Old 08-12-2018, 01:36 AM   #51
Free Candy Inside
Re: 66 C50 Cummins build aka Big Stupid
I got the rear end welded up. I then made a battery tray. Sorry the pic is terrible. I wanted to keep the battery close to the starter so I decided to mount it on the side of the frame next to the drivers side front cab mount. I needed it to be close to he body for ground clearance but that makes it hard to swap or install cables. I got creative and I made side matching plates that have a slot in them and allow the battery tray to slice down 4” since this plates are welded to the frame and not the tray. Install the battery then slide it up into place and lock it down with the 4 bolts that go through the side brackets and into the lower battery tray. Works out great.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 08-13-2018, 06:25 PM   #52
SCOTI
SCOTI's Avatar
Sounds similar to an install I did. I mounted/bolted side flanges to the frame that are drilled for 4x 3/8" fasteners. I made a battery 'tray' that secures the battery & slides up/into the flanges on the frame. I use 2x unthreaded pins to temp hold the batt/tray in place while installing 2x of the 3/8" retaining bolts, then pull the pins & put the other 2 bolts in place.
I can use a floor jack if @ home/the shop but it can also be removed as long as you can bench press the initial weight of the batt w/tray. I built it to allow service regardless of where it is. The battery also has the top + side terminals for easy-ish jump start connections. Cumbersome, but serviceable. Definitely cleaned up the engine compartment.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-23-2018, 10:19 PM   #53
Free Candy Inside
Haven’t had as much time to work on the truck as I’d like. Been busy with metal orders and now I’m back to school teaching. Decided I needed an evening to unwind and work on the truck. Knocked out my center console with a Lokar shifter and some cup holders. Also got the rear end spring perches welded up and some shock mounts finished. I’m down to electrical and some other smaller items.
Instagram: jaked937
Old 09-03-2018, 10:22 PM   #54
Free Candy Inside
Got some time to make some radiator fan mounts.
Instagram: jaked937
Old 09-03-2018, 10:24 PM   #55
Free Candy Inside
Was a great day. Rigged some electrical stuff and managed to drive the truck out of the barn. I even gave it a bath!
Instagram: jaked937
Old 09-03-2018, 10:24 PM   #56
Free Candy Inside
Super stoked on how this build is turning out!
Instagram: jaked937
Old 09-04-2018, 06:09 PM   #57
hank scorpio
That's REALLY rad!
64 C10
A bunch of Volvos
Luthier
Simpsons Nerd
hank scorpio is offline   Reply With Quote
Old 09-05-2018, 05:42 PM   #58
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It's looking sweet!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-06-2018, 09:51 AM   #59
aggie91
I'm just glad to be here!
aggie91's Avatar
Man, this one has me really thinking of getting the C60 my cousin has at this shop...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-06-2018, 10:31 AM   #60
Free Candy Inside
Originally Posted by Dieselwrencher View Post
It's looking sweet!
Thanks!
Originally Posted by hank scorpio View Post
That's REALLY rad!
Thanks!
Do it!
Instagram: jaked937
Old 09-23-2018, 10:59 PM   #61
Free Candy Inside
Didn’t like how high and long the flatbed is so I decided to cut it up some.
Instagram: jaked937
Old 09-23-2018, 11:00 PM   #62
Free Candy Inside
Cut about 3’ off the end of the flatbed and cut the frame rails down to get it to sit lower.
Instagram: jaked937
Old 09-23-2018, 11:02 PM   #63
Free Candy Inside
Started making the notches to go around the wheels.
Instagram: jaked937
Old 09-28-2018, 07:53 PM   #64
mcnally351
mcnally351's Avatar
This build is awesome ! Great work
87 k5 silverado 4x4 350 38k stock
77 k5 Cheyenne 2wd 5.3 4l60e project
mcnally351 is offline   Reply With Quote
Old 10-29-2018, 09:11 AM   #65
Free Candy Inside
Slow progress. Teaching and my metal business got in the way the past couple of weeks. Combine that with a no start issue and I kept putting off working on the truck. This is my first diesel so I’m still trying to figure it out. I had a fuel issue so I replaced some lines and the lift pump. Still couldn’t get it to run. I kept trying to bleed the fuel system and continuously got air. Turns out while working on the flatbed the other day I disconnected the feed line at the sending unit and didn’t get it all the way clipped in. Once I finally found that and got it fully clipped on the truck fired right up. I then went on to work on the flatbed and got it mounted. Have a little more work to do to it then I’ll be ready for the wood and hopefully start driving it.
Instagram: jaked937
Old 10-31-2018, 08:36 AM   #66
Low Elco
Man, this is cool.
Low Elco is offline   Reply With Quote
Old 10-31-2018, 10:21 AM   #67
Lokin4AReason
Lokin4AReason's Avatar
liking the stance ....
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 10-31-2018, 01:15 PM   #68
Free Candy Inside
Messing with some wood for it. Trying to decide how I want to do it.
Instagram: jaked937
Old 10-31-2018, 09:02 PM   #69
joesscamaro
This is a really cool truck! Keep up the good work!
joesscamaro is offline   Reply With Quote
Old 11-06-2018, 11:34 PM   #70
Free Candy Inside
Welded up some plate on the rear of the frame for the hitch. Also made a rear light bracket with a recessed license plate frame. Overall I need this to be done and out of my shop before thanksgiving so I can get ready for the Christmas rush of metal orders.
Instagram: jaked937
Old 11-09-2018, 01:02 PM   #71
Free Candy Inside
A little more progress on the flatbed. Hoping to have it done by the end of the weekend.
Instagram: jaked937
Old 11-09-2018, 02:05 PM   #72
Indychus
Indychus's Avatar
Wow!! Badass truck!
Build Thread: Project Overkill 1968
Bagged & Blown Pro Street 1968 Short Fleet
Indychus is offline   Reply With Quote
Old 11-09-2018, 05:48 PM   #73
SCOTI
SCOTI's Avatar
What are you using for your wood (type, dimensions, planned finish)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-12-2018, 01:41 PM   #74
Free Candy Inside
1.5” oak rough cut I bought off of an Amish guy. Wasn’t planning on planing it down, was probably just going to leave it rough cut.
Instagram: jaked937
Old 11-13-2018, 07:04 AM   #75
Free Candy Inside
Have most of the wood cut down to size. Have to rip a few boards and then the wood should be finished.
Instagram: jaked937
