Old 01-21-2022, 05:01 PM   #51
Grizz1963
Grizz1963's Avatar
Re: A '62 has to get back on the road
Erstaunliche Arbeit ist dir gelungen. Ich bin beeindruckt. Was ist Ihre tägliche Arbeit, wenn Sie dies so gut machen? Ich mag die Farbwahl, weil sie anders ist. Der Winter verlangsamt sicherlich meine Fortschritte. Vielen Dank für das Teilen Ihres Builds.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 01-21-2022, 11:06 PM   #52
Low Elco
I don't know much German, but Icht Sehr Gut! (I Think!) Nice work!
Low Elco is offline   Reply With Quote
Old 01-22-2022, 04:00 AM   #53
Braunschweiger
Thank you very much, I was able to retire in 2020 and bought this C10 in the summer of 2020 to do what I enjoy. I was also able to gain initial experience with my 68er Mustang, but it didn't have to be painted and welded.
The welding work was my first time, I had welding skills, but not for that :-) painting is also my first time, it can definitely be done better, but it's okay, I've learned a lot here from the forum, you guys Great, thanks for that.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 01-22-2022, 10:22 AM   #54
Braunschweiger
Now it's the turn of the frame, the engine and the gearbox had to leave their place, as did the exhaust, the axles stayed in place for the time being, I wanted to clean the whole thing in a washing area. Roughly pre-cleaned for the first time.
Greetings Harald
My 62 build thread
Old 01-22-2022, 10:36 AM   #55
Braunschweiger
The frame has been cleaned and I have an unpleasant surprise with the crack in the frame, there were still some, more on that later. Rear axle removed, it's an 8.5 inch, 10 bolt axle, from a '76 Pontiac, my C10 runs on a 5x4.75 bolt circle, I could identify that with the rear axle code 2.41:1 with Positrack, geared quite long, strange axis.
Greetings Harald
My 62 build thread
Old 01-22-2022, 10:50 AM   #56
Braunschweiger
Removed the '62 front axle, it was still welded to the frame, why? The truck probably had a bad accident and the frame was cut open, straightened and welded again. I reopened the crack, the metal was a good 3mm on top of each other, with a 20t hydraulic ram, I drilled and welded holes in the crack, ground the crack into a V shape and step welded it, for stability, another plate was placed behind it and spot welded, that should hold
Greetings Harald
My 62 build thread
Old 01-22-2022, 11:04 AM   #57
Braunschweiger
I reworked the repair welds again, grinding and rewelding where the welding was not clean, an unfavorable place for stability.
Sanded the frame and set it up with the engine jack for painting, with zinc phosphate rust protection the 1st layer
Greetings Harald
My 62 build thread
Old 01-22-2022, 12:06 PM   #58
notsolo
notsolo's Avatar
Nice project, your metal kills are very good, sheet metal looks amazing...and the color comb is great. Looking good....what's your plan for the axles, I went with a 5 lug from an " 82 " 11 inch discs and the booster from same truck, worked out well. Made a plate to cover double hole from old a master and slave cylinder clutch.
notsolo is offline   Reply With Quote
Old 01-22-2022, 01:34 PM   #59
Braunschweiger
Well I'm from Germany and I was lucky to find a 63 axle, I'm sticking with the 5x4.75 bolt circle because I already have the rims for it, the truck already has PB which works great. The conversion with Dropspindles and the bolt circle is exciting, I will report about it
Greetings Harald
My 62 build thread
Old 01-22-2022, 01:51 PM   #60
Joe Pass
Joe Pass's Avatar
Nice...
Joe Pass is offline   Reply With Quote
Old 01-23-2022, 01:01 AM   #61
Warrens69GMC
Warrens69GMC's Avatar
The front should be able to use 1988-1992 Camaro 1LE rotor, 12" with 4 3/4" bolt circle
https://www.speedwaymotors.com/1988-...RoCbEkQAvD_BwE
Old 01-23-2022, 12:48 PM   #62
Braunschweiger
Exactly, thanks, I got them from the '91 Camaro SS, the bearings fit perfectly for the '73-'87 Dropspindles
Greetings Harald
My 62 build thread
Old 02-01-2022, 09:54 AM   #63
Braunschweiger
I'll write something about assembly again. I can finally screw parts back on, the frame and axles are painted, the trailing arms have new bearings, the Rear Axle is in Place.
The front control arms have new shafts and ball joints.
Greetings Harald
My 62 build thread
Old 02-01-2022, 10:20 AM   #64
Braunschweiger
Something new from the workshop
My 1962 C10 has axles with a 5x4.75 bolt circle and they have 1" thick brake discs, the trucks usually have 1.25" thick brake discs, also a 5x5 bolt circle, now it should be lower, using Dropspindles.
WesternChassis has 2.5" dropspindles for 1" thick brake discs for C10 from the years 73-87.
Now you have to dig deep into the Chevy kit to build it on a 63 axle that is installed under the 62.
Brake disc comes from the 91 Camaro 1LE, which is identical to the truck brake disc, but has a 5x4.75 bolt circle and the bearings are the same, fits.
Ball joints come from 73-87, everything fits in, Chevrolet hasn't changed anything there, has already tested and fits.
The tie rods are trickier, on the outside they come from the 73-87, they have a right-hand thread and are 11/16", the 63 outer tie rod has a left-hand thread and is 5/8" thick
So the outer '63 tie rod moves inwards and replaces the inner '63 tie rod with right-hand thread.
From POL there is an adapter sleeve 11/16" right-hand thread and 5/8" left-hand thread to connect and voila the suspension is ready.
Caliper comes from the 70-87 Camaro.
The calipers have been revised.
All the tips came here from the ChevyTruckforum, thank you again.
Greetings Harald
My 62 build thread
Old 02-01-2022, 10:41 AM   #65
Braunschweiger
Now it's time to assemble. 2" Drop coil springs were added. Everything fits.. the idler arm from the '63 still has to be adjusted so that the steering can also be installed, it goes on....
Greetings Harald
My 62 build thread
Old 02-03-2022, 10:12 AM   #66
Braunschweiger
Installed my steering today, I described it in the photo, maybe it will be helpful for someone else, to drive 5x4.75 bolt pattern.
I'm happy that my steering also works in practice.
Parts:
81-87 WesternChassis 2.5" Dropspindles 1"Rotor
73-87 Upper and Lower Balljoints
73-87 Outer Balljoints
63er Outer Balljoint, go inside.
POL Adapter Sleeve
91er Camaro 1LE Rotor 1"
63er Idler Arm and Centerlink
70-81 Caliper Camaro
Greetings Harald
My 62 build thread
Old 02-03-2022, 11:52 AM   #67
The Rocknrod
Moderator
The Rocknrod's Avatar
That's some great work and information on the front end.
Old 02-03-2022, 11:59 AM   #68
Warrens69GMC
Abrasive Fleece?
Old 02-03-2022, 12:31 PM   #69
Braunschweiger
Parts:
POL Adapter Sleeve
Originally Posted by Warrens69GMC View Post
Abrasive Fleece?
Sorry if I wrote something wrong, English isn't my strong point, but I'm trying. What are they referring to?
Greetings Harald
My 62 build thread
Old 02-03-2022, 12:36 PM   #70
Warrens69GMC
You mention it here..
Now we continue with the painting, first prime everything with 2K epoxy, smooth dents with Bondo and sand everything with abrasive fleece.
Old 02-03-2022, 12:49 PM   #71
jchav62
1962 C-10
jchav62's Avatar
What a great project! Very impressive work...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-03-2022, 12:49 PM   #72
Braunschweiger
What is it called in US?
Greetings Harald
My 62 build thread
Old 02-03-2022, 01:06 PM   #73
Warrens69GMC
Red Coarse Sanding roll. Thank You, i did hot know it came on a roll.
Old 02-03-2022, 01:38 PM   #74
Braunschweiger
Thanks, in Germany it's called "Schleif Flies", this is 400 and is used for roughening
Greetings Harald
My 62 build thread
Old 02-03-2022, 04:29 PM   #75
SCOTI
SCOTI's Avatar
That's like Scotch Brite. Fibrous material & has incremental abrasive levels.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
