Old 07-23-2021, 08:18 AM   #51
SCOTI
SCOTI's Avatar
Re: Will 15" x 10" wide rim with 4" backspace fit with stock rear?
Originally Posted by joesscamaro View Post
For the rear I'm wanting to go with the Raceline Classico in a 20x14 with the MT Sportsman SR 29x15 tire. I have disc brakes on the front already and can get the measurements I need...so I'm not too concerned about that. Mainly talking about the rear.
While a 14" wide wheel can be made to work on a stock width housing, I'm betting you're going to want a narrowed housing. That wheel & tire size is about the 'look'. To achieve it, you'll want the hub deeper within the barrel/rim. To get that means a narrower housing vs a OE truck set-up.
What year & body style?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-23-2021, 08:31 AM   #52
joesscamaro
This is on a '65 SWB fleet. On a stock rear end and approximately 9" backspace...just throwing numbers out there...you don't think a 5" lip would look alright? You're just implying that, aesthetically, it would look better on a narrowed rear with more lip?
joesscamaro is offline   Reply With Quote
Old 07-23-2021, 08:53 AM   #53
SCOTI
SCOTI's Avatar
Correct. A 20" diameter 14" wide wheel w/9" of back-spacing will not have the same appeal as one w/7"BS.
Lowered truck? If so how much?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-23-2021, 10:26 AM   #54
joesscamaro
I see what you're saying. Truck will be on bags with a c-notch. I don't have pictures to base this on, but I think I would be ok if the wheel only had a 5" lip. I don't mind the big lips a lot of people are running but I would like to have a more "classic/timeless" look on my truck.
Old 07-23-2021, 01:18 PM   #55
SCOTI
SCOTI's Avatar
If you prefer the deep back-space vs. the deep front lip, you can make a 14" wheel fit on an un-narrowed 63-69 housing. I did 15x14 w/9.5"BS under a 67SWB bed w/a un-cut 12-bolt housing. I got it all set-up but didn't care for the look when it was all said & done (this was w/an xtra deep c-notch, widened tubs, & raised floor). On that note, all the extra wheel & tire beyond what is typically used for the "classic/timeless" appearance is extra weight & will make service work on the rear a PITA.
The 63-66 bed insides are different vs 67-72's so it's going to depend on how much cutting-up you're going to do to 99% dial in your BS needs but your proposed number is in the ballpark.
Adding disc brakes can impact your track width as well so you need to verify the rear end dimensions w/the brakes you plan to use or pad your needs enough to cover the possible 'what ifs' (wider/narrower).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-23-2021, 02:24 PM   #56
MT65
Originally Posted by shortstep60 View Post
I have some 15x10 with a 295/50/15 with a three inch backspace and it’s way to tight.
I had that same combination, the previous owner has trimmed the inner edge on the wheel well, extremely close , but worked…..
The picture is not the best , however that’s the combination..
Missed your backspace at 3”, mine are 4” backspace, which actually all four wheels are off and for sale
MT65 is offline   Reply With Quote
Old 07-24-2021, 03:15 PM   #57
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Nice green.
66 C20 Service Truck:
Old 07-24-2021, 09:48 PM   #58
joesscamaro
I should have been more clear I guess...what I mean by classic/timeless look is that the wheels im looking at give a nod towards the 60s era with a more modern look when it comes to the size of them. Im fine with having to tub the wheel tubs and trim the wood floor as needed...other than that I don't want to have to trim anything else. So, you think I'd be ok with buying my brakes for the 12 bolt and going that route? I'd hate to buy brakes for my 12 bolt and then wheels/ tires won't fit and then I need to go with a narrowed 9" rear.
Old 07-24-2021, 10:45 PM   #59
SCOTI
SCOTI's Avatar
You asked 'can they fit?'.... They can. Do you have access to any 15x8 stock Ralleys?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-24-2021, 11:34 PM   #60
MT65
Originally Posted by LostMy65 View Post
Nice green.
Thanks, wish I knew what it’s technically called…Seafoam????
