Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 01-12-2018, 10:47 AM   #51
SCOTI
SCOTI's Avatar
Re: Fastfreddys 454ss
Originally Posted by fredscarryall View Post
The bed is already on. I took a couple pics of the upper bags mounts before I put the bed on,but I can’t find them. The air bag mounts are built into the upper bar.I will take a couple shots from underneath with a tape measure and let you know tonight
I was wanting pics of the upper bar front mounts, possible measurement on the difference between the center line of the upper vs lower front rod end bolt, & length of the upper bar as installed on your truck.
The install instructions have a starting dimension for the upper bars. I was curious how close your set-up came to those dimension as I will be building my own upper bar front mounts (I'll be using better rod ends on the front of all 4 bars on my set-up) & the info requested will help dictate how things fall into place (your info will be used just as reference compared to my observations/mock-up).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-13-2018, 03:35 AM   #52
fredscarryall
fredscarryall's Avatar
Finished the coolride today. Didn’t change the look. Right now I can’t lower the truck anymore without the fender sitting on the tire because of the front wheel spacers. As soon as I put in the front pro proformance front disc conversion which will bring the wheels in about 7/8 (because I had the front hub converted to 5 on 4 1/2 to get rid of the conversion wheel spacer)and roll the front fenders a little more. I will be able to lower it another 3 or 4 inches. I also need to adjust the pitman arm in the rear to center the axle and roll the fenders a little more with a baseball bat.
fredscarryall is offline   Reply With Quote
Old 01-13-2018, 03:53 AM   #53
fredscarryall
Look what showed up today. I can’t beleive the size difference in the rotors. These are based off of the c5 corvette
Old 01-13-2018, 03:56 AM   #54
fredscarryall
Ordering caliper covers from mgp
Old 01-13-2018, 04:23 AM   #55
fredscarryall
Going to order a 10 pt roll cage from s&w. I going to get the wrap around dash style. I think it looks a lot better. The only bars I won’t put in are the ones that go thru the Back window to the bed and the door side bars.
Old 01-13-2018, 05:44 AM   #56
fredscarryall
Don’t like the velour seats and door panels. Since I already have my factory seats in storage. I going to remove the original door panels and store them also. I saw a picture of manual door panels a while ago and bought a set off ebay.
Old 01-13-2018, 05:49 AM   #57
fredscarryall
I got board and did a renduring of what I going to do. Drawings kinda suck, but you get what I’m going. My uphostery shop is out about a month. So they will be done in a while. Going to wrap both in red vinyl with exposed stitch and maroon inserts
Old 01-14-2018, 02:23 AM   #58
fredscarryall
Cool item I came across. Dash insert sticker kits by RVINYL. They come in about 20 different colors. Cost $49.95. Make sure you wipes down contact areas with alcohol before applying and they will stick really good.Says will only fit 92-94. But will fit 1988 to 1994. Just won’t be able to use a couple pieces depending on year. Also available for suburban,Yukon and tahoes
Old 01-15-2018, 11:19 AM   #59
arrg
Did you have them do something custom for you in the c5 corvette size, or are they still the 14" kit?
arrg is offline   Reply With Quote
Old 01-15-2018, 06:23 PM   #60
fredscarryall
The 14” kit uses c5 corvette parts.I believe they used both the c5 caliper and disc(Makes it easy to go to the parts store and get Pads)With a Baer design mounting brackets and hubs.The only change I made was to convert the hub from 5 on 5 to 5 on 4 1/2 because of rim choices for an extra $200.
Old 01-16-2018, 01:37 AM   #61
nuke1
nuke1's Avatar
Love the truck!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-16-2018, 03:37 PM   #62
diveplane
I worked at as a detailed for the body shop at a Chevy dealership in 1990 and drove a few 454 ss trucks. I always said to myself one day I will own one. In July 2016 I finally bought on. It is a two owner with 60,000 original mile. Don’t worry for you purists out there, every mod I have done I have kept every part. So if I ever go back to factory i can.
sweet ride.
congrats
diveplane is offline   Reply With Quote
Old 01-18-2018, 03:54 AM   #63
fredscarryall
May go with this design for the seats and door panels
Old 01-18-2018, 04:05 AM   #64
fredscarryall
Started on the az performance revelator disc conversion today. Didn’t like the cast grey on the caliper. So I sprayed them red, until my caliper covers get here. Not everyone needs a step by step, but it’s nice to use as a reference.
Old 01-18-2018, 04:08 AM   #65
fredscarryall
The kit shows to remove the spindle, but I can do it without removing it. Drilled out two of the brake shield holes for the caliper bracket with a 3/8s bit.
Old 01-18-2018, 04:09 AM   #66
fredscarryall
Tapped both holes with a 7/16-14 tap
Old 01-18-2018, 04:12 AM   #67
fredscarryall
Put the hub on to see if everthing fit. I had to use the spindle nut off the belltech spindle. The one the came with the kit had the wrong thread
Old 01-18-2018, 04:18 AM   #68
fredscarryall
Next, I had to trace the caliper mounting bracket with it bolted on to get ready to cut the ears off the spindle. More to come
Old 01-18-2018, 04:33 AM   #69
fredscarryall
Ran into my first hang up. The Wheel hub bore is about 1/16 smaller then the hub. So I going to try one of three tools to bore the rim hub out. Or I may take the hub to a machine shop to get it turned down a 1/16.
Old 01-18-2018, 10:32 AM   #70
SCOTI
SCOTI's Avatar
What are the benefits here? Why is this necessary especially after removing 4 of the bars that maintain the integrity of the set-up?
Rear bars (to the rear portion of the frame) help the structure. Door side bars? Same thing. Any bars in the vicinity of your noggin w/o a helmet? Not a good idea. I've seen roll bars form fitted to the interior sheet metal (as in nearly touching the bare steel on early trucks) that might work but a cage like that in a street vehicle w/full interior doesn't seem worthy especially because you don't have protection for your head.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-19-2018, 03:52 AM   #71
fredscarryall
I thought out some of your points. I think I am going to take the back slider window out and put it in storage. Then replace it with a solid tinted Lexan and cut two holes for the bars that go in the bed. With a nice rubber gasket around the window and bars the go to the bed.Then I will do swing out side bars. I know they are not as strong as solid welded.but since I’m in a wheelchair I have to be able to transfer in. You have to admit though 4 attachment points will make the integrity of the truck stronger then stock.As far as my head bouncing around and hitting my head on a bar. I will be wearing a seat belt and my bars will be thick padded. Thousands of people have a full interior with a cage. May be a little less room, but if done right there is enough room. It’s not going to be a full on drag race or road corse truck
Old 01-19-2018, 03:56 AM   #72
fredscarryall
Cut the tabs off my spindle. If you aren’t using a band saw. Make sure you use a 6” cut off wheel on your hand grinder. 4 1/2 disc is too small.
Old 01-19-2018, 03:58 AM   #73
fredscarryall
Mock up
Old 01-19-2018, 04:11 AM   #74
fredscarryall
Before and after. Turns out, all I had to do to my wheel hub bore to fit was sand off the powder coat with a drum sander. took about 5 minutes. So far 3 hours into one side. The other side should only take 2 because I know exactly where to cut. Had to order 14x 1.5 lug nuts. Won’t be here till Friday night. So looks like I won’t be able to see how low it goes and how it stops and rides till next week. I finally found end caps for my lug nuts
Old 01-21-2018, 04:57 AM   #75
fredscarryall
For some reason when Baer brakes redrilled my hubs to 5 on 4.5. They uses the oddest size, a 14x2.0 metric stud. They sure make it tuff using that size. It really limits you options. Unfortunately because the lug nut holes in the rim are small, they don’t make a lug nut to fit. Looks like I’m going to drill out my 12mm lug nuts and retap them to 14x2.0. Only have to do 10. Should take a couple hours. Not so bad if that’s the worst thing to happen with a front brake conversion
