Old 09-16-2017, 08:13 PM   #51
brian1971
brian1971's Avatar
Re: OMG Honda door weatherstripping fits perfect no cutting required !!
Jfnar they are way to short.
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 09-17-2017, 12:16 AM   #52
dgheinen
Originally Posted by Grumpy old man View Post
You may as well drop a honda 4 cyl in too while your at it , and some back up cameras ,a bunch of led's and maybe drop it on bags mounted to a rusty frame and take it to the ground and hey why not hack out the dash and install a chinese stereo and amps with some boom speakers ? so you can't hear that fart can exhaust ? and hey some cheap aftermarket race seats would fit right in ?
I'll never understand the instant gratification generation ...
Wow! Somehow, someone finding a great solution to a common problem in a cost effective and efficient way is a bad thing.
dgheinen is offline   Reply With Quote
Old 09-17-2017, 10:32 AM   #53
jfnar
Ok, thanks. The U Pull it near me doesn't have any 2 dr hondas and only one 4 dr. I may get the ones from the 4 dr and splice them.
jfnar is offline   Reply With Quote
Old 09-17-2017, 07:10 PM   #54
907debow1234
Thanks for this helpful hint.. I plan to snag new gaskets off a scraped civic tomorrow. .
907debow1234 is offline   Reply With Quote
Old 09-21-2017, 10:10 PM   #55
brian1971
brian1971's Avatar
Found another set of the Honda door seals today at the Fort Lauderdale LKQ U-Pullit.They are the Graphite color and are in good shape.I took them off they are inside this car.
Old 09-22-2017, 09:09 AM   #56
67ChevyRedneck
67ChevyRedneck's Avatar
Originally Posted by crakarjax View Post
Found it, ex 72310-SVA-A01 - $50 each
Are they the same R to L?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-22-2017, 09:41 AM   #57
brian1971
brian1971's Avatar
They are different.Same side will work but join mark will be in different location.
Old 09-23-2017, 01:13 AM   #58
Greasey Harley
Greasey Harley's Avatar
Originally Posted by '70_402 View Post
With this ideology you should still be using an points ignition... are you? Cause why fix something that's not broken, innovation and an open mind are useless right?
My truck still has points.
Electronic ignitions are pointless.
Greasey Harley is offline   Reply With Quote
Old 09-25-2018, 12:34 PM   #59
Hvychvy970
Originally Posted by mrlobster View Post
Put a set of Honda door seals on my 72 GMC tonight- fit was near perfect, just had to cut it and trim about 1.5" from its total length. The doors shut with just the right amount of effort- no slamming necessary!
I had a set of Precision push-on seals prior and the doors were near impossible to shut. They are a quality product, just didn't fit right for me.
I just ordered some new seals. They don’t seem to have a lip to slide over the door seal channel. Is this what yours look like?
Hvychvy970 is offline   Reply With Quote
Old 09-25-2018, 01:45 PM   #60
brian1971
brian1971's Avatar
Those look like the wrong year or model,what year did you order.
Old 09-25-2018, 01:58 PM   #61
Hvychvy970
I ordered for a 2008 2 door.
Here is the link... https://www.hondapartsnow.com/genuin...0-sva-305.html
Old 09-25-2018, 02:12 PM   #62
brian1971
brian1971's Avatar
The part number is right but they sent you earlier model or there for an Accord.
Been awhile since I was at junkyard looking at them.
Old 09-25-2018, 02:13 PM   #63
brian1971
brian1971's Avatar
See how the ones you have are cut on the bottom for sill panel.The civic ones don't have those cutouts.
Old 09-25-2018, 05:19 PM   #64
panhead59
That hondaparts now link shows part # ending in 305. A01 WAS STATED AS BEING CORRECT #. ????????
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 09-25-2018, 05:30 PM   #65
panhead59
305 replaced A01. MIGHT have something to do with them being wrong.
Old 09-25-2018, 05:42 PM   #66
TKCR
TKCR's Avatar
Originally Posted by volksworld View Post
went to grab a set off a 2008 at LKQ today...the seal has an extra inner lip about 3/4 of an inch wide that covers the edge of the upholstery on the honda...not sure if it will touch the metal around the door frame ....looks like it may have 1/4 inch of standoff when installed....unfortunately the car i found had a light grey interior so this lip was grey 3/4 of the way around and black where it went under the rocker trim panel....so i guess these will only work if you find one with a black interior...at least it wasnt the only thing i went there for...
What you got and ordered, was the door weatherstrip. It actually goes on the door. What everyone is using, is the open seal. It goes around the opening of the car itself. That's why it's called an Open Seal.
Old 09-25-2018, 05:49 PM   #67
TKCR
TKCR's Avatar
https://www.hondapartsnow.com/Page_P...ds=Open%20seal
These are the open seals
Old 09-25-2018, 05:59 PM   #68
OregonNed
OregonNed's Avatar
I could yank them out of my '06 coupe that I hardly drive!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-25-2018, 06:08 PM   #69
Hvychvy970
Originally Posted by TKCR View Post
Ok. So these are the correct ones? Is gray the only color they make?
Old 09-25-2018, 06:18 PM   #70
TKCR
TKCR's Avatar
Here's the black. They actually come in grey, black & ivory
https://www.hondacarpartsdirect.com/...SABEgLbr_D_BwE
https://www.hondacarpartsdirect.com/...1ob25kYQ%3D%3D
Old 09-25-2018, 07:14 PM   #71
elorenzof
Originally Posted by Precision Parts View Post
Just an FYI, we make the push on style specifically for the 60-66 and the 67-72 which have the correct radius molded corner. You can see our install video here:
https://youtu.be/Ka5nMS05WIk
- Derek
Hello, what is the part number specifically used in the video?
elorenzof is offline   Reply With Quote
Old 09-25-2018, 07:18 PM   #72
tdangle
tdangle's Avatar
Might have to give these a try. I have tried the glue on ones, had to slam the doors. Bought a set of Precision push on ones that were suppose to be the best and still have to slam the door. To me it seems as if the push on part holds the rubber too far out. Getting tired of buying the same thing over and over. Either that or not run seals, then the door shuts so nice.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-25-2018, 07:22 PM   #73
panhead59
Why won't precision address the fitment issue ? They make good stuff but are really hurting their reputation with these door seals. IMO
Old 09-25-2018, 07:42 PM   #74
NC_John
NC_John's Avatar
I've had my precision push-on door seals installed for years now. Still not "broken in." I doubt they ever will so I give up and am doing something else too. I am so freaking sick of slamming the doors over and over.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 09-26-2018, 11:15 AM   #75
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The push on seals from Precision I have installed in my 1972 GMC fit flawlessly and they have never needed a "break in" period. They seal great and the doors open and close like they did when the truck rolled off the assembly line. These seals are a great product.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
