Old 07-13-2021, 08:25 PM   #51
_Ogre
_Ogre's Avatar
Re: Who Sells This Under Dash Valence?
Now: Where do I find the "Idiot's Guide To Making Fiberglas Parts" How to pull this all together?
ask and ye shall receive
seriously, just ask away. i did all of my fiberglass in a finished painted cab, no doors or interior, but everything i did inside or under hood was in a finished cab. gotta remember that i did the column cover, valence (fascia), console and sub enclosure as one piece of artwork.
look at this pic to see the bones of my fascia/column cover, light stuff is wood, dark stuff is cardboard mailing tube. i started out with a few brackets that were welded to the dash for a simple sheetmetal fascia that sorta sucked. i made a plywood L with a couple dados cut to staple cardboard into.
the tube is 4", i cut it into half and quarter radiuses on the table saw and started stapling, gluing and taping in place. i went thru a lot of supper glue during fiberglass work. start shaping and taping until you like the shape. it's pretty easy and vey time consuming and maybe a little addictive...
the compound curve used the tube inside for the top and pie cut tube on the bottom; there's 12 pieces just in the left side of the fascia
the column cover uses a piece of mdf for the top U, mdf squares for mounting blocks to the column and half tube piece. this is the first full layer of 3/4 oz matt (used for all my glass work), there are probably 4 or 5 layers of 3/4 oz matt on the fascia and console. 7 to 9 layers of 3/4oz matt on the sub enclosure
most of my tape, wood and cardboard is still there as part of the structure impregnated with resin. some of the cardboard was removed
shop air compressor timer
Old 07-14-2021, 02:25 PM   #52
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by 1project2many View Post
Hi Dan,
I may have found the car version of the one in the first couple of pictures.
https://www.trifive.com/threads/eckl...8/post-1782965
completeautoupholstery.com seems to have gone down between 2019 and 2020 but there are archived versions. https://web.archive.org/web/20190104...pholstery.com/
Contact information is also available in archives including an owner name:
https://web.archive.org/web/20130212...ry.com/contact
They do have a facebook page as well
https://www.facebook.com/CompleteAut...=page_internal
with some photos
https://www.facebook.com/CompleteAut...44686415587277
In all honesty, I would send these folks the pictures of the truck dash valance with a question about the source.
First, thanks so much for this information^^^
I wonder if the car one would work on the truck though I doubt it because the center section was made to go under the car's centered glove box door. (Besides, I can't say I really like the way it looks. But I LOVE the ones in the pictures posted)
But you're right that contacting these people and asking about the ones in the pictures I posted. I don't know if I could get them interested in developing one for the Task Force trucks but I'll try. Otherwise I have to take on the fiberglas job and I REALLY don't relish it.
PS: Neither of those Complete Upholstery links work. I posted pictures of the green & orange ones on the Facebook page. Hopefully someone sees it and responds!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-14-2021, 04:34 PM   #53
1project2many
Sorry about that. They work on one of my browsers but not the other. Here's the contact info from the archived page:
Complete Auto Upholstery
Original and Custom Interiors
Contact Information
Owner: Howard Krusey
Work: 407-869-1340
Fax: 407-869-1340
The work # shows up in a 2017 post on the Facebook page also. Good luck!
1project2many is offline   Reply With Quote
Old 07-15-2021, 10:55 AM   #54
Kevin_C
I sent a message to No Limit to see if they have any installed pics of the extension. All my vintage air parts are in so I'm probably going to order one and modify it as needed
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 07-18-2021, 11:01 AM   #55
56 3100
56 3100's Avatar
i followed OGRE pics for mine just have to finish it. I used a thin piece of plywood some round cardboard shipping tube from staples for rounded edge on bottom.
56 3100 is offline   Reply With Quote
Old 07-19-2021, 01:14 PM   #56
Dan in Pasadena
Originally Posted by 56 3100 View Post
i followed OGRE pics for mine just have to finish it. I used a thin piece of plywood some round cardboard shipping tube from staples for rounded edge on bottom.....
Thanks a lot for posting these pictures. They tells me there's a lot of "cut to fit, bend to suit, paint to match" to make the form for a valence!
Maybe I'm not seeing it but is there a flange that will bolt/screw to the underside of the dash?
I hadn't thought of it but the "roughness" of the joints between the various pieces disappear once they're covered in 'glas. I thought they'd telegraph through the cloth/resin but I suppose if they do just add more and sand them smooth after!
Old 07-19-2021, 09:11 PM   #57
G&R's57GMC
G&R's57GMC's Avatar
Dan ,
You can add a 90* aluminum 3/4" or 1" strip or pieces to the fiberglass blank with mounting holes pre drilled for the underside of the dash after the blank is released from the buck . Just glass them in . Probably wouldn't hurt to add larger holes to the side that bonds to the blank so the fiberglass has a stronger grip on the blank .
The fiberglass will give you general shape and structure , then "Bondo" will give you close to final shape , then lots of sanding to refine the finished shape . Now your ready for paint .
You've got this , have fun with it .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 07-21-2021, 10:51 PM   #58
56 3100
56 3100's Avatar
hey dan the white metal bracket in pic#5 are what the flat part mounts to. i have countersink head machine screws fiberglassed in (not seen in pic) ends have srews countersunk as well.can get some pics with screws in if you want.
Old 07-23-2021, 01:12 PM   #59
_Ogre
_Ogre's Avatar
nice to see someone else make their own dash fascia/valence
there's no wrong way, unless you don't make one for fear of the work
i did the same with fiberglassed in screws, you can see one in my pic above
if you plan on using the glove box door, might want to install it, it'll need a cutout to operate
be sure to plug in the ignition, dimmer and nss, that's the bump outs on my column cover
Old 08-06-2021, 11:02 PM   #60
Dan in Pasadena
I'm procrastinating like hell on this primarily because I WANT the one in the original pictures I posted - the ones in the green & orange trucks. I love how it looks and IF I ever try making one I'll be trying to duplicate that look.
I feel certain SOMEONE has to make it only because these two trucks seem to have the identical piece. If one of you noticed a significant difference in those two pictures, please let me know.
The 2nd reason I am procrastinating is because I did a little fiberglas work many years ago (high school, ha ha) and I remember it being an itchy, hot, stinky mess of a job. NOT looking forward to doing that again. But I'll have to if that's my only alternative to get what I want. Ogre, I won't be making a cover for the steering column. Mine is an ididit column I picked up cheap on Craigslist and asked until I did the truck. It's stainless and I had it polished so I want to be able to see it.
Old 08-07-2021, 06:00 PM   #61
Kevin_C
I did some image surfing. couldn't find anything on the orange one but found the green one. owner and shop that built it is listed. you might be able to track him down on FB. Also seen the truck in an "Arizona car scene" article
https://www.motortrend.com/features/...y-chevy-truck/
Old 08-08-2021, 01:21 PM   #62
Dan in Pasadena
Thanks for the link, Kevin. I had seen that article before - I’ve kept all the pictures of course.
I hadn’t thought to try to contact the owner but now I’ve put in a friend request on Facebook. No idea if he’ll ever reply but at least I’ve made the effort. Thanks again, Dan
Old 08-08-2021, 03:15 PM   #63
_Ogre
_Ogre's Avatar
oh c'mon dan... just make one!
Old 08-08-2021, 09:17 PM   #64
Dan in Pasadena
Ha ha ha!
Old 09-27-2021, 07:55 PM   #65
mrbuck
Any leeds on these? yeah i know Orge just make it, which i probably will. unless i can find one cheap. time is money and im short on both
mrbuck is offline   Reply With Quote
Old 09-28-2021, 12:04 PM   #66
_Ogre
_Ogre's Avatar
orge is a big round fruit, this ogre is neither round, nor a fruit
i should get a cab and make a buck to produce these dash valences
but as dan reminds me...
i'm retired, don't want to, don't need to and you can't make me
so blame dan for my lack of interest
Old 09-28-2021, 12:09 PM   #67
_Ogre
_Ogre's Avatar
did 56 3100 ever make progress on this?
Old 09-30-2021, 03:42 PM   #68
captn6
https://nolimit.ecwid.com/# found this for my 58
captn6 is offline   Reply With Quote
Old 10-03-2021, 11:07 AM   #69
mrbuck
Did you use that one ☝️ Do you have pictures, how was fit and finish?
Old 10-13-2021, 08:23 PM   #70
56 3100
56 3100's Avatar
hey Ogre havent been on forum i n a bit busy working on truck paint guy wants it back end of oct so the work frenzy continues. Valence i did do some sanding on last couple days. not missing the itch from fiberglass sanding . used round glue container wrapped it in sandpaper to get corners. cut out for radio in main section soon before i finish it.
Old 10-24-2021, 11:28 AM   #71
captn6
https://nolimit.ecwid.com web site for no limit $135 bolt on should save some time.
Old 10-30-2021, 09:35 PM   #72
Dan in Pasadena
Thanks but we discussed this back in post #17 on the first page. I've been tempted to buy that one but it seems too short for the round AC vents I want to use. If it were maybe 3/4" to 1" taller it would be perfect.
I'm still tempted to get it though because the hard work has already been done and if I REALLY disliked the height (and already had $130 in it) then I'd consider splitting it and lengthening it.
Old 10-30-2021, 11:52 PM   #73
Kevin_C
Hey Dan, I tried reaching out to No Limit a couple times and never heard back. I can no longer find it listed on their web page so I might have to go the Ogre route
Old 10-31-2021, 05:19 PM   #74
56 3100
56 3100's Avatar
one thing i notice about no limit one is it has round bosses for ac vents it you not going ac you would have to cover them.
Old 10-31-2021, 10:33 PM   #75
Dan in Pasadena
Yeah, I noticed that too. At first I didn't really care for it but then after searching online for AC vents I wasn't all that taken by any that weren't round so I guess I'm ok with it I jut think it's shorter than I would prefer.
