12-02-2021, 10:43 PM | #51 |
Re: QA1 install on my Sons Truck. (Pics)
12-03-2021, 01:35 AM | #52 |
Senior Moment
Thank You. Just ordered widened rear tubs, I must have wider tires in the rear. Time will tell where this goes. LOL
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
12-03-2021, 05:45 AM | #53 |
Looks good and I bet it rides nice now!
12-03-2021, 06:43 AM | #54 |
When u get the wider rear tubs n place then you will go even more down the rabbit hole and get the wider front tubs ….lmao. Looks like 315’s and forged rims are n the future 4 you.
12-08-2021, 04:34 PM | #55 |
I just finished installing the rear kit for stock trailing arms. Rides way better than my last set-up of Ridetech RC shocks @ 6" ECE lowering springs. I will say that once you get to the part of the instructions that say "some trimming may be required to fit brackets onto stock arms" take a deep breath! I'm the type that troubleshoots with a scalpel rather than a chainsaw. I stated with a grinder and ended with a sawzall. Took a lot of passes (a little bit at a time) to get the brackets on. Then when I went to bolt on the Coil-over bracket the bolts hit the TA and I had to trim some more. Would be great if QA-1 had some templates to show how to trim. Now that it's all together I am stoked so all the work and headache was worth it.
12-08-2021, 04:46 PM | #56 |
Senior Moment
Nice. If you add the QA Sway Bar it will improve even more
