Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 05-25-2018, 09:14 PM   #51
diveplane
Re: My Chevy 1500 W/T 94 V6
Originally Posted by Big Daddy Bear View Post
Looks good, feels good to check a few things off the list, don't it?
yes it was great to restore the truck ... now am starting to focus on my boat next.
diveplane is offline   Reply With Quote
Old 05-26-2018, 08:08 AM   #52
mingoman
What kind of boat you working on DP?
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 05-26-2018, 08:37 AM   #53
The truck cam out great. Glad someone else likes the ole V6
Old 05-26-2018, 01:50 PM   #54
diveplane
its a 1979 glastron 15 foot fibreglass speedboat.
with a 1979 johnson stinger outboard rated at 75hp
Old 05-26-2018, 01:51 PM   #55
diveplane
thx i love the v6 engine mine is stick shift to, love it.
Old 06-19-2018, 01:57 PM   #56
diveplane
another little update installed a nice addition hitch brake and rear light LED combo looks fantastic on truck.
Old 06-19-2018, 04:00 PM   #57
diveplane
i had a issue with stop lights not engaging, and i lubed the piston going through firewall
waa la the brake lamps work flawless now.
these year of trucks its a known design issue. other thing to check is stop lamp switch, and of course your fuse.
so anyone else having brake lamp issue try this fix.
Old 06-19-2018, 04:03 PM   #58
Glad you are still getting to do things on the truck. Thanks for the brake tip. I'll probably forget it before I need it though
Old 06-24-2018, 03:26 PM   #59
diveplane
got tool box back on polished , tip for anyone else , used rubber padding on outside edges on bed and lined inside with padding to reduce vibration noise.
next up is polishing the alloy rims.
Old 06-24-2018, 03:32 PM   #60
diveplane
new bright orange led lamps installed keep it authentic like from factory.
Old 06-24-2018, 04:25 PM   #61
Big Daddy Bear
Big Daddy Bear's Avatar
Looking good!!
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 06-25-2018, 01:14 AM   #62
diveplane
Here's the alloy rims, started wet sanding them to a high shine finish.
Old 06-25-2018, 07:43 AM   #63
Those came out nice!
Old 06-27-2018, 04:44 PM   #64
diveplane
thx and they are not even polished yet either.
Old 07-11-2018, 06:33 PM   #65
diveplane
on the final stages of polishing rims, the product am using is mothers alloy rim polish and protect, its amazing guys.
Old 09-30-2018, 11:37 AM   #66
diveplane
got the decals all on and edge sealed , same as factory with the addition of 4.3L vortec decal on tailgate compliments it nice.
side doors have 1500 decals and chevy symbol.
looks fantastic.
Old 09-30-2018, 11:41 AM   #67
diveplane
https://www.amazon.com/sealitpen-Sea.../dp/B000FT56OQ
highly recommend applying decals with the wet method, soapy water , this allows you to move the decals around on painted surface , takes a few hours to dry, wipe clean gently
then you can apply seal it pen edge sealer to decals, this extends the life of your decals.
Old 09-30-2018, 11:46 AM   #68
diveplane
next task is final light polish for alloy rims then installed.
Old 09-30-2018, 02:29 PM   #69
Big Daddy Bear
Looks great!
Old 09-30-2018, 04:31 PM   #70
diveplane
thx bud..
Old 11-22-2018, 12:09 AM   #71
diveplane
nice pick of truck warming up cold morning chu chu..
Old 11-22-2018, 12:10 AM   #72
diveplane
decided to take tool box off going with a cover later date and low profile box soon.
Old 12-23-2018, 10:10 PM   #73
diveplane
another little sweet upgrade some mud/water spray flaps for my truck, fronts installed...helps reduce road tar and paint chip as well.
Old 12-25-2018, 12:19 AM   #74
straight6chevyguy
straight6chevyguy's Avatar
Nice!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 12-25-2018, 01:19 AM   #75
diveplane
thx bud..
