05-25-2019, 06:21 PM | #51 | |
I'm trying....
Re: 1969 K10 CST Full Restoration
Thanks. Still a lot ahead for sure...but getting there.
Thanks my boy. Only wish I could find the NOS honey hole where you fish. Quote:
With regard to the body work...one of the things l respect about Eric most is his neatness and efficiency. I like the way he thinks about stuff and sequences his work. He just works smart and clean. When we've got something detailed and clean, it stays that way. It doesn't get dusted up. Thanks again for the kind words. Hopefully we'll have a few pics posted before we all have to head back to work next week.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
05-25-2019, 08:28 PM | #52 |
I am in for the journey. Your work is always meticulous and spotless. Doesn't hurt that you are building the one last truck project that I would like to take on (SWB K-10 with auto and air). I have whiffed on several but am still out there looking. Keep up the good work
05-26-2019, 05:56 PM | #53 | |
I'm trying....
05-26-2019, 09:06 PM | #54 |
I'm trying....
A surprisingly huge hang up on this build was the rear diff. Our truck came from the factory with 3.73s. Since the Dana that we transplanted on the front was a 3.08 in great shape...and the 3.73 under our frame was not (to say the least), and we were going with a 3 speed automatic, we decided to go with 3.08s all around. Even though we've got a '71 axle on the front, it was important to us to try and keep the original rear axle housing dated 10/23/68. For whatever reason the new gear set was really a bear to set up. I put it together and took it apart over 20 times before I finally got it to a point where I thought it was even close. It had been so finicky, I honestly didn't trust it'd be the same once the try-in bearings were swapped for new ones. So I leaned on my go to guy for stuff like this. He's been doing it for 100 years and promptly told me that without a proper pinion depth checker, I was...how shall I put this..he said I was going #2 into the wind. Which I guess it depends on your diet or health as to how bad that really is. Anyway, turns out this rear end is a fighter and gave him all he wanted too. And he hilariously admitted as much through a couple of loud and colorful phone conversations...It took him a few weeks...But to his great credit by 6pm on Friday he had the pinion set with new pinion bearings pressed on which was enough for me...so I hustled to pick it up to get it under the truck this weekend. I shimmed the carrier where I left off and sure enough the backlash was perfect. It made a pretty pattern and felt silky smooth. But after the long ordeal, it needed serious freshening up, which Eric took care of last night and we set out today to get this rascal buttoned up and--finally--under the truck.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 05-26-2019 at 09:23 PM. |
05-26-2019, 09:11 PM | #55 |
I'm trying....
Brakes done.
I can't stress enough what a wonderful resource Tony(71CHEVYSHORTBED402) is creating with his build (if you haven't, you gotta check it out: https://www.67-72chevytrucks.com/vbo....php?p=8401012 ) So happy to put that diff cover on....
05-26-2019, 09:14 PM | #56 |
I'm trying....
And we finally have a true roller. I thought we'd be here sooner...but so happy we are here now.
05-26-2019, 09:19 PM | #57 |
I'm trying....
You know I love me some stickers. Though not in love with the repro valve cover decal. Just doesn't seem like great quality. We may have to work on this. Also a little camo on our Pertronix coil.
05-26-2019, 09:29 PM | #58 |
Has to feel good to have a rolling chassis- amazing attention to detail
05-26-2019, 09:32 PM | #59 |
I'm trying....
Oh my gosh...absolutely it does. Thanks.
05-28-2019, 02:46 PM | #60 |
Damn that’s perty.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
05-28-2019, 04:47 PM | #61 |
Proprietor of Dale's Corner
Looking absolutely amazing......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-28-2019, 10:04 PM | #62 |
I'm trying....
Picked up reproduction GM belts from gastanks.com.
Tried to learn from experience, and didn't even try the rear brake lines from InLine Tube. Just bent scratch ones ourselves.
05-28-2019, 10:05 PM | #63 |
I'm trying....
Thanks guys.
05-28-2019, 11:09 PM | #64 |
Brake lines look nice!!
What paint did you use on the engine? |
05-28-2019, 11:19 PM | #65 |
VHT engine enamel, Chevy orange.
My son's 1970 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=703733 Iron Canine's Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 Iron Canine's little girl's tractor http://67-72chevytrucks.com/vboard/s...d.php?t=766665 1969 SWB 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=786335 |
05-28-2019, 11:57 PM | #66 |
Looks great...nice that you're going the resto route!!! Sub'd!!!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
05-29-2019, 09:12 AM | #67 |
Carpe manana
It's a masterpiece already - love the belts!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-29-2019, 10:07 AM | #68 |
I love the part numbers on the belts. I always thought they were printed not stamped..very cool...
05-29-2019, 09:23 PM | #69 | |
I'm trying....
Probably for the best, but we're not generally as uptight as the Corvette and Camaro guys...however I've recently found out that it's worthwhile hanging out on their sites, because they are making stuff that we can use.
06-02-2019, 02:18 AM | #70 |
Love it! Getting a little Rackman build deja vue here : )
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
06-02-2019, 07:44 AM | #71 |
I'm trying....
No doubt...Twice bit, Thrice shy?
06-05-2019, 02:08 PM | #72 |
I'm in.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
06-09-2019, 09:12 PM | #73 |
I'm trying....
06-09-2019, 09:37 PM | #74 |
I'm trying....
A little weekend update....Prep, prep and more prep. Eric cut/drilled the holes for the cargo light and then got down to the tedious and dirty business of body working the cab. I have no doubt she'll be a fair bit slicker than new when he's done. Alas, much more prep in the week ahead.
But if the breaks go our way, then primer later this week and maybe even a little color the week after (dare to dream).
06-10-2019, 05:09 AM | #75 |
It's looking really good.
Tags |
1969, 4x4, cst, k10, swb |
