Old 12-27-2016, 03:10 PM   #51
doubleds19666
doubleds19666's Avatar
Re: 2010 L99/6L80E swap into 95 C1500 Silverado
This is a picture of the VSS mounted on the rearend for the 40 tooth reluctor kit form jagsthatrun. I had to modify the connector to fit after modifying the bracket. The modified sensor they sell would work the best if not modifying the connector yourself.
"Grandpa's Truck"
1974 C10 ZZ4/L98/TPI
Tubular Trailing Arm conversion
5/7 drop with 4 wheel 13" Baer disc brakes
doubleds19666 is offline   Reply With Quote
Old 12-28-2016, 02:35 PM   #52
doubleds19666
Uploaded a video to show the GSS-2000 interface circuit in action via the gear indicator lights in the instrument panel.
https://www.youtube.com/watch?v=mHMtN7LOeKc
"Grandpa's Truck"
Old 01-04-2017, 07:37 PM   #53
doubleds19666
Just ordered the new coolant temp sensor: ACDELCO 12551708
and connector pigtail: STANDARD MOTOR PRODUCTS HP4440
I will keep you all posted on what value resistor is needed to make the temp gauge read what the ecm is getting. The ecm temp sensor works fine, but the sensor for the gauge is about 30 degrees too low while driving due to the adapter from S&P. I calibrated it at idle in park, go figure. Without the 47 ohm resistor already installed on the printed circuit it was reading pegged out(about 60 degrees too high).
"Grandpa's Truck"
Old 02-21-2017, 11:55 PM   #54
doubleds19666
I haven't had time to change out the ECT yet due to my other truck hydrolocking after a fuel injector failure(stuck open). I will be focusing on that as it should be cheaper to fix than the upgrades in store for this build.
By the way, I developed the dreaded tick/tap that these L99s are known for after 2 months of driving it. Next step for it is a Texas Speed and Performance AFM Delete, VVT-1 cam upgrade, 3000 stall converter, and some version of a locker in the back. What good is all the power if I can't hook? My tire dealer is happy...
http://67-72chevytrucks.com/vboard/i...ilies/waah.gif
"Grandpa's Truck"
Old 03-06-2019, 09:00 PM   #55
doubleds19666
Here is an update:
The Eaton style posi, carrier bearing stud kit, and Moser diff cover are finally installed. I also installed the BellTech lowering kit, BEL-686SP. I didn't like how high the rear still sat after the install.
I took the springs out and asked the local spring and axle shop to de-arch them. Now it sits like a 3/5 drop should. A couple of pics, one just the 95 and another next to an older square body.Name:  20180406_213942.jpg
"Grandpa's Truck"
Old 03-08-2019, 10:04 PM   #56
cornerstone
cornerstone's Avatar
Such a nice truck, you nailed the ride height perfectly in my opinion. What rear gears did you go with? Also, did you ever mess with the TUTD?
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-08-2019, 10:39 PM   #57
doubleds19666
Thank you for the kind words. I am still using the stock 3.41 gears. I enjoy the economy and still get the seat of the pants feeling when I need it.
I made a push button TUTD controller and wired it in. I didn't reprogram the pcm in the trans to the Corvette, but I did reprogram the ecm to use TUTD, which didn't work well. The truck drove like it had tourettes. I immediately pulled over and unwired the controller and put back the old tune. Never did anymore research. I should follow up on it. Any recommendations?
"Grandpa's Truck"
Old 03-09-2019, 12:07 AM   #58
cornerstone
Unfortunately not. I was hoping you would inform me!
Brian
Old 03-09-2019, 12:20 AM   #59
doubleds19666
I'll post what I do have and follow up on the research. Might be a couple weeks. Help me stay on track and ask again please.
"Grandpa's Truck"
Old 03-09-2019, 07:46 PM   #60
doubleds19666
Found the info I looked at before when trying the hardwired method. Link here: https://www.google.com/url?sa=t&sour...0_BiQZFOBmYsZV
Don't know if it works, but would be a good place to start. Reading how long it takes for the TUTD switch command to respond I probably wouldn't use it, but getting into Sport mode to use a separate table of shift points would be fun.
"Grandpa's Truck"
Old 03-10-2019, 12:30 AM   #61
kipps
You mentioned you would use the three pin coolant temp sensor. Have you installed that? How has it worked?
kipps is offline   Reply With Quote
Old 03-10-2019, 10:10 AM   #62
doubleds19666
I haven't installed it yet. I let one of my friends try it for his son's 5.3 swap. Not sure how that panned out. The swap is done but the truck is put back together yet to drive.
Has any one else tried it? I just started posting again. It is amazing how much is forgotten once life resumes after a build.
"Grandpa's Truck"
6l80e, c1500, l99, ls3, swap
