04-01-2020, 05:35 PM | #51 |
Re: 1972 Chevy Crew Cab “Denali”
I know it’s gonna be tough. Going with truck roofline for sure
Posted via Mobile Device |
04-01-2020, 09:55 PM | #52 |
Looking good- great progress
71 C10 72 K20 72 K10 Super Kirk |
04-01-2020, 09:55 PM | #53 | |
The Truck roof line will look better. You have the material. Just do it like Brandon done it. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-01-2020, 10:22 PM | #54 |
Excellent work. Kinda wish I had metal skills.
1971 C20 Longhorn 350/350 "Conquistador" |
04-02-2020, 07:23 AM | #55 |
04-05-2020, 09:23 AM | #56 |
Just playing around with whee and tire combos... fun fun but now it’s timw to get back to working on the thing. Next task is to get floor rust repaired and get to rockers and cab corners
04-05-2020, 11:12 AM | #57 |
Very nice work! Following
1970 CST 4x4 collecting nos parts for this project 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
04-23-2020, 02:26 PM | #58 |
Took some time away from the cab and decided to restore my k20 hubcaps for this build. First I polished them and removed old paint. Then I taped off the inlays where it should be black. Also taped off the bow tie.. Next was two coats of flat black. Upon the removal of masking tape i finished by painting the bow tie inlay blue. May be a tad dark but should look good in new steel wheels.. overall it took about 12 hours... but worth it in the end
04-24-2020, 06:24 AM | #59 |
Caps turned out great!
04-24-2020, 11:46 PM | #60 |
That first picture of the sun glistening off of that cap is pure chrome goodness.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
04-25-2020, 12:40 AM | #61 |
I agree.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
08-13-2020, 10:34 PM | #62 |
Great build! Any updates?
08-14-2020, 03:49 PM | #63 |
6>8 Plugless........
Wow, great build!!! I really like your K10 too. Great fab work you did on this unit. Someday I'll get around to building one.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-19-2020, 09:41 PM | #64 |
Not much to update. Still work on it as much as I can. Been in the mid to high 90s past few weeks so that slows progress. Did remove the outer roof and start laying in the inner roof.
08-19-2020, 09:45 PM | #65 |
Been building some hickey parts for this project as well. Tried to replicate them as best as I can. Made a couple front axle trusses and for one up. Looks real good. Also to my knowledge they never made a finned aluminum diff cover for the 3/4 ton HO52 rears. So I started messing with some metal and ended up with a nice looking diff cover. Painted that up tonight to look like an aluminum one. Super happy with it.
08-19-2020, 09:45 PM | #66 | |
That's going to look smooth. .
08-19-2020, 09:47 PM | #67 |
08-19-2020, 10:35 PM | #68 |
Very sweet build truck of dreams coming to life
08-19-2020, 10:49 PM | #69 |
This is very similar to the plan I hope to use with my Headliner.
Just a suggestion I would weld a Jig. If you run a solid bar with{ tabs (down ward) } where you can bolt to your upper shoulder seat belt bolts. . Slotted brackets front side or back That would be slotted etc. etc. to hold the roof Up to keep it some what in position. You could put a Sheetmetal screw to hold it also. Then use it to support the roof while you are welding/ It will help with the heating and cooling of the roof panel for your plan. Just suggesting. Hope this helps. Your are making Great Progress. I hope to get back to work on my in a few months. .
08-20-2020, 03:54 PM | #70 |
Great work on the diff cover and truss. I remember seeing a Hickey diff cover for a HO52 but I don't remember who had it. Definitely super rare.
12-03-2020, 08:37 AM | #71 |
Update for my fellow crew cab enthusiasts. Got the inner roof all welded in. Outer roof is also attached and the metal work in the inner and outer roof is complete.. on the inner roof I added an additional interior light to light up the front seats and console area...
12-03-2020, 08:41 AM | #72 |
Took advantage of the extended thanksgiving vacation and tacked some major rust repair of the c10 cab back I used. I got in a pinch trying to find a rust free cab back so I settled for average PA rust. I got both rear supports replaced, numerous floor patches, both cab corners, and I re worked my trans tunnel transition so carpet and sound deadened will lay down nicer. Still have some rust in the front half to fix and rockers and such but progress is progress.
12-03-2020, 08:44 AM | #73 |
Also in the last few months I took the time and worked with a fella up in Canada and got a 3D rendering for this build and he knocked it out of the park. Defianly got my motivation back for sure. If you need a rendering done I highly recommend Chad at RenderedRides. Killer work..
12-03-2020, 10:20 AM | #74 |
Almost Satisfied
Wow!! Those renderings are very nice and that truck will be beautiful. I love watching this thread. I would love to tackle something like this, but watching you do it is much cheaper
Now that you are motivated, let's see updates each week!
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
12-03-2020, 11:07 AM | #75 | |
