019, 01:36 PM | #54 |
6600DURAMAX
Did you happen to take pictures of your frame modification? I have a 157" frame I am using also and have been looking at all my options when I get to that point. Thanks
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
02-10-2019, 02:31 PM | #55 |
Post 39 you can see the frame weld.
I was thinking I could change all the bed floor supports and replace them with the shorter ones like in the center. But I’m with you on frame showing, this tall frame will already have extra hanging down. I appreciate the response, would hate to discovered something else down the road
02-10-2019, 05:09 PM | #56 |
MaddKidd - I thought the same thing about switching to the smaller supports but in the end it wasn't that much extra work to just lower it by removing that piece from the sloped portion of frame.
I will try to get a few more pics. It is just tacked right now, I need to have some plates cut to go on the inside of the frame one of these days
02-10-2019, 05:33 PM | #57 |
I’ve thought about it before in reference to you playing the frame. Do you have any old frames you could cut a section out of and use it to reinforce. Would think you could slice it in the middle and would be stronger having the 90 degree bend like a piece of angle iron.
02-10-2019, 06:00 PM | #58 |
builds looking good! i had pondered between a 133" and 157" wb c30 frame. I ended up going with a 133" and had material broken to stretch in the center. I was debating cutting down the top of the 157" frame rails or changing bed crossmembers. Sounds like you cut down the frame rails to work with stock bed?
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
06-21-2020, 09:32 PM | #59 |
SWB 4x4 Collector
How’s the progress coming?
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
