Old 08-22-2022, 07:10 PM   #51
Rods
Rods's Avatar
Re: Removing 4 Repair NL2 Aux Tank
Originally Posted by PbFut View Post
Rods That tank is some very nice work that I am sure I would not be able to afford. It is the factory design. I see that there is a new pickup/Sender unit. Do you know the part number and source by chance. I must replace my assembly as well.
I'll get the measurements later today for you.
I have found the sending unit part # its AC 642885 I haven’t looked for one yet but thought i would also let you know i have found a guy here local that is looking into building the tank for me.
Stay tuned……..
Az
Rods is offline   Reply With Quote
Old 09-04-2022, 09:24 PM   #52
67chevy2wd
67chevy2wd's Avatar
Thanks everyone for the replies but I still do not feel we have a complete answer to the question at hand. I started this thread to somewhat document the details of the 1 year only 1972 factory option NL2 Auxiliary Fuel Tank. Long story how I came to this point and maybe topic for another thread, but in any event, the question right now is on the factory switch used in the option. Getter-Done posted a photo in post #40 that I had seen a few weeks ago while searching and it confused me a bit as to where the factory location was for the switch. My truck has a toggle switch in the same location as Getter-Done. My truck also has the original factoy sticker on the dash. What was confusing to me was if the original switch was in the location of the toggle or if the factory had placed or intended to place the switch in the instrument cluster position 2 below the light switch. There appears to be room for the factory switch shown in post 40. I realize now that the ware marks on my dash is not from use but from the bezel used on the factory switch. So I assume that even though the factory could have used position two on the interment cluster it must have been mor efficient to simply drill a hole on the metal portion of the dash. What is also clear is that the original factory switch was probably not very robust as I have only seen toggle switches in use. The photos below I posted for documentation. With Instrument Panel removed you can see the available mount which was could have been used for manual chokes though I believe they were mounted below the wiper switch on opposite side of the steering column. The ware marks on both sides of the toggle switch are not from use but from the original factory bezel used on the factory switch. The marks line up perfectly to the bezel used on the instrument cluster for the factory wiper and light switches. I have a suspicion that it was intended the switch be in position 2 on the cluster and a labeled in the style of the lights and wipers be used. Likely the expense of changing the cluster was too great to justify, so they simply slid the install to the left and called it day. Pictures below show my truck with a previously swapped toggle switch, how a factory bezel covers ware marks indicating this was the factory location of original switch. And a couple shots of original switch plug hacked to use the replacement toggle.
You said this was a one year only 72’ option. This is my 71’ gmc, the glovebox door was switched before I got it so I don’t have the original spid. Was this a dealer installed option before 72?
67chevy2wd is offline   Reply With Quote
Old 09-05-2022, 08:29 PM   #53
jocko
jocko's Avatar
NL2 was a factory RPO, not a dealer-installed option - but it was available in both 71 and 72, so you should assume yours is indeed original. 71 assembly manual excerpts for ref:
Old 09-05-2022, 10:53 PM   #54
67chevy2wd
67chevy2wd's Avatar
Cool to see that. I just assumed all aux tanks were dealer installed.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
Old 03-04-2023, 10:52 AM   #55
jaybatta
jaybatta's Avatar
Dang, I never realized that tank is outside the frame rail AND hangs down below the bed. How many gallons does it hold?
Joe
Joe
1968 K20
1970 K20
Semper Fi
jaybatta is offline   Reply With Quote
Old 03-08-2023, 08:28 PM   #56
67RS/SSx2
Joe
Should be around 18 gallons.
1972 C20 402/TH400/3.54 Highlander
1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold)
1983 GMC Sierra Classic 2500 crew cab (sold)
1972 Chevy C10 Cheyenne Super (sold)
1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it)
67RS/SSx2 is offline   Reply With Quote
