11-29-2020, 03:35 PM | #51 | |
Re: Build Date
A little paranoid about giving out my serial, but to add to some value, my 71 declared May 19, 1971 is the low 1Z654500ish 654510 is too low & 654530 is to high Call it 654520. I added this (blue) to the last post above, so should be up to date. I'd like to add my 72, but wouldn't you know it's the only part of the door sticker that's toast. The truck has a build sheet but there's no pulling it out, especially with the seat in, and I doubt even that - crumbles at the slightest touch. The factory and serial on my 72 is Z146839.........Edit: That said I caught your post Taskforce, and if anything the sticker appears 3/72. Thanks to the two 72 you have recorded, it must be 2/72 or 3/72. The factory averaged 6Kish per month at the time. Cool.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-29-2020 at 04:22 PM. |
11-29-2020, 03:56 PM | #52 |
All about them K’s
Re: Build Date
FYI I started a thread dedicated to this project. It can be seen here. I will post the most recent iteration of the list as the starting point of that thread. Thanks everyone!
http://67-72chevytrucks.com/vboard/s...d.php?t=815033
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-29-2020, 04:30 PM | #53 |
Re: Build Date
Just working in the old post to see what formatting looks the best and is easiest to read.
1967 GMC 1968 GMC 1969 GMC 1970 GMC 1971 GMC 1971 FREEMONT (VIN Code Z) 1Z120204 = 4/71 1972 GMC __________________________________________ 1967 CHEVROLET 1967 FREEMONT (VIN Code Z) 7Z116048 = TBD 1968 CHEVROLET 1969 CHEVROLET 1969 FREEMONT (VIN Code Z) 9Z833902 = 12/68 (12/05/68 Build sheet) 9Z845573 = TBD 1970 CHEVROLET 1970 JANESVILLE (VIN Code J) 0J122962 = 12/69 1970 FREEMONT (VIN Code Z) 0Z100986 = 9/69 1971 CHEVROLET 1971 FREEMONT (VIN Code Z) 1Z602191 = 8/70 1Z603538 = 8/70 1Z622515 = TBD 1Z653085 = 4/71 1Z654520 +/- 10 = 5/71 1Z657051 = 5/71 1972 CHEVROLET 1972 BALTIMORE (VIN CODE B) 2B121743 = 12/71 2B132457 = 1/72 1972 JANESVILLE (VIN Code J) 2J160173 = 6/72 1972 FREEMONT (VIN Code Z) 2Z153077 = 3/72 2Z168790 = 5/72 Last edited by geunther; 11-29-2020 at 04:35 PM. |
12-04-2020, 11:07 PM | #54 |
6>8 Plugless........
Re: Build Date
Does anyone reproduce the blue manufactured date decal? The one on my 72 was cracked and faded badly. Also, is the seat the only place build sheets were placed on these?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-05-2020, 12:11 AM | #55 | |
Re: Build Date
12-05-2020, 02:39 AM | #56 | |
Re: Build Date
12-05-2020, 08:40 AM | #57 |
Re: Build Date
Good questions. First production units came off the line in August. Not sure what was the production numbers for each day, probably depends how many lines and shifts were working that day. Sequence start at 100001. Here is a very early production '64 built in Fremont ( H code changed to Z code in '65). First Day? First Hour?
12-05-2020, 08:46 AM | #58 |
Re: Build Date
Good point jocko. Engine blocks for example, may date a few months earlier. A '71 model year built in Sept. '70, may have an Feb, March, May '70 date on block.
