Old 06-26-2018, 08:28 PM   #51
Ramjet51
Re: Ramjet51 67 SBFS BUILD
I’ve cruised these pages, projects and probably missed the installation of mini rotary latches on the tailgate...why do this?
1. I like that I can hide them
2. I can remove the tailgate handle
3. I’m attempting to use stock bolt holes in tailgate and bed side
4. I’m doing this cheap..$30 for latches, $5.38 for two shoulder bolts, my time is free...I’m retired
I’m using a “Southco” latch and when I’ve got them totally adjusted and happy, I’ll probably replace with SS units. So, if you’re debating how robust these mini latches may be...they are rated at 1100 lbs.
Photo one is the latch
Photo two is where I build a plate to fit the original latch holes in the tailgate
Photo three is the latch mounted to the plate
Photo four is a bolt in position to give an indication of the striker bolt position
Photo five shows one side assembled, plate with chamfered holes and bolts used for assembly
My next post will show some additional details on building striker bolt mount....I’m using hardened shoulder bolts...
You'll never know unless you try
Ramjet51 is offline   Reply With Quote
Old 06-26-2018, 08:42 PM   #52
Ramjet51
Just in case you may be wondering, I did chamfer the holes in the plate.
1. The position required to mount the latch covers the lower bolt, therefore that bolt must be flush.
2. The lower latch bolt on the back needs to be flush as well to allow flush mounting of the plate to the bed
3. I tighten the lower bolt to the bed with a T handle Allen wrench between the latch jaws...
Old 06-26-2018, 09:06 PM   #53
Ramjet51
I finally mounted the gas cap on the tank, although not meant to be, I drilled holes on the cap and made a wrench to turn the damn thing, I could never use just my finger to get it open. I also used a “Gates” powergrip heat shrink connector instead of hoses and clamps.
Old 06-27-2018, 09:07 PM   #54
Ramjet51
Back to the striker bolts, they’re in but 1/4” too long, need to get shorter ones. Actuation links are in
Old 07-04-2018, 06:52 PM   #55
Ramjet51
Picked up some tie downs at LKQ, probably paint same as bed
Old 08-12-2018, 08:30 AM   #56
Ramjet51
I’ve been looking for a better look for the rear bumper...when the hotrod power tour came to Raleigh, I noticed that the Chevrolet performance 67 C10 had a modified rear bumper. It was really hard to see the shape but finally found a photo on the net that I could lighten to see the shape. Here it is...
Old 08-12-2018, 08:35 AM   #57
Ramjet51
So...this is how to ruin a perfectly good bumper, albeit an aftermarket unit. First I attempted to map it out..
Then decided the cuts.....
Old 08-12-2018, 08:36 AM   #58
Ramjet51
Made the cuts
Old 08-12-2018, 08:40 AM   #59
Ramjet51
Tacked and shot some paint to see the “look”......later today I’ll finish welding, grinding and throw some filler on it...I’ve also welded up the lower slots and holes to give a cleaner look...
Old 08-12-2018, 12:08 PM   #60
rustytruck50
rustytruck50's Avatar
Awesome!!! I think you pretty much nailed it!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 08-12-2018, 07:03 PM   #61
Ramjet51
On the truck.....now I’ll have to weld on the bolts while adjusting the fit to be higher than stock...little more work...
Old 08-12-2018, 07:36 PM   #62
Raleighswb
Looks good,the details make all the difference! Which bedsides did you use?
Raleighswb is offline   Reply With Quote
Old 08-12-2018, 11:04 PM   #63
Ramjet51
Originally Posted by raleighswb View Post
looks good,the details make all the difference! Which bedsides did you use?
lmc fleetsides
Old 08-13-2018, 08:36 AM   #64
KevinK7
KevinK7's Avatar
Nice work, that bumper looks great
KevinK7 is offline   Reply With Quote
