Old 04-13-2021, 01:08 PM   #51
Kronald_70GMC
Kronald_70GMC's Avatar
Re: 1968 C10 Stepside Restoration Project
Better than new! Looks really good.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 04-13-2021, 06:31 PM   #52
68 C10 Driver
Thanks! Just one step closer.
68 C10 Driver is offline   Reply With Quote
Old 04-15-2021, 10:25 AM   #53
88Stanger
88Stanger's Avatar
looking great! Good job
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 04-15-2021, 10:29 AM   #54
71cadc10
71cadc10's Avatar
very nice. I took a real liking to the raptor liner...I sprayed the insides of my bumpers with it. Coated the fender emblems with it...as well as the bed. very versatile stuff.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 04-20-2021, 05:35 PM   #55
LT7A
Really good progress. If I didn't know, I'd guess that you had been through this kind of work before. You seem matter of fact, and methodical, and the truck is coming together nicely.
Old 04-20-2021, 06:49 PM   #56
68 C10 Driver
LT7A, Thanks for the complement but I have only restored a couple MGs and a few motorcycles, nothing to the scale of this truck. I never had to weld like I have on the C10, or use a spray-on bed liner. I have literally watched endless how-tproject. and read through endless posts on this forum, learning all I can so I could work towards completing this project.
After the truck is done, I have a classic Mini to restore, and it is worse off than the truck!
Old 04-20-2021, 07:55 PM   #57
Carl Spangler
Carl Spangler's Avatar
I would like to see a couple pics of that Mini.
1971 SWB step side: Original NM Forestry and then NM Fire truck
Carl Spangler is offline   Reply With Quote
Old 04-28-2021, 05:34 PM   #58
68 C10 Driver
The Mini is just a body shell at the moment. I actually started that project before the truck. Because this truck belonged to my wife's late father, she wanted me to drop the Mini and start on the truck. I will look for some photos of the Mini when it was delivered and some of the progress I made on it. After closer inspection it was apparent that it had been wrecked and was poorly repaired.
Old 05-23-2021, 10:39 AM   #59
68 C10 Driver
So I have been able to get out and work on the truck between entertaining the kids. I finally got rhe chance to clean up the floor a bit, now to clean up the passenger side.
Old 05-23-2021, 10:42 AM   #60
68 C10 Driver
I have also been working on the bodywork on the driver's side cab corner. I will get the final sanding on it when I block the cab.
Old 05-23-2021, 05:53 PM   #61
68 C10 Driver
I really debated on whether to recreate the old panel seams on the rocker at the A & B pillars, I elected to eliminate them for a cleaner look. Driver's side is the same.
Old 05-23-2021, 09:40 PM   #62
Kronald_70GMC
Looks super clean! Good stuff
Kyle
IG: kyle_ronald
Old 05-24-2021, 10:43 AM   #63
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Looks great. Good work.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-25-2021, 06:05 PM   #64
68 C10 Driver
Thanks for the complements everyone. I will pick up steam again after Memorial Day. I want to sand the passenger side floor so I can get a good coat of epoxy primer down.
Old 05-25-2021, 06:36 PM   #65
Carl Spangler
Looks great!
Old 05-28-2021, 08:35 PM   #66
68 C10 Driver
Thanks, this has been a real learning experience!
Old 05-28-2021, 08:37 PM   #67
68 C10 Driver
Looks great!
Much appreciated! I will start on it again after the Memorial Day holiday. My goal is to have this cab painted by August!
Old 05-31-2021, 06:05 PM   #68
68 C10 Driver
So once again the weather was really great! We just got back from St.Augustine, FL and it seemed like a good day to get to sanding the passenger side floor. There was a pretty good amount of surface rust under the paint. This didn't surprise me as I was told by my wife that her dad would wash out the inside of the truck's cab with a hose. He believed that as it was a work truck, that was an acceptable method to clean it.
So after some sanding, I hit the floor with some Rust Mort...that is definitely some potent stuff. I will let that do its thing overnight and hit the floor with the self etching primer. I will eventually spray the floor with the epoxy primer to better seal it. after that I will work on the upper portion of the floor (inside firewall) and epoxy prime that as well.
Old 05-31-2021, 06:26 PM   #69
68 C10 Driver
I forgot to mention that I am retiring the Muncie 3 speed that came with the truck. I decided to go with this Muncie M20 4 Speed. I picked it up rebuilt, and I believe from the numbers on the case it is a '67 or '68. I was also able to pick up this Hurst Competition Plus shifter for under $100, and also got the shifter handle that will work with the bench seat. I'm going to try and use the reverse light switch made for the M20, according to the multimeter, it works great!
Old 06-01-2021, 07:15 PM   #70
68 C10 Driver
Making further progress on the floor and interior firewall area. had to stop to apply more Rust Mort. Once it dries, I will lightly scuff and paint with etching primer.
Old 06-01-2021, 07:18 PM   #71
68 C10 Driver
Not sure why the pics were upside-down and sideways, it is what it is I guess...
Old 06-02-2021, 11:18 PM   #72
Grumpy old man
Grumpy old man's Avatar
This is the shifter install kit you need , The difference between this one and the one I used is your trans shift arms attach using a stud and nut were mine is attached using 3/8 bolts other than that they are the same kit. watch the video I sent you a link to and he will show the difference .
install link https://www.youtube.com/watch?v=yaQw...PsyqqE&index=2
https://www.holley.com/products/driv.../parts/3733163
you may want to use these also and save your old ones in the glove box . https://www.5speeds.com/cart/index.p...&product_id=76
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-03-2021, 12:47 AM   #73
Grumpy old man
Old 06-03-2021, 10:28 PM   #74
68 C10 Driver
I just so happened to order the 3733163 Linkage kit! Thanks for the info.
Old 06-06-2021, 07:14 PM   #75
68 C10 Driver
Getting rid of the seams in the door opening of the cab. This way I do not have to worry about seam sealing them or moisture getting into them. Besides, it is a very subtle difference that only a 67 - 72 C10 owner would notice...it's just a cleaner look.
