Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-16-2018, 02:36 PM   #1
gup1972
Re: 1969 C50 crew cab build
Originally Posted by *Subject2Change* View Post
Question. I bought a 69 c50 and Im going to swap in my 79 K3500 DRW axles in. Any idea how close the spring perches are to a 3500 axles? I dont have my hands on the c50 yet.
The frame width on a C50 is 34" to the outside. Not real sure what the perch width is on a 3500DRW. It will depend on the spring mounts you choose to use to mount the springs to the frame. It's easy to cut the perches off and weld a new set on when you get all shackles and springs, etc mounted to the frame.
gup1972 is offline   Reply With Quote
Old 11-16-2018, 05:57 PM   #2
*Subject2Change*
I'm picking my c50 up Sunday and the k3500 parts are at a friends house so its hard to plan. My 60 front perches are 32 so were def in the neighborhood. Thanks for looking.
*Subject2Change* is offline   Reply With Quote
Old 03-03-2019, 08:04 PM   #3
goldenburb
goldenburb's Avatar
Keeping a eye on this one. Good luck
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 03-05-2019, 02:59 PM   #4
Pvmt-Pndr
I'm watching now too! Nice progress
Pvmt-Pndr is offline   Reply With Quote
Old 03-09-2019, 03:30 AM   #5
Airdirect
Have you thought about using a Suburban and then welding on the back of the truck cab behind the rear doors?
http://topclassiccarsforsale.com/che...-70-71-72.html
Airdirect is offline   Reply With Quote
Old 03-09-2019, 11:33 AM   #6
Steve-W
Steve-W's Avatar
Very cool build! I'm in
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 04-07-2019, 02:06 AM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
Very cool!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-19-2019, 04:52 PM   #8
cashforclunkers
cashforclunkers's Avatar
Awesome! Can't wait to see how the rounded rear doors look and how much room you have inside!
cashforclunkers is offline   Reply With Quote
Old 07-29-2019, 07:45 PM   #9
Drewbee
Subscribed awesome!
Drewbee is offline   Reply With Quote
Old 07-29-2019, 07:52 PM   #10
Drewbee
Just curious...can Dana 60 and 14 bolt swap in and bolt to the spring perches on the c50 chassis?
Old 07-29-2019, 08:46 PM   #11
sweetk30
sweetk30's Avatar
1ton down is setup for 2.75" wide stock leafs . aftermarket like lift kits go 2.5" you cant cut in the the housing for 3" wide unless you do a home brew u-bolt conversion as you will loose the 2 bolt holes for the spring plate .
the width for a dana 60 front is 32" center to center .
the 1ton rear for a 14ff is 40.5" center to center and 2.5" wide springs .
the rear can be worked around a bit but the front has the pass side spring mount cast in to the diff housing .
todays axles i would tend to start looking at ford f-450 and f-550 super duty stuff . there a lot bigger and bigger parts and also factory 19.5 rim size .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 07-29-2019, 10:06 PM   #12
Drewbee
Thanks for the info. I’m looking at the K50 rtech build and he said he just put the 1 Tom axles in. I know there are bigger axles but I’m just wondering if it’s as easy as sliding in the 1 ton axles and bolting them to the leaf springs.
Old 07-30-2019, 04:45 AM   #13
Pvmt-Pndr
Put everything in your new thread instead of here...
Old 12-11-2019, 08:42 AM   #14
Drewbee
Any new progress?
Old 05-11-2021, 12:18 PM   #15
goldenburb
goldenburb's Avatar
2021 I understand life keeps use Busy, But any updates ?
67 c10 2wd sb truck
67 c10 4wd lb truck
Old 12-20-2022, 11:20 AM   #16
Ricky Rodder
It's ashamed this one died off.
Ricky Rodder is offline   Reply With Quote
Old 12-29-2022, 11:56 PM   #17
LynnB
Please say it ain't so Joe.
would love to see this finished.
Any one know the OP?
LynnB is offline   Reply With Quote
Old 03-26-2023, 04:48 PM   #18
gup1972
Hello all. Life got in the way and the build is for sale. It pains me to let it go, but I have no choice. Frame as shown in pics, 1997 cummins 12 valve w/125,000 miles, 2012 G56 6-speed transmission that was rebuilt 10,000 miles ago, mint front clip from C50, and various other parts. No cabs, beds, front or rear ends included. Take it all for $10k. I have way more than that in it. 636-432-9509
Old 03-26-2023, 05:06 PM   #19
gup1972
some pics
Old 12-18-2023, 01:49 AM   #20
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man, wish I was in the position to take her off your hands and finish things out.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
